    Unwanted lines
    5 Posts 4 Posters 586 Views 4 Watching
    • jarynzlesaJ
      jarynzlesa
      Hi all,
      How to get rid of unwanted lines (edges)?
      Wrench downloaded at http://archive3d.net/--- format *.3ds.
      I would like to delete a lot of lines, not just hide them.
      Is any plugin to do that by one operation?
      http://www.vizualizaceschodiste.mypage.cz/
      • H
        HFM
        Select the entire object and choose 'smooth edges' from the menu. Play with the slider to get the best result.
        • GaieusG
          http://forums.sketchucation.com/viewtopic.php?t=22920 by ThomThom (for instance).
          But please, jarynzlesa, only ask questions when my wife is not around (you know, she is fond of kittens, too...)
          πŸ˜’
          • jarynzlesaJ
            jarynzlesa
            πŸ˜’
            Sorry for bothering your wife, I just couldn't remember the name of plugin πŸ˜„ thx.
            Best regards to your wife - if she is not around then call at her.
              mac1
              It appears from your OP post you have the 3ds file. If so try importing to mesh lab and you can then reduce the number of vertices. Do it 1/2 at each step and take a look at the model to see if it is of the quality you'll accept
              Select re-mesh simplification and reconstruction
              Quadratic edge collapse decimiation
              Select optimal position of simplified vertices, post simplification cleaning , quality to 1
              Note you can input the number you want
