    Walking dead
    30 Posts 5 Posters 15.5k Views 5 Watching
    • artysmediaA Offline
      artysmedia
      @ely862me said:
      Nice work over here ,well done.
      Attached is the gift in v7 format.Nice gift btw.
      I have v6 v7 and v8 installed but i mostly use v6 ;seems the best for me.
      Take care!
      ๐Ÿ˜ฎ Thanks . Great gift!
      http://farm2.static.flickr.com/1006/5182431886_8b5c36660c_o.jpg
      Walking dead 32 por artysmedia, en Flickr
      Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
      Blog: Artysmedia
        artysmedia
        Here you have the mosaic on 3d Warehouse
        Mosaic 01
        Blog: Artysmedia
        • michaliszissiouM Offline
          michaliszissiou
          Glad you like it. A zbrush (10 min) and decimatorMaster result. You may edit the UV texture in Ps as its almost projected.
            artysmedia
            i think i have to try ZBrush... ๐Ÿ˜†
            http://farm5.static.flickr.com/4147/5181354670_6d5366f3a7_o.jpg
            Walking dead 29 por artysmedia, en Flickr
            http://farm2.static.flickr.com/1402/5181354796_0213202971_o.jpg
            Walking dead 30 por artysmedia, en Flickr
            http://farm2.static.flickr.com/1266/5180755357_c648db98b2_o.jpg
            Walking dead 31 por artysmedia, en Flickr
            Blog: Artysmedia
              artysmedia
              He remodeled the roof of a church that i had made some time before.
              By the way I've changed some parts of the design.
              http://farm2.static.flickr.com/1001/5184390800_1f910a9cf9_o.jpg
              Walking dead 33 por artysmedia, en Flickr
              Blog: Artysmedia
                michaliszissiou
                Better not, its too expensive. For your needs here, blender, or 3DCoat (this last one became the leader to all these apps)
                Now, how did you modeled this fine paving thing? Using push-pull tool? If yes, then can you realize how many faces are there? The VG industry bakes normal maps for this. You can still export a obj mesh to 3DCoat or other app and bake a normal map to a single face. The use of a displacement map is not good as it forces the renderer to do the subdivision, too many faces again.
                Excellent work, once again. Great thread. ๐Ÿ‘
                  artysmedia
                  Before, I used displacement maps but I'm not worth the time it takes to render.
                  Although i have to work more, I prefer to model everything; is more relaxing.
                  I have to try someday normal maps. For now ...
                  Blog: Artysmedia
                    artysmedia
                    A general view with some trees far away
                    http://farm5.static.flickr.com/4125/5187816400_61fe29ecee_o.jpg
                    Walking dead 34 por artysmedia, en Flickr
                    Blog: Artysmedia
                      michaliszissiou
                      OK, another gift.
                      Obviously, I like the whole concept and your work here.
                        artysmedia
                        OK, another gift.
                        Thanks for the gift. I think i will use it into an haunting hill project, someday ๐Ÿ‘ฟ
                        http://farm5.static.flickr.com/4086/5187816640_da909050bf_o.jpg
                        Walking dead 35 por artysmedia, en Flickr
                        Blog: Artysmedia
                          artysmedia
                          One more step
                          http://farm5.static.flickr.com/4124/5187217537_f0535bde0a_o.jpg
                          Walking dead 36 por artysmedia, en Flickr
                          Blog: Artysmedia
                            michaliszissiou
                            Someday SU team should fix this halo effect around pngs. I never understood how this is happening. Nice scene astysmedia. ๐Ÿ‘
                              artysmedia
                              Thanks, michaliszissiou! I will fix it in Photoshop
                              Here you have more crypts, headstones and the fence
                              I left an opening on the right side of the fence so that zombies can come out... ๐Ÿ’š
                              http://farm5.static.flickr.com/4129/5187217805_b59fd170bd_o.jpg
                              Walking dead 37 por artysmedia, en Flickr
                              Blog: Artysmedia
                                artysmedia
                                http://farm5.static.flickr.com/4107/5187817500_01e5693243_o.jpg
                                Walking dead 38 por artysmedia, en Flickr
                                Blog: Artysmedia
                                  michaliszissiou
                                  My tree brought you some trouble, sorry, here a link to download 4 pngs without antialiasing, true cut outs. And you may use all of theme as its the same 3d tree from different angles
                                  Great updates astysmedia!!!
                                  http://www.mediafire.com/file/m6386m5942qhfxi/Archive.zip
                                  • 2 / 2
