    Walking dead
    30 Posts 5 Posters 15.5k Views 5 Watching
    • artysmediaA Offline
      artysmedia
      @michaliszissiou said:
      Excellent work ๐Ÿ‘
      And a gift here.
      Thanks for the comments and the file but i dont have SU8 (dont needed) so i cant open it
      I will continue to use SU7 perhaps until SU10 appears ๐Ÿ’š
      Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
      Blog: Artysmedia
      • ely862meE Offline
        ely862me
        Nice work over here ,well done.
        Attached is the gift in v7 format.Nice gift btw.
        I have v6 v7 and v8 installed but i mostly use v6 ;seems the best for me.
        Take care!
        t1.skp
        Elisei (sketchupper)
        Come and See EliseiDesign
          artysmedia
          Take care!
          ๐Ÿ˜ฎ Thanks . Great gift!
          http://farm2.static.flickr.com/1006/5182431886_8b5c36660c_o.jpg
          Walking dead 32 por artysmedia, en Flickr
          Blog: Artysmedia
            artysmedia
            Here you have the mosaic on 3d Warehouse
            Mosaic 01
            Blog: Artysmedia
            • michaliszissiouM Offline
              michaliszissiou
              Glad you like it. A zbrush (10 min) and decimatorMaster result. You may edit the UV texture in Ps as its almost projected.
                artysmedia
                i think i have to try ZBrush... ๐Ÿ˜†
                http://farm5.static.flickr.com/4147/5181354670_6d5366f3a7_o.jpg
                Walking dead 29 por artysmedia, en Flickr
                http://farm2.static.flickr.com/1402/5181354796_0213202971_o.jpg
                Walking dead 30 por artysmedia, en Flickr
                http://farm2.static.flickr.com/1266/5180755357_c648db98b2_o.jpg
                Walking dead 31 por artysmedia, en Flickr
                Blog: Artysmedia
                  artysmedia
                  He remodeled the roof of a church that i had made some time before.
                  By the way I've changed some parts of the design.
                  http://farm2.static.flickr.com/1001/5184390800_1f910a9cf9_o.jpg
                  Walking dead 33 por artysmedia, en Flickr
                  Blog: Artysmedia
                    michaliszissiou
                    Better not, its too expensive. For your needs here, blender, or 3DCoat (this last one became the leader to all these apps)
                    Now, how did you modeled this fine paving thing? Using push-pull tool? If yes, then can you realize how many faces are there? The VG industry bakes normal maps for this. You can still export a obj mesh to 3DCoat or other app and bake a normal map to a single face. The use of a displacement map is not good as it forces the renderer to do the subdivision, too many faces again.
                    Excellent work, once again. Great thread. ๐Ÿ‘
                      artysmedia
                      Before, I used displacement maps but I'm not worth the time it takes to render.
                      Although i have to work more, I prefer to model everything; is more relaxing.
                      I have to try someday normal maps. For now ...
                      Blog: Artysmedia
                        artysmedia
                        A general view with some trees far away
                        http://farm5.static.flickr.com/4125/5187816400_61fe29ecee_o.jpg
                        Walking dead 34 por artysmedia, en Flickr
                        Blog: Artysmedia
                          michaliszissiou
                          OK, another gift.
                          Obviously, I like the whole concept and your work here.
                            artysmedia
                            OK, another gift.
                            Thanks for the gift. I think i will use it into an haunting hill project, someday ๐Ÿ‘ฟ
                            http://farm5.static.flickr.com/4086/5187816640_da909050bf_o.jpg
                            Walking dead 35 por artysmedia, en Flickr
                            Blog: Artysmedia
                              artysmedia
                              One more step
                              http://farm5.static.flickr.com/4124/5187217537_f0535bde0a_o.jpg
                              Walking dead 36 por artysmedia, en Flickr
                              Blog: Artysmedia
                                michaliszissiou
                                Someday SU team should fix this halo effect around pngs. I never understood how this is happening. Nice scene astysmedia. ๐Ÿ‘
                                  artysmedia
                                  Thanks, michaliszissiou! I will fix it in Photoshop
                                  Here you have more crypts, headstones and the fence
                                  I left an opening on the right side of the fence so that zombies can come out... ๐Ÿ’š
                                  http://farm5.static.flickr.com/4129/5187217805_b59fd170bd_o.jpg
                                  Walking dead 37 por artysmedia, en Flickr
                                  Blog: Artysmedia
                                    artysmedia
                                    http://farm5.static.flickr.com/4107/5187817500_01e5693243_o.jpg
                                    Walking dead 38 por artysmedia, en Flickr
                                    Blog: Artysmedia
                                      michaliszissiou
                                      My tree brought you some trouble, sorry, here a link to download 4 pngs without antialiasing, true cut outs. And you may use all of theme as its the same 3d tree from different angles
                                      Great updates astysmedia!!!
                                      http://www.mediafire.com/file/m6386m5942qhfxi/Archive.zip
                                      • 2 / 2
