    Windows 7, Sketchup 8 and SP 3 issues
    28 Posts 12 Posters 8.4k Views 12 Watching
      CPhillips
      Well this sucks. I finally managed to find a model that would crash SU8 and not SU7. But it is crashing deep in the physics engine and I have no way to debug it.
      At least this crash is not in the Ruby differences. It may be a bug in SU8 or it maybe a bug in the physics engine. Either way I don't see how I can fix it.
      This model always crashes SU8. If it doesn't crash your SU8 could you let me know.
      su8crash.skp
        mptak
        In the immortal words of Marty Feldman....
        Could be worse.....could be raining.
        Thanks for your incredible work and passion for your invention.
        I guess I'll just need to fill real sandbags now.
          phy
          Can you pm me a file that isn't working? Since I have Win 7 and sketchup 8 and it seems to work ok.
          Tableau de comparaison de Staxyn s'agit d'un mΠ“Β©dicament uniquement sur ordonnance.
            Barack
            Well I can't send my Plugins folder, but I can tell you what plugins I am on. These might be causing my recent crashes:
            Sketchyphysics 3 RC1
            Lazyscript 1.3083
            Select at Startup
            And, of course, all of the Sketchup 8 ruby examples.
            Hope this helps,
            Barack
            I'm a Sketchup Free user, nothing else. 3DS is way too expensive, and Pro, ditto. What else do you expect?
            UPDATE: I have some blender knowledge, that is why this signature is edited.
              Barack
              It doesn't crash my system. I am now using SU8 but it works fine. Maybe you should try a virus scan.
                Mr.K.1
                Lazyscript 1.3083
                Select at Startup
                Hope this helps,
                Barack
                LazyScript shouldn't affect anything until you add the scripts to your model.
                But once added there is no guarantee, some of the features work, and some are known to report errors in SU8.
                For the time being I advise using it only with SU7, because there is where the features were developed and tested.
                  Mr.K.1
                  Works fine for me.
                  My setup is a little different tho, WinXP + SU8 + SP3X April 2
                    CPhillips
                    I have found and fixed at least one problem with SP and SU8. Turns out the bug would also crash SU7 but far less frequently. The problem was with hinges and servos that used both min/max and accel/damp without a controller field.
                    The downside to this fix is it may break older models that worked fine in SU7 but now crash SU8. I guess that is just the trade off. I'll do a bit more testing and then post a version and we will see if that fixes the instability.
                      jblively
                      This would most likely be the cause of our issues. As that is the scenario that the models that are crashing all have in common!
                      Wow, great job in determining that. Because, YES, sketchup 7 did crash sometimes...but we just attributed it to common bug splats because it didn't happen often or consistently.
                      Thanks again!!
                        astana777
                        @camokid11 said:
                        hi Joe, i think i can explain this.
                        http://sketchupusers.vacau.com/index.php?topic=115.msg1267#new
                        this topic basicly asked the same question, and the conclusion was Sketchup 8 uses a newer version of ruby which isnt liked by Sketchyphysics (all version i believe).
                        Sketchup 7 works fine on windows 7, but Sketchup 8 i havnt tried.
                        My advice, if you can, switch back to sketchup 7 to use sketchyphysics.
                        I've skp pro 8 on a windows 7 and man do I have a lot of bug when i do try 2 run a sketchy physics models 😑
                        • 2 / 2
