    Making a curved viaduct
    14 Posts 6 Posters 1.1k Views 6 Watching
    • leedeeteeL Offline
      leedeetee
      Evening chaps,
      Just wondering how you people would go about modellign a curved viaduct. A bit like this: http://lh4.ggpht.com/_62yau5-1iHo/R5uw1YYT7TI/AAAAAAAACpA/Op26Sy61m9o/s720/venice%20May06%20713.JPG
      Could i make one of the arches and then use a plug-in (component stringer?) to copy it along a curved path??
      Thanks guys.
        It depends on the curvature of the viaduct. If it is a circle segment, sure a simple radial array would do it (as the components could remain the same).
          leedeetee
          Probably not a circle to be honest. 😞
          Would it be a case of 'filling in' the gaps between the arch components bit faces.
            leedeetee
            In fact, mighn't a better way to be sonstruct the whole viaduct in one straight segment, then use Fredo's radial bend to get the angles?
              Yes, you can do that, too. If it is an irregular curve, it should be easy to model it straight from components and then bend the whole thing.
              • Chris FullmerC Offline
                Instead of component stringer, Shape Bender would be the one to use. You would just model the arch section (perfectly straight) then make as many copies of it as you need in a row, all a single component. The use shape bender to bend that straight viaduct into the curvy shape you want.
                But Fredo's radial bending also works super well. It might be just the thing in this case.
                • mitcorbM Offline
                  mitcorb
                  Unless there is something I missed in using Fredobend, I don't think you can bend accurately to a precise destination. Here is where Chris' Shape Bender might be the tool of choice.
                    leedeetee
                    Thanks for the extra input, chaps. πŸ‘
                    • bmikeB Offline
                      bmike
                      I've bent to pretty accurate locations. I set up a reference line, and always picked the same points when selecting the geometry (I had a large model and had to break it up otherwise my machine would crash). After selecting my components I would enter the same numbers into the dialog, and repeated this 6-10 times depending on the model. If I remember I had to enter 2* the angle that I wanted to bend to... to figure out the numbers I needed I did some pre-test bending of box components using my reference line, with a locked reference curve as a guide.
                      • deaneauD Offline
                        deaneau
                        like this?
                          leedeetee
                          @deaneau said:
                          like this?
                          Very similar indeed. Cheers mate. πŸ‘
                          • deaneauD Offline
                            deaneau
                            you can made this without any plugins!!!
                            @leedeetee said:
                            @deaneau said:
                            like this?
                              leedeetee
                              I've done my viaduct, but, whenever I come to either Radial bend it (fredo) or Shape Bender it (Chris) the photo textures of the arches gets totally messed up. Is there a way round this, or do I have to bite the bullet and use a generic tiled texture for the viaduct walls?
                                leedeetee
                                All done, and all the better for the experience. πŸ˜„
                                Ribblehead Viaduct.
