    Little Problem with Follow tool
    5 Posts 3 Posters 303 Views 3 Watching
    • E
      Estyl
      Hi to all,
      I'm facing a little problem with the "follow"tool, I try to make a shape following a close geometry but at the and my results presents some holes where they shouldn't be.
      because a picture worth 1000 words, please check my picture to visualize the problem.
      I have also attached the .skp file for more information.
      I thank you all for your help
      Estyl
      FollowTool_ Problem.skp
      • GaieusG
        Hi Estyl,
        I am almost certain this is some scaling issue. SU has problems with creating faces that would have as small edges as about 1 mm.
        Before you run the follow me tool, scale your model (object) up by 10 (or sometimes even 100), do the follow me then scale it back.
        • E
          Estyl
          Thank you Gaeus,that was exactly the problem. I scale it 100x and it worked
          • AnssiA
            Anssi
            I would also recommend that you don't use the default number of segments(12) when you draw small arches such as these. 6 or even less are most often quite adequate to create the right impression, and you get a much smaller number of larger faces.
            Anssi
            • GaieusG
              True, very true.
              Also, if you make such round corners often, here is a useful plugin:
              http://forums.sketchucation.com/viewtopic.php?t=10370
