    Valiarchitects - plugins
    94 Posts 42 Posters 24.1k Views 42 Watching
      chuck vali
      @tails said:
      Is it possible to create a cross gabled roof as in my attachement, using this software as when I have tried I end up with one roof higher than the other. i'm still using the free version for the time being.
      Tails,
      It looks like the slope on the one gable is different than that of the other. Is that the intent? The script can make intersecting gables, but the roof slopes must be the same for both parts of the roof. I spent some time trying to make the script capable of generating different roof portions with different slopes, but I kept ending up with a really complicated user interface. So I gave it up, assuming that I would just tell people to generate different sloped parts in separate pieces.
      Chuck
      • F Offline
        fossa
        Chuck:
        First of all great work, I will be buying all three in the near future.
        Do you plan on updating the scripts with more features, and if so how long before a new purchase would be required.
        • soloS Offline
          Chuck,
          How do I solve the gap between road and ground, I fear it may be because of SU size limitation, but when I opt out of curb and even set hieght to 0, I get gaps.
            chuck vali
            @solo said:
            Chuck,
            Solo,
            Would you mind sending me the .skp so I can try to figure out what's happening?
            Thanks,
            Chuck
              chuck vali
              @solo said:
              Chuck,
              Solo,
              Disregard my last message - I think I know what it is. Did you set the road thickness to between -1" and +1" and if so does it work when you set road thickness outside that range?
              Chuck
                tspco
                Chuck, nicely done, on the instant roof RB, I downloaded it and installed it in SU7, drew a quick model, then rendered it KT, and the roof doesn't leak (light that is). That is one problem I have had in the past, I usually can get it fixed but it cuts into my "play time".
                Thanks again for a great plug!
                SU make 2017, /Twilight Render Hobby
                Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                  chuck vali
                  @solo said:
                  Chuck,
                  It's not a SU size limitation. The road thickness must be >= 1" or <= -1", otherwise a gap will occur. If you need the road surface flush with surrounding terrain, you can generate the road at some arbitrary thickness, select the top road surface and move it down. (It has the exact same perimeter as the hole in the terrain, so it will fit).
                  Chuck
                  • soloS Offline
                    Thanks Chuck.
                    I had to select it and use move tool to get it flush. Entering 0" does not get accepted I noticed, it automatically defaults to 1/2", no problem as there is a work around.
                    • V Offline
                      vidy
                      @dtrarch said:
                      New question:
                      Does it work with SU 7.1 free
                      or just 8.0 Pro? ❓
                      kind of having the same problem here, im using su 7.1
                      please could it be checked Chuck or this plugins only for su 8?
                      thank you,
                      VD
                      still so much to learn..
                      • KrisidiousK Offline
                        Krisidious
                        I'm using it on 7.1 no issues yet. none that were not just me not configuring or setting up the plugin properly.
                        By: Kristoff Rand
                        • V Offline
                          vidy
                          hi krist,
                          probably could provide a step by step just in writing for this plugin to work or how it work, actually for the roof i have no problem, but when i try to follow solo's image to create a road, it just nothing happen..
                          thanks,
                            Krisidious
                            there are a bunch of tutorials on Chuck's site... have you seen them yet?
                            (www.valiarchitects.com)
                            By: Kristoff Rand
                              Krisidious
                              it's under each plugin where it says "learn more". at the bottom of each of those pages.
                              By: Kristoff Rand
                              • V Offline
                                vidy
                                woohoo.. never check tutorial on the sites before.. thanks krist, will look for it.
                                • Bob JamesB Offline
                                  Bob James
                                  @chuck vali said:
                                  Reply to Grim,
                                  The terrain has to be larger than the road plus the shoulder width. So I scaled up the terrain slightly to get it to work. But it made kind of a bumpy road. That's because the road precision was much tighter than the terrain spacing - which makes the road follow the coarse terrain. So in the next copy, I reduced the precision of the road by changing the "adjust number of curve segments" parameter from "3x" to "same as input" and the road was less bumpy. Try turning on hidden lines to see what I mean.
                                  As for "try before buy", all that pro does is let you make a few things wider - everything else is the same. So please see if you like it first. (And can figure out all my cryptic parameters)
                                  Chuck
                                  Thank you, Chuck. I had the same introductory problems as Grim: the attached revised skp reallymade it clear.
                                  Great tool: purchase in-work.
                                    jaxcoffee
                                    I seem to be having problems access your site. Something I should be aware of?
                                      chuck vali
                                      Hi jaxcoffee,
                                      I am not experiencing any problems, so please try again http://www.valiarchitects.com
                                      What browser are you using? We are still trying to figure out this website stuff --- the different web browsers, different languages, different operating systems... Any feedback is welcome, so we can get our interface working without glitches.
                                      Thanks,
                                      Chuck
                                        jaxcoffee
                                        @chuck vali said:
                                        Hi jaxcoffee,
                                        Thanks,
                                        Chuck
                                        I use Chrome, and the error message I was getting was a server or host error. I just don't recall what it said. Sorry, but all is well now. Thanks Great plug-in's.
                                          jaxcoffee
                                          Seem to be getting nothing but bug splats when trying to use the instant roof plugin. I'm on version 8 pro. Am I missing something here?
                                            chuck vali
                                            I don't know it this is the issue in your case, but it's very important to close the 'Outliner' window prior to running Instant Roof. If not, the script will crash.
                                            Another possible reason for a crash is when the geometry in the model is slightly off, say out-of-square by a small fraction of a degree. This can happen when geometry is imported from another cad program. Not likely if geometry is drawn in SketchUp.
                                            View this tutorial on Instant Roof http://www.valiarchitects.com/tutorials/some-simple-roofs
                                            More advance tutorials at: http://www.valiarchitects.com/sketchup_scripts/tutorials
                                            Thanks for giving the plugin a try,
                                            Chuck
                                            • 3 / 5
