    Corinthian order
    55 Posts 17 Posters 14.1k Views 17 Watching
    • ken28875K Offline
      ken28875
      Awsome, Michalis! ๐Ÿ‘ ๐Ÿ‘
      Have a nice week,
      _KN
      Follow Your Dreams.
      • I Offline
        ivanscotti
        ๐Ÿ˜ฎ In all honesty, i did not understand how you've done to model this masterpiece, but the result is truly incredible.
        Excellent work! ๐Ÿ‘
        ivan ๐Ÿ˜‰
        "With great power comes great responsibility".
        Spiderman
        my website: http://www.area63.it
          Prisoner
          Impressive level of detail ๐Ÿ‘ Great job. I'd be very interested in your SU/3dc tutorial.
            kev_N
            Lovely stuff, and blender is a good tool isnt it ๐Ÿ˜„. Spec to get 3Ds models out of the sketchup free as it reads the only free export. And i agree the internal rendering in blender is good. Try Yafaray also, seems to give some good result after looking it up, i had that before i updated to windows 7. Just have to re download it.
            Such a nice full feel to this.
            Kev
            • michaliszissiouM Offline
              michaliszissiou
              @ken28875, thanks ken. I had your modeling skills in mind when doing this. You may find interesting the su to 3dc pass.
              @ivanscotti, thank you
              @kev_N, I used normal maps heavily here. So Yafaray isn't good, is not supporting normal maps, whatever they claim. If you managed to do this please inform me. In most cases yafa produces an ugly bump from normals. Major bug.
              The Blender internal is advanced enough (particle systems etc) but not a choice for archi presentations. Non, or -recent builds- not the best GI. It has good SSS though, good for skins, portraits. And fast for animations. Real time PP via nodes -this is perfect.
              To import SU meshes to blender is easy (SU 6 only, sorry). And this is what I do, so to clean some non manifolds and double vertices if any. To convert collada 1.4 to obj of course. (SUpro has an obj exporter). Its not about blender though, its about to drop this obj to voxels room of 3DC. A new topology now and this is my point.
              @prisoner, thanks man.
              Another use of 3DC is to import the obj mesh for UVs and painting textures only.
              SU should have decent obj importer-exporter. The free version I mean.
              SU should have a loop-cut tool.
              It doesn't because is a 'triangular based' modeler only. This is the secret. (this isn't true but its the only way Su translates geometry in the end)
              • N Offline
                notareal
                @michaliszissiou said:
                I could also import the obj directly to thea but I dont have any idea how it works. ๐Ÿ˜†
                Another masterpiece! No doubt I loved to see these rendered with Thea... just be careful, once you give it a try - you might get addicted. ๐Ÿ‘ฟ For blender users there is well integrated blender exporter (with a tutorial inside the exporter distribution pack), so you don't necessarily need to do much in Thea.
                  Funny order of architectural's orders ๐Ÿ˜Ž
                  All are waiting the new tutorial! โ˜€ ๐Ÿ˜Ž
                    michaliszissiou
                    @pilou
                    Right pilou, tu avais raison.
                    @notareal
                    Addicted? always, especially in good taste.
                    BTW this blender exporter has some bugs. Easy for me to directly import obj to thea.
                    • N Offline
                      notareal
                      Sure .obj do work fine, although not as convenient as use of exporter. One important issue to keep in mind with .obj import; when you look Thea ground grid, a small cell is 1x1 meters. It helps you to keep scene in correct scale. Without a correct scale your results will not be as good as they can.
                      btw have you reported those bug's to grzybu at http://www.thearender.com/forum/viewforum.php?f=71
                      I am not much a blender user - learning bit by bit. ๐Ÿ˜ณ
                        Karlfucious
                        Are the columns you are using the ones I did? If so I am glad they are getting put to good use. Very nice work.
                          michaliszissiou
                          Oh yes, I couldn't remember, of course its yours (the capital only), corbel is may sculpt in 3dc. Columns are mine too but not big deal.
                          It looks like roman (diocletian baths- Maria degli Angeli)? The problem is that its a over 100K faces model, it also has a non friendly topology for some apps (zbrush, 3DCoat. these apps prefer waterproof meshes) Probably lot of non manifolds. Common problem. what I did? I wrapped a hi def quad mesh around and imported this last as voxels to 3dcoat. Then resculpted some details fast, not accurate. Ended as an 6K faces light mesh with nice UVs and normal map. You have done a very accurate work ๐Ÿ‘ , I was looking now the ionic capital too. I may use this too, this time some modifications for the corner capital.
                          All these aren't too accurate of course, its a background for a scene I'm working on. Thats why I didn't import them in SU again, this gonna be heavy, the object in front I mean.
                            Karlfucious
                            Feel free to use them any way you want. I was just curious how well they worked w/ 3d coat. Ive never tried it. Ive used Zbrush and Mudbox quite a bit but they do not like sketchup meshes at all. In all honesty I'm glad they are getting put to good use. It seems like typical topology (quad models) sketchup doesn't like and vise verse. My only Experience from sketchup to a sculpting app required quite a bit of retopo work for it to even work. This isn't required when you import as voxels in 3d coat?
                              michaliszissiou
                              As I already mentioned, I used a trick in this case. (wrapping)
                              I could also just retopo - skin directly in 3DC, but this will take some hour.
                              In many cases SU obj export can be imported directly to voxels -3dc. As it is translated to vox space, all su topology is a past now.
                              The problem is when you have non waterproof objects. They have to be closed. Inverted normals don't seem to be a problem. The worst of all is the non manifolds. You have to clean them (in SU) before exporting. Otherwise, I clean them in blender but its not really easier.
                              After dropped to voxels room of 3DC you can sculpt as much you like but have in mind that in end you'll need to retopo this (if UVS and low-poly mesh is needed)
                              This corinthian capital (excellent model) was really a PITA. It doesn't have holes but its too complicated and you can find your pc out of memory. Or just import it to low density vox-room and loose all details and deal with some artifacts. Not practical IMO.
                              You can simply import this capital model just for UVs and direct surface painting in 3DC though (you can't with ZBrush). You can (real time preview) paint normal maps (depth) and even displacement map.
                                kev_N
                                So in inspired by these images, fantastic, im guessing you work in this industry?
                                • N Offline
                                  notareal
                                  Very inspiring model, can't wait the final work. Here is some 10 min renders from Thea IR. Original resolution at Thea Render forum.
                                    michaliszissiou
                                    You should lower the indirect lighting. The Ao as well. Normal maps working perfectly.
                                    • N Offline
                                      notareal
                                      Perhaps I need to give this another try.
                                      • N Offline
                                        notareal
                                        How about this? Used unbiased engine of Thea this time. Relight to balance indirect light from HDR sky and dropped AO (except what been baked in textures). Render time 10 minutes.
                                          michaliszissiou
                                          A more completed scene, blender internal render. 1 min at 2000 px.
                                          Aphrodite sculpted in blender-3dcoat-zbrush. Here at 40k faces + displacement and normal maps.
                                          http://www.mediafire.com/imgbnc.php/8799a52e70dc15e2c15779c27e68f4690c848f2bbac6577d00c429ec970ae58d6g.jpg
                                            KarinaGM
                                            Where is the clap clap clap?
                                            ๐Ÿ˜ excelent (as always)
                                            **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminarรก perdiendo ambas"
                                            -Benjamรญn Franklin.**
                                            • 1 / 3
