πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
:Mixed Use: sketchup/pshop
12 Posts 10 Posters 2.2k Views 10 Watching
    marked001
    quick project I did for a local architect.. was hoping to render it, but nothing seems to support these dramatic 2 point perspectives (or is there something??)..so it was just raw sketchup, with a subtle fotosketcher overlay, and a whole bunch of line overlays..
    http://img294.imageshack.us/img294/6664/40thpinev1103110.jpg
    http://www.revision21vis.com
    instagram: revi21on
      Hi Jason,
      This is a stunning use of line overlays, i really like it.
      As for the 2pt rendering dilemma, Thea recently added this to the latest plugin exporter by Tomasz
      http://news.sketchucation.com/sketchup-thea-exporter-0-83-beta/
      At least i think this is what you could be referring to?
        marked001
        thanks, Rich... that might do it. twilight and podium both will do it, but no panning/zooming.. being able to pan would definitely help, i'll give it a try.
        instagram: revi21on
          d12dozr
          πŸ‘ Awesome work, Jason
          http://goo.gl/f7ooYh
            Pixero
            You can always render it and distort the image in Photoshop to look like 2 point perspective.
            Just remember to render a little extra space around the actual scene since the distortion will need it.
              minguinhirigue
              You could effectively use podium or twilight, peraphs render[in] wil also include it...
              But as you seem quite good with photoshop, extended lines, with good post-processing should be enought to make a beautifull and dramatic view.
              If you are missing radiosity effects, you should juste add some life and glare effect to your windows, and adjust an "artificial ambiant occlusion" with some mask...
                Daniel
                Looks great, Jason.
                My avatar is an anachronism.
                  boofredlay
                  Nice work as usual Jason. Only thing that stands out are the hot spots behind the figures on the left.
                    marked001
                    this is the kind of info i need! as no, i'm not very good with pshop.. just the basics.. so if you could elaborate or post a link to something..that would be very helpful.
                    Eric.. totally did not notice those.. happened in the last minute rush too, i think.. πŸ˜•
                    instagram: revi21on
                      sepo
                      I believe,with Thea you can pan but not zoom.
                      • N Offline
                        notareal
                        True, with SU2Thea 2p perspective with panning should work. Not sure how hard implementing zoom would be, but Tomasz knows it better.
                        Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                        • O Offline
                          olishea
                          nice jason πŸ˜„
                          oli
