    :Mixed Use: sketchup/pshop
    12 Posts 10 Posters 2.8k Views 10 Watching
    • marked001M
      marked001
      quick project I did for a local architect.. was hoping to render it, but nothing seems to support these dramatic 2 point perspectives (or is there something??)..so it was just raw sketchup, with a subtle fotosketcher overlay, and a whole bunch of line overlays..
      http://img294.imageshack.us/img294/6664/40thpinev1103110.jpg
      http://www.revision21vis.com
      instagram: revi21on
        Hi Jason,
        This is a stunning use of line overlays, i really like it.
        As for the 2pt rendering dilemma, Thea recently added this to the latest plugin exporter by Tomasz
        404 Not Found
        (news.sketchucation.com)
        At least i think this is what you could be referring to?
        • marked001M
          marked001
          thanks, Rich... that might do it. twilight and podium both will do it, but no panning/zooming.. being able to pan would definitely help, i'll give it a try.
          instagram: revi21on
            d12dozr
            πŸ‘ Awesome work, Jason
            http://goo.gl/f7ooYh
            • PixeroP
              Pixero
              You can always render it and distort the image in Photoshop to look like 2 point perspective.
              Just remember to render a little extra space around the actual scene since the distortion will need it.
                minguinhirigue
                You could effectively use podium or twilight, peraphs render[in] wil also include it...
                But as you seem quite good with photoshop, extended lines, with good post-processing should be enought to make a beautifull and dramatic view.
                If you are missing radiosity effects, you should juste add some life and glare effect to your windows, and adjust an "artificial ambiant occlusion" with some mask...
                • DanielD
                  Daniel
                  Looks great, Jason.
                  My avatar is an anachronism.
                  • boofredlayB
                    boofredlay
                    Nice work as usual Jason. Only thing that stands out are the hot spots behind the figures on the left.
                    • marked001M
                      marked001
                      this is the kind of info i need! as no, i'm not very good with pshop.. just the basics.. so if you could elaborate or post a link to something..that would be very helpful.
                      Eric.. totally did not notice those.. happened in the last minute rush too, i think.. πŸ˜•
                      instagram: revi21on
                        sepo
                        I believe,with Thea you can pan but not zoom.
                        • N
                          notareal
                          True, with SU2Thea 2p perspective with panning should work. Not sure how hard implementing zoom would be, but Tomasz knows it better.
                          • olisheaO
                            olishea
                            nice jason πŸ˜„
                            oli
