    [Plugin] Dxf_In v2.2 20110517 Dxf2Skp
    200 Posts 41 Posters 310.6k Views 41 Watching
    • honoluludesktopH Offline
      honoluludesktop
      Jim, I think I get it about bulge in polyline as "a sequence of vertexes". The dxf reader sounds like a great tool. Just an idea, but perhaps in addition to displaying the group code, you could provide a short meaning of it (probably too much work).
      In the process of material importing, I tried to convert Acad's basic colors to the ones recognized by SU. Wow, too much work for me, and there were to many approximate correlations. Then I thought of setting the RGB values in SU, but that wouldn't cover materials, so I decided to leave it in the hands of the user to make sure that the same material existed on both sides. Because I do not use ACad, I can't test the validity of that assumption, and will have to depend on feedback. Now I see this discussion, and will leave the matter to experts.
      I read that lwpolyline was implemented by ACad in version 14. So unlike my original speculation, it is not an old form of polyline, rather a newer one then polyline. To my understanding, It is a 2d, variable width, entity that supports curves between pairs of vertex. One application is as "arrow heads" at the ends of dimension line. I have yet to read an explanation why this entity was created. Perhaps because, it helps reduce the size of the drawing database, especially with those that are primarily used in "production drawings".
        honoluludesktop
        V1.5 adds layer names, and materials to faces. In addition, the initial user interface is now organized as a single options menu.
        When selecting DXF_In materials on, unless the material exists in SU, the resulting face is black. I currently have not thought of a practical way to handle that situation.
        Jim, I have been reading up on lwpolyline, and polyline entities. Thanks for your post.
          honoluludesktop
          Oops...wrong conversion values for metric scales. Corrected with v1.6. In addition to minor adjustments, "check for upgrade" is a selection from the Option menu. "Yes" to this will take you to the top of this topic, and clear the options returning SU to its previous condition.
            honoluludesktop
            V1.9 includes improved user interface, and support for faces by layers and materials. The default material colors are based on Acad's color chart of 256 colors. Unlikely to be used, but included is support for colors by SU's color name chart of 140 colors, and the current model's colors. Btw, I had to manually reverse the faces on the right side, near wing of the model.
            Energy model, scaled and support for color.
            • I Offline
              ideas_arte
              Thank you very much!!!!
                honoluludesktop
                V1.10 places a rescaled dxf model on the mouse pointer.
                Options menu
                The import file name is in the upper left. Check update take you to the top of this topic's page, and import units include metric as well as imperial scales. Import origins are placed on SU's origin, or subject to the mouse pointer. The default import is for closed polylines to faces, however this may be turned off. Dxf colors by Acad number is also the default, SU names, SU's model materials, or none may be selected.
                I think all the interface issues have been addressed. I do not intend to add other entities (perhaps only as requested).
                  honoluludesktop
                  V 1.14 includes minor interface refinements, and the "help option" to save current option selections. Below is a example of an imported 3d polymesh whose definition name is created from the name of the file.dxf.
                    jbertke
                    Honoluludesktop,
                    How do I get a copy of your DXF importer plugin? It looks like just the thing I need.
                    Thanks,
                    Jim B
                      honoluludesktop
                      It's here at the top of this topic.
                        gonedata
                        honoluludesktop
                        great work!
                        imported 3d polymesh from construction software(agtek)generated dxf
                        the terrain looks perfect...
                          lovebugjunkie
                          Thank you for this plugin, very useful.
                            honoluludesktop
                            Added Dxf_In v1.15 french translation thanks to D. Bur.
                            LES ENTITES DXF SUPPORTEES SONT:
                            1. Polylignes comme arĂȘtes connectĂ©es.
                            2. Polyligne's (fermées) comme faces sélectionnées par l'utilisateur.
                            3. LWPolylignes comme arĂȘtes connectĂ©es.
                            4. Lignes comme arĂȘtes.
                            5. Cercles comme contour d'arĂȘtes.
                            6. Arcs comme contour d'arĂȘtes.
                            7. 3dFaces comme faces.
                            8. Blocs comme groupes ou composants.
                            9. Maillage Polyligne comme arĂȘtes.
                            10. Maillage comme faces sélectionnées.
                              honoluludesktop
                              Minor update including facing circles when user option to face polylines is selected (v15), and streamlining the readability of the code (v16).
                              • H Offline
                                HHF
                                Hello Honoluludesktop...First THANK YOU..for this great plug-in..
                                my DXF when imported to SKU8 comes flat i.e. the Z height comes at zero..yet when I imported to the 7.1 version comes with the right heights..?
                                Thanks in advance for your input..
                                  honoluludesktop
                                  Can you post the dxf here? The only Dxf_In entities that default to z=0 are LWPolylines.
                                    honoluludesktop
                                    Hmmmmm..... The dxf reference has a LWPolyline code "elevation" that I had not previously taken into account. Try the attached Dxf_In, and let me know if it works or not. Don't forget to post your dxf file.
                                    my_dxf_In_v1.17.rb
                                      honoluludesktop
                                      HHF, This is the file as translated by an Acad Viewer. The viewer is v2000. I also read the dxf file, and couldn't find the kind of information used to update Dxf_In_v1.18 as part of the new file's entities. Perhaps you shouldn't explode the drawing, and just export it to Dxf as is. Which version of Acad did you use to make the dxf?Temp00.png
                                      • H Offline
                                        HHF
                                        Not exploding the file was good advice ...it came out nice, ..to answer your question the prefered sofware is Datacad (to me it is more powerful than Autocad..sorry guys!!). It can export any file to DWG and DXF format latest versions..in this instance DXF was saved to version 2002
                                        Thanks again for this wonderful Plug-In it gave me a lot of possiblities...please enjoy your holidays!!
                                        • H Offline
                                          HHF
                                          I tried v1.17..it did not work either..I am also attaching the DXF ..look forward for your comments...Thanks,
                                          • H Offline
                                            HHF
                                            Aloha!..it worked ! ..however I tried a more complex file and it did not come out right (picture #2) I exploded every line before converting to DXF and may have missed something in the midst... I am attaching the the new DXF for your review..
                                            Thank you again for all your input..Happy Holidays..
                                            • 2 / 10
