    [Plugin] Dxf_In v2.2 20110517 Dxf2Skp
    200 Posts 41 Posters 323.1k Views 41 Watching
    • honoluludesktopH
      honoluludesktop
      Except for polyface mesh, Dxf_in v1.0 imports the basic geometric entities recognized by SU.
      Dxf polyline mesh import.
      • DavidBoulderD
        DavidBoulder
        Looks great! I ran it through a test with some DXF's created by EnergyPlus (as part of an energy simulation run).
        What I noticed is that using your plugin the DXF came in 12x smaller. In the Pro I have units set to feet vs. inches, which works with these DXF's. Easy enough for the user to fix but could be nice option to add down the road. One other thing I noticed is that on your DXF import a few faces were reversed from how there were with the pro importer. The pro importer was not set to "orient faces consistently" but maybe it was doing it anyway, and the source file really does have some reversed faces.
        Other features that would be nice, but aren't critical, are to support the layer and color applied to a face.
        DXF_In 1.1 and pro side by side.
        David Goldwasser
        OpenStudio Developer
        National Renewable Energy Laboratory
        • honoluludesktopH
          honoluludesktop
          David, Thanks. Can you provide a sample dxf (smaller the easier for me) with layer and texture? Perhaps I should provide a options menu.
          • DavidBoulderD
            DavidBoulder
            Sure, here is a 50k file from the example above. Now this was made from EnergyPlus, so it may not be the best test case since it wasn't generated by AutoCad. I'm not sure if a similar file from Autocad would like the same or not.
            This file has layers and color (not image textures)
            (hmm, can I not upload DXF file?)
            David Goldwasser
              Jim
              you can download lot's of dxf files from here (my google site.) The .zip contains an un-attributed compilation of shared .dxf files designed as 2D cnc routing patterns. (17MB)
              I'm wondering, do you know how to handle the bulge data when it appears in the lwpolylines? It's something I'd like to add to my importer, too.
              • GaieusG
                I made dxf (and dwg) an attachable file extension
                • honoluludesktopH
                  honoluludesktop
                  Jim, Thanks, I will take a look at your files. Is lwpolyline something that is required by a lot of modern applications? I found the following, but bulge remains unimplemented with my importer:
                  "The bulge is the tangent of 1/4 of the included angle for the arc between the selected vertex and the next vertex in the polyline's vertex list. A negative bulge value indicates that the arc goes clockwise from the selected vertex to the next vertex. A bulge of 0 indicates a straight segment, and a bulge of 1 is a semicircle."
                  DXF is on the other side of the moon when compared with SUs faces, and edges. I initially made Dxf_In work for my own Cad application, then added features as others have requested. Initially, by self imposed discipline, all of my cad models were built with 3d faces, and blocks. My Cad2Dxf2Su requirements were simple. But times change, and while my code is fairly well organized to implement new entities, it needs work on the overall DXF structure. Something I ignored since I was only interested in geometry.
                  Gai, Great. Perhaps, like a lot of others, I only learned how to "send to zip" once I needed to do it.
                  • honoluludesktopH
                    honoluludesktop
                    Just change the file.extension name to .txt, or right click, sent to .zip first. Thanks
                    Addenda: See post by Gai below.
                    • DavidBoulderD
                      DavidBoulder
                      Here is the attachment. Thanks for the tips. I left the file at work, so couldn't send last night. Sounds like we can do dxf's now.
                      GeometryTest.dxf
                      David Goldwasser
                        Jim
                        Looking at the Blender dxf importer (written in Python) and found these dxf test files in the Downloads section:
                        http://wiki.blender.org/index.php/Extensions:2.4/Py/Scripts/Import/DXF-3D
                        • honoluludesktopH
                          honoluludesktop
                          V1.2 provides the option to select input units, and location (thanks to_tt). Not being familiar with metric conversion, I did not check their accuracy.
                          Model built converting feet to inchesBtw: In regards to lwpolylines, when I wrote this translator, I found that the dxf example I used contained occasional differences in the actual number of vertices's, and the number provided by the dxf. So, I ended up writing a procedure that did not depend on the stated number. I am not sure if this is a misunderstanding on my part or a bug in the program that created the dxf.
                          • honoluludesktopH
                            honoluludesktop
                            Sigh...As soon as you think you got it, there is something to change, hence v1.1. Functionally no different, but with better error messages. Unless I find a bug, or figure how to add a polyface mesh, this should be it:-) Attached are some test with old.dxf models.
                            A first draft Cad.Dxf model brought into SU for visualization.
                            Another first draft Cad.Dxf detail originally imported for study.
                            The model's groups are based on common materials, textures, or colors. This makes it is easy to update the SU model's textures of any Cad based revision. The groups/blocks are sent both ways so that the production drawings are easily revised based on changes to the model.
                              Jim
                              I can't find the reference now, but I understood it to say something similar to "polylines that can be converted to lwpolylines, are converted into lwpolylines in order to save space."
                              I have a routine to handle the bulge data for regular polylines, but the lwpolylines are different enough that I haven't been able to decipher them consistently.
                              I found a dwg/dxf converter for Windows that may be of interest. It converts between dwg and dxf, but also from dxf to dxf and you can choose several versions of the file format. So maybe it will be useful for converting tricky dxf files into older formats which your importer is more tolerant of.
                              The converter is here, under the name ODA Teigha File Converter.
                              http://www.opendesign.com/guestfiles
                              • honoluludesktopH
                                honoluludesktop
                                Jim, I am using Dxf Reference, ACAD 2010 and am not able to identify bulge data within dxf polyline.
                                The group code for bulge in lwpolyline "42", is absent in the 2010 reference for polyline unless it is part of "70" and some other group code. I don't look forward to figuring out how to including it in Dxf_In.
                                Incidentally, Dxf_In doesn't check for version number, and will attempt to process any File.Dxf, even one that is manually, incorrectly edited, and rejected by Import SU Pro. It has succeed for the implemented entities, except when the group code is written out of order. I noticed that import SU Pro V7 refused to translate a 2010 Dxf file.
                                • honoluludesktopH
                                  honoluludesktop
                                  Hi Jim, Thanks, I have used that open source translator from time to time, especially with a cad.dxf that needed to be accessed by older programs. It has a difficult interface requiring two folders, one for the file and the other for the export. As I recall (perhaps erroneously) it did not allow you to select specific files for translation, and processed the entire folder.
                                  When Dxf_In detects a lwpolyline, it process it as a SU "continuous edge" by assuming z=0.0. I am not sure if that's what's intended for that entity type, but have successfully translated the examples I had access to at that time.
                                  There were other anomalies I noticed in comparing Dxf_In to SU Pro imports. The windows in the energy model above, imported with SU Pro, are faces in the same plane as the wall (surface) they are on. Hence the problem displaying its color. For some reason, Dxf_In corrects this by drawing the window as a faced hole in the wall. However, Dxf_In draws some of the energy models faces, back side out, where SU Pro draws them properly. I speculated that the cause of this maybe in part, the order that the faces are drawn. Dxf_In, processes the Cad.dxf in the order the entities are listed. Perhaps SU Pro pre-processes the entities before drawing them. Btw, I hadn't realized that polylines have "bulge". Although I haven't encounter any that did, I guess I need to look at that entity attribute. Is my post above regarding bulge calculation correct to your understanding? Also puzzling to me were the entities in some dxf files that by the manner of their identification in the file, are not drawn. If file size is a consideration, I wondered why these were included in the dxf file.
                                    Jim
                                    It's the POLYLINE's VERTEX that may or may not have a bulge attribute. POLYLINE's are implemented as a sequence of VERTEX's, ending with a SEQEND code. LWPOLYLINE's can have multiple vertex and bulge data but these are stored in the object itself as multiple 10, 20, and 42 codes.
                                    I am in the process of separating out the dxf reader part of my importer to be more generally useful. It reads a dxf and converts it into a Ruby data structure of Arrays and Hashes. This will allow access to the sections and entities much easier.
                                    Header variables:
                                    dxf = DxfReader.load("c:\drawing.dxf") acad_version = dxf['HEADER']['$ACADVER']
                                    Iterating ENTITIES:
                                    dxf['ENTITIES'].each do |entitiy| process_entity(entity) end
                                    Viewing a specific, or entities by type:
                                    all_lwpolylines = dxf['ENTITIES'].select{|e| e[0] == 'LWPOLYLINE'}
                                    In addition, you can "pretty print" the dxf allowing for easier analysis, such as this image of the representation of a LWPOLYLINE as a Ruby data structure.
                                    You can see the lwpolyline has 8 vertices (code 90), but only 4 of those bulge data (code 42). I know how to create an arc from 2 verts and a bulge, but I don't know how to apply that formula to this particular lwpolyline.
                                    But with the DxfReader, you can pick out and try to create this one particular entity for debugging:
                                    lwpoly = dxf['ENTITIES'].select{|entity| entity[5]=="477"}.first x_values = lwpoly[10] y_values = lwpoly[20] bulge_data = lwpoly[42] nverts = lwpoly[90] for i in 0..nverts-1 pt = Geom::Point3d.new(x_values[i], y_values[i]) entities.add_cpoint(pt) end
                                    (etc.)
                                    I will try to clean-up and post the reader this week.
                                    • honoluludesktopH
                                      honoluludesktop
                                      Jim, I think I get it about bulge in polyline as "a sequence of vertexes". The dxf reader sounds like a great tool. Just an idea, but perhaps in addition to displaying the group code, you could provide a short meaning of it (probably too much work).
                                      In the process of material importing, I tried to convert Acad's basic colors to the ones recognized by SU. Wow, too much work for me, and there were to many approximate correlations. Then I thought of setting the RGB values in SU, but that wouldn't cover materials, so I decided to leave it in the hands of the user to make sure that the same material existed on both sides. Because I do not use ACad, I can't test the validity of that assumption, and will have to depend on feedback. Now I see this discussion, and will leave the matter to experts.
                                      I read that lwpolyline was implemented by ACad in version 14. So unlike my original speculation, it is not an old form of polyline, rather a newer one then polyline. To my understanding, It is a 2d, variable width, entity that supports curves between pairs of vertex. One application is as "arrow heads" at the ends of dimension line. I have yet to read an explanation why this entity was created. Perhaps because, it helps reduce the size of the drawing database, especially with those that are primarily used in "production drawings".
                                      • honoluludesktopH
                                        honoluludesktop
                                        V1.5 adds layer names, and materials to faces. In addition, the initial user interface is now organized as a single options menu.
                                        When selecting DXF_In materials on, unless the material exists in SU, the resulting face is black. I currently have not thought of a practical way to handle that situation.
                                        Jim, I have been reading up on lwpolyline, and polyline entities. Thanks for your post.
                                        • honoluludesktopH
                                          honoluludesktop
                                          Oops...wrong conversion values for metric scales. Corrected with v1.6. In addition to minor adjustments, "check for upgrade" is a selection from the Option menu. "Yes" to this will take you to the top of this topic, and clear the options returning SU to its previous condition.
                                          • honoluludesktopH
                                            honoluludesktop
                                            V1.9 includes improved user interface, and support for faces by layers and materials. The default material colors are based on Acad's color chart of 256 colors. Unlikely to be used, but included is support for colors by SU's color name chart of 140 colors, and the current model's colors. Btw, I had to manually reverse the faces on the right side, near wing of the model.
                                            Energy model, scaled and support for color.
                                            • 2 / 10
