    Simulate a Wood Carving?
    29 Posts 8 Posters 5.5k Views 8 Watching
    • soloS Offline
      Lower than 1mb
      carving1.skp
        Thanks Pete. I haven't had time to do anything to show here so I'm glad you did.
        • charly2008C Offline
          charly2008
          Hi Pete,
          I have reduced the polygons with Cinema 4D by 50%. But the quality seems worse than in your model. The size is still 1.81 MB. The method that you have achieved it? Or is it your secret?
          Charly
            Charly, I've been extremely busy at my day job doing some upgrades to our 70 anesthesia machines so I haven't even had time to open Pete's file to compare it to the way I managed to get the file size down. The way I did it, however was to split the carving in half along its line of symmetry. Then I deleted one half. There was a lot of excess geometry I could delete as well. My version doesn't have a back surface. These things are designed to be applied to another surface so the back isn't needed. Getting rid of it eliminated a large number of edges and faces. Once the half was cleaned up, I made it a component, copied it and flipped the copy. The seam line was then hidden so it looks like one piece.
              charly2008
              Hi to All,
              I have again a question to all SketchUp users. If you keep selecting the back of a high polygon model is always a lot to be polygons that are not included. And this has to be erased manually. Is there a trick to select all parts below the surface?
              Charly
                charly2008
                Sorry Dave,
                It was not my intention to discourage you from important work. I also expect to a question no lightning-like response. I am happy if I get some time for a response. I know that there are more important things than Sketchup. I now have a bit more time, since I'm retired.
                Charly
                • jason_marantoJ Offline
                  jason_maranto
                  Turn off perspective then pick one of the standard views and use a left-to-right bounding box selection technique.
                  Best,
                  Jason.
                    charly2008
                    Hi Jason,
                    thanks for your tip. But I still can not catch all the polygons.
                    Charly
                      Charly, I would intersect a surface with the shape at the point where I want to cut it, as it appears you have. Then I would set up the standard view and parallel projection. A right to left selection box made so it just misses the cutting plane should select most if not all of the stuff you want to get rid of. Look closely for any remaining edges and delete those either manually or zoom in closer and make additional selections.
                      By the way, no worries about me putting off more important work. I only respond here on the forum when I do have time. I'm glad to actually have that time now, though.
                      • soloS Offline
                        Intersect is easier.
                        http://img829.imageshack.us/img829/6093/capture30.gif
                        • soloS Offline
                          Even smaller now.
                          carving1edit.skp
                            jason_maranto
                            Yeah I got the right to left thing mixed up 😳 -- I have a hard time with right and left, when somebody asks directions I always use east, west, north, and south... which drives my wife nuts.
                            I think it's a byproduct of being semi-ambidextrous.
                            Solid tools are the fastest, but I assumed you didn't have those.
                            Best,
                            Jason.
                              No worries, Jason.
                              You're right about the Solid tools although with something like this applique piece, there's a good chance you'd spend a lot of time cleaning it up just to make it show as a solid group/component.
                              • soloS Offline
                                Solid tools are the fastest but a model that is not solid will not work, so going back to the old intersect method works.
                                • 2 / 2
