    Solid Tools - subtract
    11 Posts 8 Posters 4.9k Views 8 Watching
      Doogen
      Is there a script that allows one using the subtract tool without deleting the first part?
      As it is now, I have to make a copy of the 1st solid, place it in a nearby spot, do the subtraction and then place the copy back to the original place...
      /Jonas
      • H Offline
        Howard leslie
        Jonas,
        It sounds like Subtract works a bit like Bool Tools plugin.
        Try...
        Copy
        <Perform Subtract Operation>
        then PASTE IN PLACE (as opposed to Paste) - Original geometry restored to EXACT position
        To speed things up a bit more Define "Copy", by default <Ctrl> + C and "Paste in Place" on Quick Short Cut Key Strokes
        (Window - Preferences - Short Cuts)
        Hope this Helps
        Howard L'
        • gillesG Offline
          gilles
          you could try this, with SU8 free or pro only
          http://forums.sketchucation.com/viewtopic.php?p=112055#p112055
            jhauswirth
            I think you need to use trim instead of subtract.
              Doogen
              Well, what can I say...
              Trim was the one I was looking for. It sat there all the time, just in front of my nose. 😳
              Thanx.
              /Jonas
                Although Trim is what you want, you may find this useful sometimes. Select the first component (the one you would place the copy of off to the side) and choose Copy (Ctrl+C, Edit>Copy, etc.) Perform the operation as needed. Now click Edit>Paste in place et Voilà! All done.
                • O Offline
                  okthierry
                  I am having a similar problem. Each time I subtract (tried different plug-ins as well) my main object is damage and prevent further subtractions. Anyone has a trick of how to subtract a grid of cylinders on a cube? I am trying to produce roundish pyramids.
                  Here are the files:
                  https://dl.dropboxusercontent.com/u/2637056/half-pipe-pattern2.skp
                  https://dl.dropboxusercontent.com/u/2637056/1.png
                  https://dl.dropboxusercontent.com/u/2637056/2.png
                  Thank you in advance!
                    I don't have access to SketchUp at the moment so this is a guess. Try scaling the model up by a factor of 100 before executing the Subtract operation. From your screen shots it would appear there are some tiny gaps due to faces not forming. This is a well know issue when working at small dimensions.
                    • BoxB Offline
                      Dave nailed it, scale up by ten and it works fine.
                        abhininja
                        its not working in 2016
                        • BoxB Offline
                          That plugin has been abandoned and hasn't worked for several versions.
