    SketchyPhysics3.1
    85 Posts 37 Posters 87.7k Views 37 Watching
      jblively
      @cphillips said:
      Ah, i forgot about the motor joint. Ill fix in next version.
      Thanks! Thought I was going a little crazy!
        reddoor
        Just having a little trouble loading this new version on Sketchup 8 Macintosh 10.5.8
        I get this error on startup:
        Error Loading File sketchyphysics.rb
        dlopen(/Library/Application Support/Google SketchUp 8/SketchUp/plugins/SketchyPhysics3/sdl/SDL.dylib, 9): no suitable image found. Did find:
        /Library/Application Support/Google SketchUp 8/SketchUp/plugins/SketchyPhysics3/sdl/SDL.dylib: unknown required load command 0x80000022
        Any suggestions?
          shareck
          Hi. Can somebody tell me how to use the camera function? is it possible to achieve the same thing as with the lazy script where you have a box with a camera "attached" to its centre?
          • W
            willeykj
            @reddoor said:
            Any suggestions?
            I'm the developer of the Mac Port of SP3. Are you running on a Mac or a Hackintosh? Which CPU (has to be INTEL).
            This may be a case of the build being unique to 10.6 but I'm trying to dig in.
            Kevin
            • W
              willeykj
              @willeykj said:
              @reddoor said:
              Any suggestions?
              Kevin
              Just got done working with Chris.
              The Mac port requires shared libraries for SDL to work just like the PC version.
              The libraries I generated for Chris last week had unintended linkages to a version of SDL I had installed on my machine.
              Therefore, if you didn't have SDL installed the libraries in the SketchyPhysics directory didn't work which was the cause of Reddoor's error.
              SP 3.1 uses the standard SDL library as well as the SDL_mixer extension for audio. On the PC these are 2 separate shared libraries. On the Mac, it didn't seem to make sense to have SDL_mixer statically linked to the complete SDL library if the SDL shared library was going to be needed anyway. All complicated by the fact that the SP3.1 plugin folder isn't a library load directory. SOOOO.....
              I've compiled a new "SDL_Special.dylib" which has the necessary object code from SDL and SDL_mixer merged. This file is undergoing testing as I type and everything looks good so far. I hope to deliver to Chris later tonight and we'll get past this hiccup with the Mac version
              Thanks for your patience.
              Kevin
              • C
                CPhillips
                I have the updated Mac files now and will release a new version in a few days.
                Thanks Kevin!!
                  reddoor
                  Thanks Guys for all your hard work on the code. We Mac users really appreciate it!
                  All my students thank you also.
                  Reddoor
                  Hong Kong
                  • H
                    hpnisse
                    Hello CPhilips! (or someone else).
                    How can I use Velocity & Torque in sketchyphysics 3.1?
                    Is it something with, get the speed of a physics joint (hinge/motor for example)?
                    Some examples or something will be appreciate.
                    Its from this website that you named in this post I find it, but no instructions how to use them.
                    http://code.google.com/p/sketchyphysics/wiki/ScriptFunctions
                    /hpnisse
                    ** %(#BF0000)[/hpnisse]**
                    %(#000000)[Windows 7 U] %(#000000)[-]%(#408000)[Sketchup 8] %(#000000)[-]%(#4000FF)[SketchyPhysics 3.2-Dec2] - from Sweden
                    • C
                      CPhillips
                      setVelocity takes a vector that is the direction the object will be moving and the length of the vector is how fast. It is different from push because it actually sets the objects velocity rather than just try to push it.
                      setTorque does the same thing with the objects rotation.
                      I updated the script page on the wiki.
                      Example attached
                      SetVelAndTorqueExample.skp
                      • H
                        hpnisse
                        Hey!
                        Thanks for fast answer, is it possible to "getTorque/velocity" to know if something is moving in any direction.
                        And get the speed of an object, if I will do a speed/RPM -meter?
                        /hpnisse
                          reddoor
                          Just wondering if there was any news about the updated, "fixed", mac version?
                          I was looking around and I didn't see any new files
                          • W
                            Wacov
                            @reddoor said:
                            Try:
                            http://forums.sketchucation.com/viewtopic.php?f=61&t=32200&p=284163#p284163
                            • C
                              CPhillips
                              Yeah 3.2 should work on Mac. I'll do a zip file for it tonight.
                                ROVAP
                                Am I being stupid but could someone put a link directly to the latest MAC version of SP 3.1 or 3.2 what ever is latest. I often read the forums and see Mac version coming then the next posts are of people trying to get Mac version to work. However I never see the link or if there is one it takes you to a PC exe file.
                                Thanks in advance. 😲
                                  solodown
                                  dlopen(/Library/Application Support/Google SketchUp 7/SketchUp/plugins/SketchyPhysics3/sdl/SDL.dylib, 9): no suitable image found. Did find:
                                  /Library/Application Support/Google SketchUp 7/SketchUp/plugins/SketchyPhysics3/sdl/SDL.dylib: unknown required load command 0x80000022
                                  • C
                                    cljohnston108
                                    Good question. I tried downloading SketchyPhysics3RC1-MacAndWin-Fixed.zip off the Wiki front page, but the newest files in there are dated March 26, 2009, so I figured that can't be right.
                                    • C
                                      CPhillips
                                      Sorry for the late reply. Mac will be supported in the next version. It was supposed to be out last week but I found some problems and havent had a chance to fix them. It should be in a few days.
                                      • C
                                        cljohnston108
                                        Coolness! Looking forward to it!
                                          Davidfi1
                                          Guys
                                          Could you please "STICK" this final version on the top of the forum?
                                          Thank you all very much.
                                          Good work!
                                          David.
                                            arjunmax09
                                            where can i get tutorial for sketchyphysics...maybe a pdf file...??
                                            when you fail at something....you haven't really failed...you've found one way the thing will not work out
                                            • 2 / 5
