    SketchyPhysics3.1
    85 Posts 37 Posters 78.9k Views 37 Watching
      reddoor
      Thanks Guys for all your hard work on the code. We Mac users really appreciate it!
      All my students thank you also.
      Reddoor
      Hong Kong
      • H Offline
        hpnisse
        Hello CPhilips! (or someone else).
        How can I use Velocity & Torque in sketchyphysics 3.1?
        Is it something with, get the speed of a physics joint (hinge/motor for example)?
        Some examples or something will be appreciate.
        Its from this website that you named in this post I find it, but no instructions how to use them.
        http://code.google.com/p/sketchyphysics/wiki/ScriptFunctions
        /hpnisse
        ` /hpnisse`
        ` Windows 7 U -Sketchup 8 -SketchyPhysics 3.2-Dec2 - from Sweden`
          CPhillips
          setVelocity takes a vector that is the direction the object will be moving and the length of the vector is how fast. It is different from push because it actually sets the objects velocity rather than just try to push it.
          setTorque does the same thing with the objects rotation.
          I updated the script page on the wiki.
          Example attached
          SetVelAndTorqueExample.skp
          • H Offline
            hpnisse
            Hey!
            Thanks for fast answer, is it possible to "getTorque/velocity" to know if something is moving in any direction.
            And get the speed of an object, if I will do a speed/RPM -meter?
            /hpnisse
            ` /hpnisse`
              reddoor
              Just wondering if there was any news about the updated, "fixed", mac version?
              I was looking around and I didn't see any new files
              • W Offline
                Wacov
                @reddoor said:
                Try:
                http://forums.sketchucation.com/viewtopic.php?f=61&t=32200&p=284163#p284163
                  CPhillips
                  Yeah 3.2 should work on Mac. I'll do a zip file for it tonight.
                    ROVAP
                    Am I being stupid but could someone put a link directly to the latest MAC version of SP 3.1 or 3.2 what ever is latest. I often read the forums and see Mac version coming then the next posts are of people trying to get Mac version to work. However I never see the link or if there is one it takes you to a PC exe file.
                    Thanks in advance. 😲
                      solodown
                      Error Loading File sketchyphysics.rb
                      dlopen(/Library/Application Support/Google SketchUp 7/SketchUp/plugins/SketchyPhysics3/sdl/SDL.dylib, 9): no suitable image found. Did find:
                      /Library/Application Support/Google SketchUp 7/SketchUp/plugins/SketchyPhysics3/sdl/SDL.dylib: unknown required load command 0x80000022
                        cljohnston108
                        Good question. I tried downloading SketchyPhysics3RC1-MacAndWin-Fixed.zip off the Wiki front page, but the newest files in there are dated March 26, 2009, so I figured that can't be right.
                          CPhillips
                          Sorry for the late reply. Mac will be supported in the next version. It was supposed to be out last week but I found some problems and havent had a chance to fix them. It should be in a few days.
                            cljohnston108
                            Coolness! Looking forward to it!
                              Davidfi1
                              Guys
                              Could you please "STICK" this final version on the top of the forum?
                              Thank you all very much.
                              Good work!
                              David.
                                arjunmax09
                                where can i get tutorial for sketchyphysics...maybe a pdf file...??
                                when you fail at something....you haven't really failed...you've found one way the thing will not work out
                                  cljohnston108
                                  Any progress?
                                    dorritos
                                    @cljohnston108 said:
                                    Any progress?
                                    How 'bout now? 😄
                                      CPhillips
                                      Sorry, I know I am late with the new version. I have been real busy.
                                      I'll work on this week but no promises.
                                        loolytoo
                                        I downloaded the newest version of sketchy physics and installed it. I have sketchup pro 8. When sketch up starts i get the following message
                                        undefined method extend_object' for Singleton'
                                        then when i try to download and use a sketchy physics model from wharehouse, they dont work and i get the following message.
                                        Error starting the simulation:uninitialized constant. msketchyphysics 3::SP3xSimulationContext::SP Sounds C:/PROGRA~1/google/GOOGLE~3/plugins/sketchyphysics3/controller commands. Rb:777:in 'initialize'
                                        can anyone help me with how i sort this out?
                                        Lucy
                                          CPhillips
                                          I have never seen that error before. Best guess something went wrong with the new Midi sound support. What version of windows are you using? Do you have any thing unusual about your sound setup?
                                            andy1347
                                            I get the exact same error as Loolytoo above. The only apparent difference is I am using Windows 7 Pro 64 bit and SU7. I have tried reinstalling SketchyPhysics. When I run a sample model, the Ruby console shows this;
                                            Checking if dueForUpdate
                                            String doesn't compile: uninitialized constant MSketchyPhysics3::SP3xSimulationContext::SPSounds#<NameError: uninitialized constant MSketchyPhysics3::SP3xSimulationContext::SPSounds>
                                            C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SketchyPhysics3/ControllerCommands.rb:777:in initialize' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SketchyPhysics3/sketchyphysicstool.rb:727:in new'
                                            C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SketchyPhysics3/sketchyphysicstool.rb:727:in initialize' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1623:in new'
                                            C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1623:in startphysics' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1650:in physicsTogglePlay'
                                            C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1738
                                            C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1737:in `call'
                                            C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SKMtools/image_class.rb:946
                                            Had I made this model myself, I would say it is operator error, but that is not the case.
                                            Could someone shed some light on how to either solve this or work around it so I could try my hand at using this plug-in?
                                            Thanks,
                                            Andy
                                            • 3 / 5
