    The new Render[In] plugin
    51 Posts 29 Posters 10.3k Views 29 Watching
    • I
      ivanscotti
      Hi guys,
      I downloaded Render[in] four days ago and immediately started to use it to finish a work in progress.
      In my opinion it is a very good rendering engine. It's fast and the images are of good quality.
      Obviously there are some things to fix, as you said, but it is still a beta version.
      I enclose below a couple of pictures I made with the engine in question.
      The model was fairly complex and large (approx. 20 MB), and the size of the render is 2900x2000 pixels. Rendering time about 30 minutes with a iMac 3.06 GHz Duo 4 Gb RAM
      ciao 😉
      Ivan
      "With great power comes great responsibility".
      Spiderman
      my website: http://www.area63.it
      • Mike LuceyM
        Mike Lucey
        I've got some details on pricing. Stephene Desmuile has advise the following,
        **Hi all SketchUp users !!
        We understand that the selling price is an important criteria for your choice.
        But the Render[in] price is not defined yet...
        but we can give you an indication... it will not exceed $200**
        Seems reasonable enough to me!
        Mike
        • E
          Ecuadorian
          Ivanscotti, those are excellent images for sales brochures from my point of view. Building companies are often not too worried about absolute realism, but rather about making things look attractive, dreamy, Utopian.
          -Miguel Lescano
          • I
            ivanscotti
            You're right, these images were actually designed with exactly this purpose.
            However I think we can achieve much better results about realism even than this, with this engine.
            Keep in mind that these are only the first testing and that this is a beta version, with many small problems to solve. 😉
            Spiderman
              Ross Macintosh
              Render[In] has released a new Beta today with improvements asked for in the forum.
              Release summary:
              Get view size - Now you can automatically get the SketchUp Window size in the Render[in] parameters.
              Stop Rendering - You can now stop the rendering anytime.
              Smoothing geometry - No more problems with smoothing!
              QuickTime - We need QuickTime for several reasons with Render[in]; now we check at startup that QuickTime is installed.
              Create light - The issues concerning complex geometry creating light have been corrected.
              Memory leaks - We have corrected some memory leaks, we keep checking.
              Regards, Ross
              • L
                Lee-Enfield
                does anyone else have problems getting it installed or to work properly?
                i have installed it and i have Quiktime, but when i open Sketchup i dont get the request for a serial number, all that appears is a little box saying Could Not Load "Plugins\Renderin\Renderin.dll".
                any input?
                  dtrarch
                  New Beta better.
                  Faster and pretty much per ATL render quality.
                  Slick presets and just enough to do a Q&D output.
                  Works OK with SU 8 Pro.
                  Typ radiosity output and a little flat and plastic IMO.
                  While a fine artist like Ross will always get the best out of an app for my eye the KT engine (Twilight too) still wins for exterior renders.
                  Faster too (photon map + AA)
                  A couple of renders of a project model that i use to compare outputs.
                  Just for info.
                  dtr
                  RENDER[I]
                  RENDER KT
                  • E
                    ezt
                    I have installed this and when I launch it I get this error
                    It does not stop Render[in] working but I'm sure it will cause me issues.
                    I posted the problem on their forum, but so far no response.
                    Has anyone else experienced this - or know how to resolve it.
                      Do what it says... find the 'Renderin' folder inside Plugins and change its 'properties' - access rights, so you can read/write it, and its contents and sub-folders etc...
                      • E
                        ezt
                        Thanks Tig.
                        I had already checked the permissions for the Renderin folder and sub-folders, and checked again after your response - they all have at least read/write permissions for all users - hence my confusion.
                          Do you have any 'textures' in that folder ?
                          Perhaps the error is occurring because it's finding 'none' ??
                          • E
                            ezt
                            Yes - render[in] installed various files in the directory including the icons for the gui (which show in SU) and a couple of textures.
                            • 3 / 3
