    Setting file types in the savepanel
    21 Posts 8 Posters 3.3k Views 8 Watching
    • honoluludesktopH
      honoluludesktop
      Jim, Thanks. I knew about the .ext bug making _.ext, but didn't know about using it with ""|nil. So, there is no way to force the savepanel to open with .ext in a predetermined folder?
        Why (""|nil) instead if just nil ?
          Jim
          Apologies - that was just meant as a notation for either "" or nil.
            Ah, gotcha!
              Jim
              @honoluludesktop said:
              So, there is no way to force the savepanel to open with *.ext in a predetermined folder?
              Not that I know.
                Jim
                Still can't add filetypes to the "Save as type" dropdown, as far as I know.
                But you can provide a extension mask as follows:
                UI.savepanel "Title", nil, "*.rb" (can use empty String or nil for middle param)
                Note, if you try to provide a directory name (the 2nd parameter,) the file mask gets messed up - it's a bug (IMO.) The file mask asterisk will get translated into an underscore: " _.rb"
                And this might only work on Windows, I don't know.
                Also, to work around the bug it may be possible to use Dir.chdir() to set the default directory before calling savepanel. (Update: Looks like this doesn't work. Windows must store the MRU location somewhere.)
                  It's been reported before - but it doesn't hurt reminding them...
                  http://forums.sketchucation.com/viewtopic.php?f=11&t=29023
                  • W
                    WorCoder
                    Thanks for the effort, guys.
                    Sadly this doesn't really help.
                    Seems to me as more inconvenient to have to move to the desired folder every time.
                    What bugs me the most is, that one can't click save and then immediately start typing the filename, in the way that the whole line (including ".xxx")is highlighted.
                    Since there might be some not really intelligent people handling this, I would love a way for them to immediately start typing, but still have the right extension visible as well.
                    Do I have to file a bug-report to get this in or is there nothing one can do to try and get functionality of the filetype selector!?
                      If the users are so stupid why even give them the chance of saving the file in a weird folder or giving it a stupid name ?
                      Why not always locate and name the file 'with the model'.
                      First use a trap (puts "Save SKP!";return nil if model.path=="" in case your SKP is not saved.
                      You get the folder from folder=File.dirname(model.path)
                      You could then 'set' the file-name based on the model, so file=model.title+".xxx" or whatever file type suffix you want.
                      You could use the Scene name in the name too...
                      scene=model.pages.selected_page.name.gsub(/[^A-Za-z0-9_-]/,"_")
                      [The gsub is to avoid making a file name with 'illegal' characters like /:"etc]
                      Then file=model.title+"_"+scene+".xxx"
                      OR you could use a file name based on the 'date/time' which will always be different...
                      time=sprintf("%.1d\n",(Time.now.to_f*100))
                      Then file=model.title+"_"+time+".xxx"
                      Set the path=File.join(folder,file).tr("\\","/")
                      [The tr is only to tidy up if you are to display it later - e.g. in a confirming dialog - as you might get a mix of / and \ on a PC]
                      Now use the path to export, or save as a data file etc...
                      Alternatively you could let the user set the file name with a simple inputbox
                      results=inputbox(["File Name: "],[model.title],"Type in XXX File Name [WITHOUT a '.xxx' suffix]") return nil if not results file=(File.basename(results[0]).gsub(/[^A-Za-z0-9_-]/,"_"))+".xxx"
                      which traps 'stupid' input or file suffix...
                      • W
                        WorCoder
                        Thanks for those tips! I really appreciate this.
                        I see your point. Since there are pro and dumb users, the features I would love to include are:
                        • selecting your own name for the file
                        • selecting your wished folder to store into
                        • keep "uneducated" users from messing up the filetype
                        • keep a clean interface for ease of use and esthetic reasons
                        And somehow I'm also on the point that talig mentioned
                        @talig said:
                        ...I find it puzzling that the list of file types exists but it's empty and can't be filled.
                        Mainly because I think this is just a basic functionality and I don't see the point in this option not being provided.
                        • W
                          WorCoder
                          P.S.: I did send in a report, so maybe there might be a fix in the future...
                            Can't you just correct the filename you are returned? If there is not file extension, automatically append it before saving? Since Windows since XP hide the file extension on known files many users are completely unaware of file extensions anyway.
                            • W
                              WorCoder
                              Sorry for the late reply, was on holiday...
                              Sure I can correct the file extension, but I'd still love to have the nice looking "clean" solution with a working file type selector. 😉
                              We'll see what the future brings.
                              • Dan RathbunD
                                Dan Rathbun
                                Not a given.
                                On all our machines (or any machine I work on,) I turn file extension display back ON.
                                I'm not here much anymore.
                                  @dan rathbun said:
                                  Not a given.
                                  Yes - but by default XP hides it.
                                  • Dan RathbunD
                                    Dan Rathbun
                                    Which is one of the dumbest things Microsoft does.
                                    • T
                                      tvcasualty
                                      Sorry to drudge up old news, but this is an embarrassingly old issue, be nice to have a filter option in the API by now.
                                      Here was my solution because I didn't like the fact that it could possibly overwrite a file accidentally using TIGs approach (untitled != untitled.txt for example). Anyhow it can be a burden to hit save twice, but I'd rather do that 100x then accidentally save over something important.
                                      Where:
                                      EXT = "txt"
                                      default_dir = "c;\\temp\\"
                                      default_file = "untitled"
                                      The following while loop:
                                      name_valid = false
                                      while name_valid == false
                                       path_to_save_to = UI.savepanel("Save Code File", default_dir, default_file)
                                       #path_to_save_to = path_to_save_to.tr("\\","/") # This maybe required.
                                       fileext = File.extname(path_to_save_to) # filename with prefix stripped
                                       filebase = File.basename(path_to_save_to, ".#{EXT}")
                                       #puts fileext.inspect
                                       if fileext == "" || fileext == nil
                                        default_file = filebase + ".#{EXT}"
                                        UI.messagebox "Oops! Including the file extension '#{EXT}'\nThis is an embarrassing workaround...\nPlease hit save again."
                                        #puts default_file.inspect
                                       else
                                        filename = filebase + ".#{EXT}"
                                        path_to_save_to = File.dirname(path_to_save_to) + "\\" + filename
                                        name_valid = true
