    Useful graphic apps
    extensions
    91 Posts 39 Posters 143.6k Views 39 Watching
    • soloS Offline
      Adam
      You never lost the UV's, it's not exported with model (notice no mtl file) you need to export texture out seperately.
      • EarthMoverE Offline
        EarthMover
        I did it also with Blender, but lost the UV's. (Probably naming and file issue) I'll try Meshlab. Sculptris works great with an already made SDS mesh. I just made a nice cushion! Can't figure out why TIG's importer won't work though.
        (Sorry for taking up this thread. I'll find another thread for just Sculptris issues)
        Content Creator at Skapeup
          EarthMover
          I see! Thanks Pete!
          Came across this one today - Artizen HDR- http://www.supportingcomputers.net/Applications/Artizen/Artizen.asp
          "From real to surreal, Artizen HDR is a Windows based stand alone image editing application that has a complete set of state of the art technologies that makes working with photographs easier than ever. Artizen is full featured photo editor with ability to work with JPEG's, +14 Digital Camera RAW files and High Dynamic Range images in an easy and efficient manner suitable for both professionals and hobbyist photographers."
          Free for 8 bit image editing!!
            Simon B
            Visual Color Picker does exactly what it says 😃
              Thanks James, impressive list!
              I already use some of them but there's indeed a bunch to discover...
              • soloS Offline
                This looks cool, for Photoshop.
                400 Bad Request
                (www.niksoftware.com)
                http://www.niksoftware.com/colorefexpro/usa_img/cep3/madrona_wall.jpg
                • Z Offline
                  Zacchia
                  sure this is very helpful if you work with a lot of files:
                  http://www.mootools.com/plugins/us/index.asp
                  You can see all files as small tumbnails. It reads different files and you can also save them as different. Also convert files with batch command or polygon reduce with batch command and much more is possilbe. I could not be without it!
                  • majidM Offline
                    majid
                    http://www.artweaver.de/ is ignored.... simple and powerfull painting application for free
                    • PixeroP Offline
                      Pixero
                      Found this free photoshop plugin for normal map creation: http://cgted.com/
                      • soloS Offline
                        Nice find Pixero. 👍
                          pichuneke
                          Plugin for Gimp for normal map creation:
                          Error 404 (Not Found)!!1
                          (code.google.com)
                          (Only free software, as always 😄 )
                          By the way, do you know how to turn a normal map into a bump map? I want to use Bitmap to Mesh with a normal map, but first I have to turn it into a bump map...
                          Forgive my spanglish...
                          • PixeroP Offline
                            Pixero
                            Converting a normal map to a bumpmap/heightmap/displacementmap isnt so easy.
                            You can maybe fake it either by converting the normalmap to grayscale or using the blue channel as a base.
                            There are some programs that can do it rather well:
                            http://www.crazybump.com/
                            Commercial, good but kind of expensive.
                            http://www.xnormal.net/Downloads.aspx
                            Free? Can convert normalmap to cavity map but that isnt really a heightmap more like a occlusion map.
                            http://shadermap.com/
                            Free command line version or commercial (19.95) pro version with UI.
                            Here is some examples with Shadermap:
                              pichuneke
                              Thanks Pixero. It seems that Shadermap is what I am looking for (as I do my work for free, with free tools). 😄
                              • Al HartA Offline
                                Al Hart
                                [Edit - I presumed you wanted to turn a mesh into a bump map - I may have answered the wrong question.]
                                We wrote a (not free) app to turn a mesh into a bump-map. The trick is to look at the mesh from head on and make the closer faces either brighter or darker. A bump map does not have colors, but uses intensity of gray scale to represent Z-distance offsets.
                                We did this by extracting all the faces and running them through an OpenGL renderer which turned the distance from the camera into shading intensity. This worked well, but it was hard to find a good application for it.
                                You might be able to get a similar effect by making the object white, using a parallel projection, turning off all lighting, turning off edges, and adding fog. Then the amount of fog should represent the distance from the camera plane, and product the bump map.
                                Al Hart
                                IRender nXt from Render Plus
                                • shuraS Offline
                                  shura
                                  Thanks for sharing Pilou, Chaoscope is really beautiful!
                                    I have made reasonable displacement maps like this actually. Best is to use hidden line face style (to get rid of face shading completely) and hide all edges in the style panel.
                                    You may want to exaggerate the geometry a little bit to get the desired effect with the fog but grouping the whole thing and scaling along the Z axis makes it easy.
                                      Chaoscope
                                      The more easiest program : 3 keys F3,F4 ESCAPE 😎
                                      Maybe a day it will gives the 3D Export 😒
                                      Usefull for make crazzy background ☀
                                      Click image if scroll bar
                                      • N Offline
                                        notareal
                                        File Not Found
                                        (www.holmes3d.net)
                                        What is MeshMan?
                                        MeshMan is a 3D modeling tool. It loads and manipulates 3D mesh geometry in a few useful ways. It supports multiple subdivision schemes for smoothing a mesh, decimation for thinning a mesh, transforms for rotating, scaling, or translating a mesh, can tessellate a mesh into triangles, and supports a few other minor manipulations.
                                        The primary file format MeshMan works with is the OFF format, a simple format for storing 3D data. For more information on the OFF format, see the pages for my RoffView OFF viewing program and the related OFF Tools page. MeshMan works only with the most basic type of OFF files and does not load the texture coordinates that RoffView can handle. This is because handling that extra data is beyond the scope of MeshMan's manipulations. MeshMan can also open simple OBJ files, and can export to several other formats, including STL and PLY.
                                        • BurkhardB Offline
                                          Burkhard
                                          Skp files are only for 32 bit available 😠
                                          http://www.ia-plus.de
                                          • V Offline
                                            valerostudio
                                            http://www.artrage.com/Hands down one of the best 'painting' programs out there. The Ipad app is amazing and super cheap and the desktop versions are much much cheaper than Corel Painter and Artrage has all of the same functionalities.
                                            • 2 / 5
