    Useful graphic apps
    extensions
    91 Posts 39 Posters 144.5k Views 39 Watching
      For the little story Sculptris is now hosted by Zbrush (Pixologic) and the creator Dr Petter is now in Pixologic team (creator of Zbrush) 😉
      Whishing it stay free 😄
      • EarthMoverE Offline
        EarthMover
        It's a shame I can't get Scultpris to work with TIG's .obj importer plugin. The polyreducer brush, voxel like sculpting and texture painting would make a great free workflow addition for most sketchup users. If anyone can make it work, please let me know. I've tried all settings.
        Content Creator at Skapeup
          Try Meshlab(free)
          • soloS Offline
            Adam
            You never lost the UV's, it's not exported with model (notice no mtl file) you need to export texture out seperately.
              EarthMover
              I did it also with Blender, but lost the UV's. (Probably naming and file issue) I'll try Meshlab. Sculptris works great with an already made SDS mesh. I just made a nice cushion! Can't figure out why TIG's importer won't work though.
              (Sorry for taking up this thread. I'll find another thread for just Sculptris issues)
                EarthMover
                I see! Thanks Pete!
                Came across this one today - Artizen HDR- http://www.supportingcomputers.net/Applications/Artizen/Artizen.asp
                "From real to surreal, Artizen HDR is a Windows based stand alone image editing application that has a complete set of state of the art technologies that makes working with photographs easier than ever. Artizen is full featured photo editor with ability to work with JPEG's, +14 Digital Camera RAW files and High Dynamic Range images in an easy and efficient manner suitable for both professionals and hobbyist photographers."
                Free for 8 bit image editing!!
                  Simon B
                  Visual Color Picker does exactly what it says 😃
                    Thanks James, impressive list!
                    I already use some of them but there's indeed a bunch to discover...
                    • soloS Offline
                      This looks cool, for Photoshop.
                      400 Bad Request
                      (www.niksoftware.com)
                      http://www.niksoftware.com/colorefexpro/usa_img/cep3/madrona_wall.jpg
                      • Z Offline
                        Zacchia
                        sure this is very helpful if you work with a lot of files:
                        http://www.mootools.com/plugins/us/index.asp
                        You can see all files as small tumbnails. It reads different files and you can also save them as different. Also convert files with batch command or polygon reduce with batch command and much more is possilbe. I could not be without it!
                        • majidM Offline
                          majid
                          http://www.artweaver.de/ is ignored.... simple and powerfull painting application for free
                          • PixeroP Offline
                            Pixero
                            Found this free photoshop plugin for normal map creation: http://cgted.com/
                            • soloS Offline
                              Nice find Pixero. 👍
                                pichuneke
                                Plugin for Gimp for normal map creation:
                                Error 404 (Not Found)!!1
                                (code.google.com)
                                (Only free software, as always 😄 )
                                By the way, do you know how to turn a normal map into a bump map? I want to use Bitmap to Mesh with a normal map, but first I have to turn it into a bump map...
                                Forgive my spanglish...
                                • PixeroP Offline
                                  Pixero
                                  Converting a normal map to a bumpmap/heightmap/displacementmap isnt so easy.
                                  You can maybe fake it either by converting the normalmap to grayscale or using the blue channel as a base.
                                  There are some programs that can do it rather well:
                                  http://www.crazybump.com/
                                  Commercial, good but kind of expensive.
                                  http://www.xnormal.net/Downloads.aspx
                                  Free? Can convert normalmap to cavity map but that isnt really a heightmap more like a occlusion map.
                                  http://shadermap.com/
                                  Free command line version or commercial (19.95) pro version with UI.
                                  Here is some examples with Shadermap:
                                    pichuneke
                                    Thanks Pixero. It seems that Shadermap is what I am looking for (as I do my work for free, with free tools). 😄
                                    • Al HartA Offline
                                      Al Hart
                                      [Edit - I presumed you wanted to turn a mesh into a bump map - I may have answered the wrong question.]
                                      We wrote a (not free) app to turn a mesh into a bump-map. The trick is to look at the mesh from head on and make the closer faces either brighter or darker. A bump map does not have colors, but uses intensity of gray scale to represent Z-distance offsets.
                                      We did this by extracting all the faces and running them through an OpenGL renderer which turned the distance from the camera into shading intensity. This worked well, but it was hard to find a good application for it.
                                      You might be able to get a similar effect by making the object white, using a parallel projection, turning off all lighting, turning off edges, and adding fog. Then the amount of fog should represent the distance from the camera plane, and product the bump map.
                                      Al Hart
                                      IRender nXt from Render Plus
                                      • shuraS Offline
                                        shura
                                        Thanks for sharing Pilou, Chaoscope is really beautiful!
                                          I have made reasonable displacement maps like this actually. Best is to use hidden line face style (to get rid of face shading completely) and hide all edges in the style panel.
                                          You may want to exaggerate the geometry a little bit to get the desired effect with the fog but grouping the whole thing and scaling along the Z axis makes it easy.
                                            Chaoscope
                                            The more easiest program : 3 keys F3,F4 ESCAPE 😎
                                            Maybe a day it will gives the 3D Export 😒
                                            Usefull for make crazzy background ☀
                                            Click image if scroll bar
                                            • 2 / 5
