    How to draw a cylinder by ruby?
    11 Posts 7 Posters 3.2k Views 7 Watching
      Andreas
      how can I draw a cylinder by ruby-code?
      With best regards from Germany
      Andreas
      • TIGT Online
        group=Sketchup.active_model.active_entities.add_group()
        ents=group.entities
        edges=ents.add_circle(center_point, normal_vector, radius, segments)
        face=edges[0].face
        face.pushpull(height)
        center_point is the point at which the center of the cylinder's bottom face sits...
        normal_vector is the direction of the circular face [which will become the cylinder's bottom face] - typically Z_AXIS...
        radius the circular face's and therefore the cylinder's radius...
        segments the number of segments in the circle and thereby the cylinder's 'side' faces...
        height is the cylinder's height.
        When you have made the cylinder you can use group.explode to return the cylinder's geometry to the active context if desired...
          Bill_239
          Thank you very much! You provided just enough for me create my first Ruby SketchUp script (it makes cylinders) and I figured out how to integrate it with SketchUp..all in just a few hours..lol! It was an ideal challenge--I feel like I'm off and running! I should mention, for the sake of anyone reading this, that some background I had in O-O programming and some reading I did about Ruby, were invaluable too. I just registered at this site and I am looking forward to learning more about programming for SketchUp here.
          Bill
          • Chris FullmerC Offline
            Great, welcome to the site. Good luck with your next Ruby endevor!
              Andreas
              > ents=group.entities
              > face=edges[0].face
              Sorry, but that doesn´t works:
              center_point = Geom;;Point3d.new(10, 10, 10)
              => Point3d(10, 10, 10)
              vector = Geom;;Vector3d.new(0,0,1)
              => Vector3d(0, 0, 1)
              => nil
              radius = 5
              => 5
              segments = 10
              => 10
              height = 2
              => 2
              => nil
              => #<Sketchup;;Group;0x821f824>
              ents=group.entities
              => #<Sketchup;;Entities;0x821f298>
              => nil
              edges=ents.add_circle(center_point, Z_AXIS, radius, segments)
              => [#<Sketchup;;Edge;0x821e190>, #<Sketchup;;Edge;0x821e168>, #<Sketchup;;Edge;0x821e154>, #<Sketchup;;Edge;0x821e140>, #<Sketchup;;Edge;0x821e12c>, #<Sketchup;;Edge;0x821e118>, #<Sketchup;;Edge;0x821e104>, #<Sketchup;;Edge;0x821e0f0>, #<Sketchup;;Edge;0x821e0dc>, #<Sketchup;;Edge;0x821e0c8>]
              => nil
              face=edges[0].face
              NoMethodError; undefined method `face' for #<Sketchup;;Edge;0x821e190>
              Andreas
                face=edges[0].faces[0]
                  Andreas
                  There is also an error:
                  => nil
                  radius = 5
                  => 5
                  segments = 10
                  => 10
                  height = 2
                  => 2
                  => nil
                  => #<Sketchup;;Group;0x82075d0>
                  ents=group.entities
                  => #<Sketchup;;Entities;0x8206d60>
                  => nil
                  => [#<Sketchup;;Edge;0x8205adc>, #<Sketchup;;Edge;0x8205ac8>, #<Sketchup;;Edge;0x8205a64>, #<Sketchup;;Edge;0x8205a50>, #<Sketchup;;Edge;0x82059ec>, #<Sketchup;;Edge;0x82059d8>, #<Sketchup;;Edge;0x82059b0>, #<Sketchup;;Edge;0x820599c>, #<Sketchup;;Edge;0x8205988>, #<Sketchup;;Edge;0x8205974>]
                  => nil
                  NoMethodError; undefined method `pushpull' for nil;NilClass
                  Andreas
                    edges=ents.add_circle(center_point, Z_AXIS, radius, segments) edges[0].find_faces face=edges[0].faces[0]
                    or (maybe better option)
                    edges=ents.add_circle(center_point, Z_AXIS, radius, segments) face=ents.add_face( edges )
                    • TIGT Online
                      We have all gone adrift here... 😳
                      You have a set of edges forming a circular 'ring' - nothing more.
                      We've missing a line of code!
                      To make a face from the edges use
                      face=ents.add_face(edges)
                      then to ensure it's the inner face that the edges delineate use
                      NOW face will be the inner face of the circle - this is useful in case the 'ring' is already drawn over a face etc and you might end up with two faces touching an edge... 🤓
                      EDIT: I see Thomthom beat me to it!
                        buidoi3003
                        Hi guys,
                        I use the following code to set the center point = position of the mouse click:
                        def onLButtonDown(flags, x, y, view)
                        puts " x = "
                        puts " y = "
                        puts "--------------------- "
                        centerpoint = Geom::Point3d.new x,y,0
                        However, the (x,y) seems not to be my mouse's click position. It is just random.
                        How could I set the center point to be my mouse click position?
                          driven
                          hi
                          have a look at linetool.rb and class CylTool < LineTool in the Example scripts folder in ../SketchUp/Plugins/examples/linetool.rb, or download it if it's not......
