    Render this: Kitchen
    57 Posts 33 Posters 11.0k Views 33 Watching
    • E Offline
      ericschimel
      It must be large address aware then, because it soaks up way more then 2gb of ram... Time to upgrade! ๐Ÿ˜„
      -Eric
      http://plugin.sketchthis.net
      Sketchup Kitchen Design Plugin
      Custom Models
        martin-art
        I just wanted to clarify that Shaderlight will run as both a 32 bit and 64 bit system.
        In our installer we tell Windows that it is a 32 bit system to avoid having 2 separate installers. But if you have 64 bit Windows then you will be running 64 bit Shaderlight (it will confirm this in the Help - About Shaderlight in the Shaderlight render Window. So Shaderlight will benefit from having more than 4Gb in the system and will use it.
        Martin
        • E Offline
          ericschimel
          Cool! Good to know. So here's a question, if mine is installed in the x86 directory, does that mean its not running as a 64 bit app?
          -Eric
          Custom Models
            martin-art
            No that is where it will be installed whether running as 32 bit or 64 bit. While rendering in the Shaderlight Render Window go to Help, About Shaderlight. This will tell you what version you are running. The information is not displayed in the SketchUp help menu just the Shaderlight one.
            Martin
              jsteacy
              I 'm trying to throw my hat in the ring a little more often but I'm still learning. Rendered in Thea, added vignetting in the first image to create a bit darker atmosphere in the room, not sure if it worked though. Just sun for lighting, which is why there is nothing in the windows. I love the blue in the skylights especially with the reflections. Does anyone know how I would get the same blue in the lower windows. I assume it has something to do with the horizon/atmosphere settings but I don't know. I uses adobe kuler for selection of the paint on the walls and the lamp over the table. I like the colors but they match the wood texture too much I think. If you haven't heard of Kuler, check it out, I think it's great for any designer. http://kuler.adobe.com/
              thea render with vignetting
              thea render
                troyhome
                Here's my Thea render- cropped in Photoshop...
                only pp is crop in ps
                color pp in ps
                IOviz.com
                SU Pro 2024 PC
                  samatall
                  This is from RenderIn
                    troyhome
                    After 3 hours in Thea there is still a ton of grain...
                    Fotosketcher
                    IOviz.com
                    SU Pro 2024 PC
                      troyhome
                      I like the ambient occlusion quality RenderIn has. I had to unload it because it interfered with SketchUp- every time i selected something and double clicked, the select tool would randomly become the paint bucket tool (i was constantly texturing things by accident) ๐Ÿ˜ฎ
                      IOviz.com
                      SU Pro 2024 PC
                        troyhome
                        Okay- i got it to where i like it. 10 hrs + render time in Thea, minor color pp in PS
                        IOviz.com
                        SU Pro 2024 PC
                        • tridemT Offline
                          tridem
                          Here's my attempt with Thea Render.
                          cheers
                          • E Offline
                            ericschimel
                            That's nice!
                            Does the Thea render add that "Soap Opera" look? (I am not poking fun, it looks good!)
                            -Eric
                            Custom Models
                            • tridemT Offline
                              tridem
                              ๐Ÿ˜† ...you mean the glare effect? yes is a thea tool
                                troyhome
                                That's nice!
                                Ha! i love it- that's what i'm calling it from now on ๐Ÿ˜„
                                IOviz.com
                                SU Pro 2024 PC
                                • PixeroP Offline
                                  Pixero
                                  Oil on canvas, 2 weeks...
                                  ...just kidding.
                                  Three layers of Dap and Photoshop.
                                  Less than 10 minutes in total.
                                  • FrederikF Offline
                                    Frederik
                                    ๐Ÿคฃ
                                    http://www.kerkythea.net/users/Frederik/Anim-Icons/clap-above.gif
                                    It's really funny to see some different results of this... ๐Ÿ˜„
                                    Cheers
                                    Kim Frederik
                                    • F Offline
                                      floor
                                      @floor said:
                                      Hello , it was I nice model to play with, I try to create two moments of the day .
                                        bhbarchitects
                                        Hi All
                                        First Attempt, not much done in photoshop just added texture to logs, AO pass and colour corrected.
                                        Feedback as always welcome.
                                        Matt
                                        Sketchup Vray(Beta) Photoshop
                                        • N Offline
                                          nomeradona
                                          better late than never. may i know the functionality in the froum how to display this smaller image. like autoresizing functionality?
                                            Hi nomeradona,
                                            You can use the 'Upload attachment' feature below the 'Post a reply' input box. I edited your post to achieve this/ I hope you don't mind?
                                            Great render as always. Thanks for sharing ๐Ÿ‘
                                            • 2 / 3
