    Render this: Kitchen
    57 Posts 33 Posters 11.2k Views 33 Watching
    • N Offline
      notareal
      They say RAM should do the trick. Its a separate application from Sketchup, and at this point, its not a 64 bit app (At least I am assuming because its in the x86 install folder)
      If I am correct, it won't be able to use more then 3gig of RAM because its not 64 bit? So upgrading to 8 would actually help, because just having my system loaded up eats up about 1.5 gig....
      Limits for 32-bit program in 64-bit windows:
      2 GB with IMAGE_FILE_LARGE_ADDRESS_AWARE cleared (default)
      4 GB with IMAGE_FILE_LARGE_ADDRESS_AWARE set
      http://msdn.microsoft.com/en-us/library/aa366778%28VS.85%29.aspx
      Adding RAM will allow more 32-bit programs run without swapping, but the amount of memory available for each 32-bit program will stay same (2Gb or 4Gb, if large-address-aware flag is used).
      Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
      • E Offline
        ericschimel
        It must be large address aware then, because it soaks up way more then 2gb of ram... Time to upgrade! ๐Ÿ˜„
        -Eric
        http://plugin.sketchthis.net
        Sketchup Kitchen Design Plugin
        Custom Models
          martin-art
          I just wanted to clarify that Shaderlight will run as both a 32 bit and 64 bit system.
          In our installer we tell Windows that it is a 32 bit system to avoid having 2 separate installers. But if you have 64 bit Windows then you will be running 64 bit Shaderlight (it will confirm this in the Help - About Shaderlight in the Shaderlight render Window. So Shaderlight will benefit from having more than 4Gb in the system and will use it.
          Martin
          • E Offline
            ericschimel
            Cool! Good to know. So here's a question, if mine is installed in the x86 directory, does that mean its not running as a 64 bit app?
            -Eric
            Custom Models
              martin-art
              No that is where it will be installed whether running as 32 bit or 64 bit. While rendering in the Shaderlight Render Window go to Help, About Shaderlight. This will tell you what version you are running. The information is not displayed in the SketchUp help menu just the Shaderlight one.
              Martin
                jsteacy
                I 'm trying to throw my hat in the ring a little more often but I'm still learning. Rendered in Thea, added vignetting in the first image to create a bit darker atmosphere in the room, not sure if it worked though. Just sun for lighting, which is why there is nothing in the windows. I love the blue in the skylights especially with the reflections. Does anyone know how I would get the same blue in the lower windows. I assume it has something to do with the horizon/atmosphere settings but I don't know. I uses adobe kuler for selection of the paint on the walls and the lamp over the table. I like the colors but they match the wood texture too much I think. If you haven't heard of Kuler, check it out, I think it's great for any designer. http://kuler.adobe.com/
                thea render with vignetting
                thea render
                  troyhome
                  Here's my Thea render- cropped in Photoshop...
                  only pp is crop in ps
                  color pp in ps
                  IOviz.com
                  SU Pro 2024 PC
                    samatall
                    This is from RenderIn
                      troyhome
                      After 3 hours in Thea there is still a ton of grain...
                      Fotosketcher
                      IOviz.com
                      SU Pro 2024 PC
                        troyhome
                        I like the ambient occlusion quality RenderIn has. I had to unload it because it interfered with SketchUp- every time i selected something and double clicked, the select tool would randomly become the paint bucket tool (i was constantly texturing things by accident) ๐Ÿ˜ฎ
                        IOviz.com
                        SU Pro 2024 PC
                          troyhome
                          Okay- i got it to where i like it. 10 hrs + render time in Thea, minor color pp in PS
                          IOviz.com
                          SU Pro 2024 PC
                          • tridemT Offline
                            tridem
                            Here's my attempt with Thea Render.
                            cheers
                            • E Offline
                              ericschimel
                              That's nice!
                              Does the Thea render add that "Soap Opera" look? (I am not poking fun, it looks good!)
                              -Eric
                              Custom Models
                              • tridemT Offline
                                tridem
                                ๐Ÿ˜† ...you mean the glare effect? yes is a thea tool
                                  troyhome
                                  That's nice!
                                  Ha! i love it- that's what i'm calling it from now on ๐Ÿ˜„
                                  IOviz.com
                                  SU Pro 2024 PC
                                  • PixeroP Offline
                                    Pixero
                                    Oil on canvas, 2 weeks...
                                    ...just kidding.
                                    Three layers of Dap and Photoshop.
                                    Less than 10 minutes in total.
                                    • FrederikF Offline
                                      Frederik
                                      ๐Ÿคฃ
                                      http://www.kerkythea.net/users/Frederik/Anim-Icons/clap-above.gif
                                      It's really funny to see some different results of this... ๐Ÿ˜„
                                      Cheers
                                      Kim Frederik
                                      • F Offline
                                        floor
                                        @floor said:
                                        Hello , it was I nice model to play with, I try to create two moments of the day .
                                          bhbarchitects
                                          Hi All
                                          First Attempt, not much done in photoshop just added texture to logs, AO pass and colour corrected.
                                          Feedback as always welcome.
                                          Matt
                                          Sketchup Vray(Beta) Photoshop
                                          • N Offline
                                            nomeradona
                                            better late than never. may i know the functionality in the froum how to display this smaller image. like autoresizing functionality?
                                            • 3 / 3
