    [Plugin] Dxf_In v2.2 20110517 Dxf2Skp
    200 Posts 41 Posters 277.5k Views 41 Watching
    • honoluludesktopH Offline
      honoluludesktop
      The basic arcs, have been corrected, but the Dxf contains entities currently unsupported by "Dxf Import". Until these are added, along with support for "nested block(s)", only the most basic geometry, will be imported. If necessary, the unsupported entities can be exploded into supported entities prior to being imported into SU.
      I have been unable to test "basic block(s)" except in the simplest cases. If I can get a Dxf with "BLOCK" and their related "INSERT" entities (not INSERT(s) inside a BLOCK) to test, I will then be able to check them. I need someone to post a Dxf with a pair of BLOCK(s) made in Acad as illustrated below.2 groups, a cube and a cylinder.
      • BepB Offline
        Bep
        Hi Honoluludektop,
        I'm sorry that i cant help you with a real acad dxf ,but would'nt a dxf created with the free doublecad http://www.doublecad.com/LinkClick.aspx?link=http%3a%2f%2factivate.imsisoft.com%2fdoublecad.aspx%3fproductpage%3dDoubleCAD_XT_v2&tabid=1128&mid=3384
        do the same.
        Thanks for your effort ,and i wish you succes πŸ‘ ,
        Bep
        "History is written by the winners"
          honoluludesktop
          I am not fluent in that app, and failed to take a component into it as a block, and back as a group/component with the original entities preserved. But if you build the model in DoubleCad, and save as a Dxf, I can give it a try. By inspecting the DXF, it is possible to see if the entities are preserved. Thanks.
            SurfingAlien
            thank you very much!
            I will try it asap and let you know if it works fine with my CAD programs (I'm still with SU 7.1 BTW)
            cheers,
            Alessandro
              honoluludesktop
              Beta release v0.50 includes LWPolylines, group names, and some fixes. The following image is the bathtub dxf previously provided.
                honoluludesktop
                Alpha v 0.45 includes support for Blocks2Groups. Charley, while still missing lwpolylines and ellipse, arcs are resolved, and blocks accomodated in the current release, (I hope:-). Bep, translators are not equal. One app. may elect to export circles as connected edges, in other situations, SU may have, or not have a high level entity that a Cad app supports, so....Sigh!!!!, several situations need to be tested for.
                Missing lwpolyline and ellipse
                Acad has more entities then I thought possible. In the process of supporting blocks, I discovered polyface meshes. The following is one of 6 variations in this category. In this release blocks2groups is addressed. I would still like to get a Acad created Dxf of a cube, and drum represented as faces.
                The polyline is a polyface mesh.
                Highlighted groups
                Anyway, if "NO" to convert polyline to faces is selected, the above is created. It is a way of representing a 3d object with polylines, taking the least amount of space in Dxf.
                In most cases, selecting OK, to a error message, allows you to proceed. In some cases, this is taking too much time, and needs to be accommodated
                  honoluludesktop
                  Except for polyface mesh, Dxf_in v1.0 imports the basic geometric entities recognized by SU.
                  Dxf polyline mesh import.
                  • DavidBoulderD Offline
                    DavidBoulder
                    Looks great! I ran it through a test with some DXF's created by EnergyPlus (as part of an energy simulation run).
                    What I noticed is that using your plugin the DXF came in 12x smaller. In the Pro I have units set to feet vs. inches, which works with these DXF's. Easy enough for the user to fix but could be nice option to add down the road. One other thing I noticed is that on your DXF import a few faces were reversed from how there were with the pro importer. The pro importer was not set to "orient faces consistently" but maybe it was doing it anyway, and the source file really does have some reversed faces.
                    Other features that would be nice, but aren't critical, are to support the layer and color applied to a face.
                    DXF_In 1.1 and pro side by side.
                    David Goldwasser
                    OpenStudio Developer
                    National Renewable Energy Laboratory
                      honoluludesktop
                      David, Thanks. Can you provide a sample dxf (smaller the easier for me) with layer and texture? Perhaps I should provide a options menu.
                        DavidBoulder
                        Sure, here is a 50k file from the example above. Now this was made from EnergyPlus, so it may not be the best test case since it wasn't generated by AutoCad. I'm not sure if a similar file from Autocad would like the same or not.
                        This file has layers and color (not image textures)
                        (hmm, can I not upload DXF file?)
                        David Goldwasser
                          Jim
                          you can download lot's of dxf files from here (my google site.) The .zip contains an un-attributed compilation of shared .dxf files designed as 2D cnc routing patterns. (17MB)
                          I'm wondering, do you know how to handle the bulge data when it appears in the lwpolylines? It's something I'd like to add to my importer, too.
                            I made dxf (and dwg) an attachable file extension
                              honoluludesktop
                              Jim, Thanks, I will take a look at your files. Is lwpolyline something that is required by a lot of modern applications? I found the following, but bulge remains unimplemented with my importer:
                              "The bulge is the tangent of 1/4 of the included angle for the arc between the selected vertex and the next vertex in the polyline's vertex list. A negative bulge value indicates that the arc goes clockwise from the selected vertex to the next vertex. A bulge of 0 indicates a straight segment, and a bulge of 1 is a semicircle."
                              DXF is on the other side of the moon when compared with SUs faces, and edges. I initially made Dxf_In work for my own Cad application, then added features as others have requested. Initially, by self imposed discipline, all of my cad models were built with 3d faces, and blocks. My Cad2Dxf2Su requirements were simple. But times change, and while my code is fairly well organized to implement new entities, it needs work on the overall DXF structure. Something I ignored since I was only interested in geometry.
                              Gai, Great. Perhaps, like a lot of others, I only learned how to "send to zip" once I needed to do it.
                                honoluludesktop
                                Just change the file.extension name to .txt, or right click, sent to .zip first. Thanks
                                Addenda: See post by Gai below.
                                  DavidBoulder
                                  Here is the attachment. Thanks for the tips. I left the file at work, so couldn't send last night. Sounds like we can do dxf's now.
                                  GeometryTest.dxf
                                  David Goldwasser
                                    Jim
                                    Looking at the Blender dxf importer (written in Python) and found these dxf test files in the Downloads section:
                                    301 Moved Permanently
                                    (wiki.blender.org)
                                      honoluludesktop
                                      V1.2 provides the option to select input units, and location (thanks to_tt). Not being familiar with metric conversion, I did not check their accuracy.
                                      Model built converting feet to inchesBtw: In regards to lwpolylines, when I wrote this translator, I found that the dxf example I used contained occasional differences in the actual number of vertices's, and the number provided by the dxf. So, I ended up writing a procedure that did not depend on the stated number. I am not sure if this is a misunderstanding on my part or a bug in the program that created the dxf.
                                        honoluludesktop
                                        Sigh...As soon as you think you got it, there is something to change, hence v1.1. Functionally no different, but with better error messages. Unless I find a bug, or figure how to add a polyface mesh, this should be it:-) Attached are some test with old.dxf models.
                                        A first draft Cad.Dxf model brought into SU for visualization.
                                        Another first draft Cad.Dxf detail originally imported for study.
                                        The model's groups are based on common materials, textures, or colors. This makes it is easy to update the SU model's textures of any Cad based revision. The groups/blocks are sent both ways so that the production drawings are easily revised based on changes to the model.
                                          Jim
                                          I can't find the reference now, but I understood it to say something similar to "polylines that can be converted to lwpolylines, are converted into lwpolylines in order to save space."
                                          I have a routine to handle the bulge data for regular polylines, but the lwpolylines are different enough that I haven't been able to decipher them consistently.
                                          I found a dwg/dxf converter for Windows that may be of interest. It converts between dwg and dxf, but also from dxf to dxf and you can choose several versions of the file format. So maybe it will be useful for converting tricky dxf files into older formats which your importer is more tolerant of.
                                          The converter is here, under the name ODA Teigha File Converter.
                                          Demo
                                          Open Design Alliance (www.opendesign.com)
                                            honoluludesktop
                                            Jim, I am using Dxf Reference, ACAD 2010 and am not able to identify bulge data within dxf polyline.
                                            The group code for bulge in lwpolyline "42", is absent in the 2010 reference for polyline unless it is part of "70" and some other group code. I don't look forward to figuring out how to including it in Dxf_In.
                                            Incidentally, Dxf_In doesn't check for version number, and will attempt to process any File.Dxf, even one that is manually, incorrectly edited, and rejected by Import SU Pro. It has succeed for the implemented entities, except when the group code is written out of order. I noticed that import SU Pro V7 refused to translate a 2010 Dxf file.
                                            • 5 / 10
