    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
    • KrisidiousK
      Krisidious
      yes they are checkmarked... I may be slow... but I'm not that slow ๐Ÿ˜‰
      By: Kristoff Rand
      • fredo6F
        Then,
        1. do you see a menu LibFredo6 Settings in the Windows menu
        2. If so, can you open the Ruby console, type load "ZLoader__FredoScale.rb" and tell me if you see some messages
        3. By the way, do you you some other of my plugins working fine (Like RoundCorner or Curviloft)?
        • KrisidiousK
          Krisidious
          Then,
          Error: #<SyntaxError: (eval):894: compile error
          (eval):894: unterminated string meets end of file>
          (eval):894
          the settings menu item is there... but the drop down menu that should come up from it does not appear.
          I do have a few of your other plugins such as curviloft and round corner.
          By: Kristoff Rand
          • fredo6F
            This is very weird.
            There must be a faulty file somewhere.
            1. Did you try to download the Zip from Sketchucation and install again the scripts?
            2. Can you try the same manual loading with Ghostcomp and TOS from the Ruby console and see if you get a similar message
            3. Also, just in case, could you remove the file FredoScale.def from the DEFPARAM_dir folder.
            • KrisidiousK
              Krisidious
              (eval):1: warning: already initialized constant MYPLUGIN
              true
              load "ZLoader__Curviloft.rb"
              true
              load "ZLoader__GhostComp.rb"
              true
              load "ZLoader__OnSurface.rb"
              true
              there is nothing in my DEFPARAM_Dir folder...
              By: Kristoff Rand
              • KrisidiousK
                Krisidious
                well I gave up on trying to fix it... I deleted my plugins folder and started installing all plugins from scratch. now I have all my paid plugins, my most essential plugins like Thomthom, Fredo and Tig and all my toolbars. so I'm happy... I'm missing a lot of small simple plugins and individual rubies, but I'll just add them as I miss them.
                so I have no idea what my error was... I saved the plugins folder that was erroring, so if anyone has any ideas I can check it still.
                By: Kristoff Rand
                  DIEGO-RODRIGUEZ
                  Hi Fredo.
                  I make a query.
                  would be added to your tool to scale a similar function to the image but for 3D objects'?
                  scalar or reference to three points
                  really would be helpful
                  possible?
                  thanks
                  • P
                    Pastilhas
                    Hi Fredo.
                    First of all, Thank you for this Truly remarkable plugin.
                    I just installed Sketchup 8.0.3117 and your plugin but i got a weird error when a use it.
                    http://www.snapdrive.net/files/493183/Freedo 1.JPG
                    when i put 4000mm in FredoScale, Sketchup change radius circle to 2017.3 ?!
                    If i change radius circle to 2000mm FredoScale change to 3965,8mm ?!
                    http://www.snapdrive.net/files/493183/Freedo 2.JPG
                    What happening?
                    Im, using:
                    Sketchup 8.0.3117
                    FredoScale 2.0i
                    LibFredo6 3.4c
                    Thx and sorry for my bad English.
                    • fredo6F
                      @pastilhas said:
                      Hi Fredo.
                      What happening?
                      Im, using:
                      Sketchup 8.0.3117
                      FredoScale 2.0i
                      LibFredo6 3.4c
                      From what I observe on the image, your scaling box is not aligned with the axes. This is usual for round shapes, because a circle in Sketchup is not a true circle, but a suite of small segments).
                      I would suggest that you align the scaling box, by typing RIGHT ARROW.
                      Then tell me if you still have a problem with the dimensions
                      • fredo6F
                        @diego-rodriguez said:
                        Hi Fredo.
                        I make a query.
                        [attachment=0:19ki78vc]<!-- ia0 -->Untitled.gif<!-- ia0 -->[/attachment:19ki78vc]
                        possible?
                        thanks
                        This type of Scaling About (specifying the pivot point and a direction) is possible. I am not sure it fits the UI framework of FredoScale however. I would rather see a dedicated plugin for that.
                        • P
                          Pastilhas
                          @pastilhas said:
                          Hi Fredo.
                          What happening?
                          Im, using:
                          Sketchup 8.0.3117
                          FredoScale 2.0i
                          LibFredo6 3.4c
                          ๐Ÿ˜ฎ Shame on me ....
                          Worked like a charm, thx Fredo.
                            DIEGO-RODRIGUEZ
                            oo, thank you very much fredo.
                            this tools would be very useful.
                            for example when drawn with the "adapter picture" of sketchup.
                            when it finishes drawing perspective, if we know the true measure of a wall (for example) we can scale the all drawing. segun esta medida conocida, according to this measure known.
                            • jeff hammondJ
                              diego,
                              i might be missing some of what you're saying but if i'm not, you can already do that in sketchup using the tape measure tool
                              just measure a line in the model which you know the length of then type that measurement in the vcb and everything will scale accordingly.. you can do it inside a group if you only want to change certain lengths or do it globally so that everything in the model scales..
                                DIEGO-RODRIGUEZ
                                Jeff my English is very bad. I'm learning
                                My idea is to do something similar to this picture, both in 2D and in 3D.
                                not how to do that with sketchup, in a simple and fast.
                                I do, but I use several methods
                                • jeff hammondJ
                                  i was just checking if you knew about scaling with the tape measure
                                  if that's not simple or fast enough for you then ok..
                                  personally, i think a tool which you're showing (autocad?) would be mostly beneficial for scaling to approximate lengths (the lengths beginning with ~ in sketchup)
                                  but hey, fredo likes your idea so let's see what he comes up with ๐Ÿ˜‰
                                    DIEGO-RODRIGUEZ
                                    A simple example would be this image. is an example in 2D, but 3D would be helpful.
                                    Thom time ago wrote a plugin to modify a curve depending on the length of one side.
                                    would be something similar but 3D, interactive and for Groups or Components
                                    http://forums.sketchucation.com/viewtopic.php?f=323&t=28439&p=247192&hilit=tt_edge_adjust.rb#p247194
                                    • jeff hammondJ
                                      i'm still not convinced you're hearing me about the tape measure...
                                      don't use for that.. use
                                      [flash=750,446:prdy63au]http://www.youtube.com/v/u3tsguLP74A?fs=1&amp;hl=en_US&amp;color1=0x2b405b&amp;color2=0x6b8ab6[/flash:prdy63au]
                                        DIEGO-RODRIGUEZ
                                        you are a genius. ๐Ÿ˜„
                                        jajaaj
                                        I feel a fool.
                                        three years using sketchup and I did not know this function.
                                        thank you very much
                                        • V
                                          Vicspa
                                          Thanks Fredo
                                          • jeff hammondJ
                                            jajaaj
                                            ๐Ÿ˜† ๐Ÿค“
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 58
                                            • 59
                                            • 24 / 59
