    Not able to edit points of shapes?
    layout
    5 Posts 2 Posters 3.3k Views 2 Watching
      jason_maranto
      I'm not sure if this is a bug or if it is intended but I am unable to enter point editing mode for some of the shape primitives via double click.
      If this isn't a bug could someone explain to me the logic of why?
      Best,
      Jason.
        bjanzen
        Sure. It's the difference between a shape and a path. If there is a shape that you can't add or adjust bezier points to, e.g. Rectangles and Ellipses, simply use the split tool (Tools->Split) and split the shape so it becomes a path. Now you can double click on it and modify.
        b
          jason_maranto
          Thank-you for the reply -- I already understood the work-around... my question was really "why?" πŸ˜• .
          I'm not sure I get why polygons and circles will allow direct editing and other shapes do not -- they are all built of the same stuff and the specialized edibility of the shapes (eg- up/down arrow, etc.) does not persist so why the counter-intuitive difference in the way some shapes are handled? (which BTW is not documented, which is why I thought it might be a bug)
          The one that puzzles me the most is the ellipse... the others I can see there is some sort of recalculation of the rounded corners taking place during scale operations (or something).
          The reason I ask is I have to explain it to others and "just because" isn't an answer I like to give. πŸ€“
          Also, it might be a feature request to have some sort of explode context click command for these special shapes as the split thing is less than ideal -- you end up with extra points that aren't easy to get rid of or heal... best case scenario it takes 6 clicks to get to an clean editable state.
          Best,
          Jason.
            bjanzen
            If the people you're explaining it to aren't programmers, then I wouldn't bother trying to explain, other than perhaps to mention a subtlety in their behavior: rectangles and ellipses generally are drawn parallel or perpendicular to the x axis, and they remember that, but bezier paths don't. For example, draw a rectangle and a pentagon, and rotate each 90ΒΊ. Now select each one. Note that the rectangle rotation knob remembers the rotation from the original position. The pentagon, being a path, doesn't. Not a big benefit for you, I guess, if you didn't notice it.
            b
              jason_maranto
              No, thank-you β˜€ ... anything I can pass on is going to help make more sense of the separation in the tools and the "why" behind it.
              Just fact finding and trying to make double sure I know what is really happening... you know what they say, "measure twice, cut once" πŸ˜‰
              Best,
              Jason.
