    Texture from url?
    39 Posts 10 Posters 7.8k Views 10 Watching
      What is the plugin doing - as a whole?
      I'm wondering if you might be able to make use of webdialogs - using XMLHttpRequest with Javascript.
      • V Offline
        Viskiz
        I have materials in web server and this script is used to create and apply material from server, using WebDialog. Is there a vay to create texture using webdialog, XMLHttpRequest and Javascript?
          Yes, you could use a webdialog to that runs a Javascript that downloads the texture and use that temp file to create the texture.
          All though, there could very well be some better way within SketchUp Ruby. Though I'm not immediate ware of it.
          Just throwing in some ideas.
          • V Offline
            Viskiz
            Yes, i had this idea, but how to know the name and location of that tmp?
            • TIGT Online
              API can use the texture image file from a temp folder.
              You need to download the image file to that folder from the url.
              See Ruby on Rails http://www.ruby-forum.com/topic/133981
              http://snippets.dzone.com/posts/show/3994
              or
              http://crunchlife.com/articles/2009/01/07/another-ruby-image-scraper
              or here's some java script to download an image in a webdialog http://www.codingforums.com/archive/index.php/t-34531.html
              • V Offline
                Viskiz
                or
                These links requires additional ruby libraries that regular Sketchup users does not have and may find difficult themselves to install them. I'd like to find a way to do this without using Sketchup unsupported Ruby libraries.
                @attachment_data = open(url) #throws exception "Invalid argument", cause it requires 'open-uri' that Sketchup does not have.
                I need to get the file without interrupting user with "Save as" or another yet additional dialog
                • TIGT Online
                  The javascript version 'executes' 'save_as' you could look for a 'save' equivalent ?
                  • V Offline
                    Viskiz
                    I could not find such function, that save file without interruption. I don't think it's possible.
                      How about:
                      • Download the image using HTTPRequest
                      • Put the data into a hidden input field. (possibly base64 encoded? - since you are dealing with binary data)
                      • Use WebDialog.get_element_value to fetch the data
                      • Save to a temp file with the Ruby File class
                        ben.doherty
                        Hi, I'm trying to do something similar.
                        I'm not too fussed about using non sketchup ruby libraries, so I just want to do it in the most elegant way possible.
                        I tried adding:
                        $LOAD_PATH << "C:/Ruby186/lib/ruby/1.8/net"
                        $LOAD_PATH << "C:/Ruby186/lib/ruby/1.8/i386-mingw32"
                        to my load paths as a way to crunch through the error messages that I got (couldn't find socket etc.)
                        Is there an easy way to do this that is nice and easy and clean?
                        • N Offline
                          NatBridge
                          Maybe you could just open the webdialog to the image url and screenshot it? (If it isn't bigger than the screen.)
                          Error 404 (Not Found)!!1
                          (code.google.com)
                            ben.doherty
                            That would probably work, but wouldn't win any prizes for elegance.
                            Given that ruby can access things on the internet as part of it's core library does anyone have any idea how to point it at those standard libraries?
                            • TIGT Online
                              Here's a discreet way of downloading an image file from a url on Windows only - using vbs...
                              strFileURL = "http://www.it1.net/images/it1_logo2.jpg"
                              strHDLocation = "C;\Temp\it1_logo2.jpg"
                              Set objXMLHTTP = CreateObject("MSXML2.XMLHTTP")
                              objXMLHTTP.open "GET", strFileURL, false
                              objXMLHTTP.send()
                              If objXMLHTTP.Status = 200 Then
                                Set objADOStream = CreateObject("ADODB.Stream")
                                objADOStream.Open
                                objADOStream.Type = 1 'adTypeBinary
                                objADOStream.Write objXMLHTTP.ResponseBody
                                objADOStream.Position = 0    'Set the stream position to the start
                                Set objFSO = Createobject("Scripting.FileSystemObject")
                              If objFSO.Fileexists(strHDLocation) Then objFSO.DeleteFile strHDLocation
                                Set objFSO = Nothing
                                objADOStream.SaveToFile strHDLocation
                                objADOStream.Close
                                Set objADOStream = Nothing
                              End if
                              Set objXMLHTTP = Nothing
                              Make a copy of this text in a file that's called say
                              C:\Temp\urldownloader.vbs
                              or another Temp folder etc...
                              Change the first two lines of the text to be the url [I've used a known image_file simply to show that it works] and the folder+filepath to save that file to - in this example I put it into C:\Temp\ too using the same file_name...
                              Now run it from within Ruby
                              UI.openURL("C:\\Temp\\urldownloader.vbs")
                              In Ruby wait till the file arrives - timeout after a while ?
                              To tidy up you can delete the temp file...
                              It works - I have run it successfully...
                                Jim
                                Nothing is easy. πŸ˜†
                                You have the right idea, but I think you may need to add more locations to make it complete. If you check the $LOAD_PATH of your installed Ruby, you'll find it has more locations than just those you listed. See Dan's post on the subject. We should have more success using the installed Ruby since we now have 1.8.6 in SketchUp and an installable 1.8.6
                                  Jim
                                  VBScript will run in the WebDialog, so you could eliminate the external file. But I would still try to follow Thom's advice, use JavaScript, and pass the data to the Ruby plugin to save it on disk.
                                  • TIGT Online
                                    My 'vbs' method means you don't actually need a web-dialog running at all.
                                    You can download images from a url with it [on PC] irrespective of what the Ruby script is doing or has as an interface... πŸ˜•
                                      Jim
                                      @tig said:
                                      [on PC]
                                      Exactly.
                                      The most beneficial result from this thread would be a cross-platform download library which could be used for images or anything, really.
                                      • TIGT Online
                                        But the original inquiry was 'for PC' ?
                                        A pure Javascript version can't work [?] - because of security issues there is no plain 'save' - only 'save_as', to you ensure you know what's going on with downloading things off the www onto your PC...
                                        The 'vbs' method will work for PC - there's probably an equivalent AppleScript [type] method for the MAC... but I can't see how a 'cross-platform' version might work πŸ˜•
                                        Java is inherently 'limited' as I said...
                                          Jim
                                          I think it can. There is no save or save as in JavaScript. You can save to disk using JavaScript, but there isn't a cross-platform solution. On Windows, you would use a FileSystem activex object. The same scripting host that rtuns the .vbs can run .js also.
                                          But, the XHR is available on all (important) browser platforms. So a cross-platform solution is to use a WebDialog, fetch the file using the XHR, then pass it to the ruby plugin for saving to disk.
                                          This small library is a good example of using a XHR cross-platform:
                                          http://code.google.com/p/microajax/
                                          if (window.ActiveXObject)
                                          return new ActiveXObject('Microsoft.XMLHTTP');
                                          else if (window.XMLHttpRequest)
                                          return new XMLHttpRequest();
                                          return false;
                                          • TIGT Online
                                            What's this then ?
                                            <a href="java script&#058;void(0);" onclick="document.execCommand('SaveAs',true,'http://fileden.com/somefolder/some file.mp3');">download</a>
                                            There's just not a 'Save' version ???
