    [Plugin] Select by Material, and Hide All Unselected
    31 Posts 15 Posters 50.6k Views 15 Watching
      πŸ‘
      It can be ver useful when someone is modelling for GE for instance, too (like in this topic).
      Models sometimes get rejected for "incomplete texturing" when the modeller misses to texture a face or two somewhere in the model.
        kwalkerman
        Thanks for all the positive feedback.
        Bob - the tool should work to select materials within groups. However, if you are currently in component or group edit mode, it will only look at entities within the current workspace. Try exiting all components and running the plugin again. If this doesn't work, try it on a simple model... and let me know how it goes.
        CadFather - I can add something like this... Just give me a few days. Weekends are for construction.
        Karen
        • CadFatherC Offline
          CadFather
          thanks Karen and take your time..
          • Bob JamesB Offline
            Bob James
            In the attached picture I have:
            1. Clicked on the tile material in the model
            2. Noted that there are 46 faces with this material
            3. Clicked on the tile material in the Material Editor
            4. Clicked on Material Selection in the Plug-ins
            Nothing selected-nothing hidden ❓
              CadFather
              there are 2 menus in the plugins, one to select and one to hide - they don't work together at once
              but it all works fine on my SU8, WinXP
                kwalkerman
                The more I think about the option to 'get' the material under the cursor, the less it makes sense to me to add it into the plugin. I really like the fact that you can choose a material from the materials browser for selection. This way, you can choose to select something that you don't want in your model (or can't find), such as unpainted surfaces.
                If you left the current functionality, and added the ability to get the material under the cursor, this would add a step to the process, which makes it no better than doing the following:
                1. Pick a material with the built-in SU picker
                2. Select materials
                Let me know what you think.
                Karen
                  CadFather
                  Hi Karen, i was thinking it could be fast right-clicking and select by material - though this way works just fine
                    kwalkerman
                    Bob - I sent you a PM, asking to see the model you are having difficulty with. Did you get everything figured out?
                    Karen
                      Ben Ritter
                      Karen, thank you. Great!
                        Ben Ritter
                        Karen,
                        I have the same problem as Bob. Other materials are not hiding. I'm using version 8. I tried it with the default entity Susan. Ben
                          Bob James
                          Karen,
                          Thanks for the offer to look at my model, but I think I have it now:
                          So the sequence is to make the material active, use "Material Selection" and then use "Hide All Un-selected".
                          CadFather: I did not see the other entry in the plugin list: "Hide All Un-selected".
                          That's sort of an unusual approach. I would suggest that the "Material Selection" entry have a fly-out menu for the Hide option.
                            kwalkerman
                            Bob (and CadFather),
                            I wanted to leave them separate because I thought 'hide all unselected' could be useful for other applications... But I think I can figure out a fly-out.
                            Karen
                              CadFather
                              i for one prefer them separate
                              • McGyverM Offline
                                McGyver
                                You rock!! I'm finishing up a huge model and just this morning I was thinking I wonder if there is anything that could... well, do what this ruby does!! THANK YOU!!
                                Visit My ShareCG Freebie Gallery
                                  Bob James
                                  I yield to the power πŸ˜„ (As long as they stay together in the plugin list)
                                    ahnvtk
                                    This is useful, thanks. πŸ‘
                                    One limitation: it seems as if this will only select faces with a material if both sides of the face contain the material. For inconsistently textured scenes that would mean the material is overlooked.. Maybe it could have two modes: one where it will select only faces with the material on both sides, and another that selects faces if the material is on either side?
                                      kwalkerman
                                      Right now it looks only at the front side. I could do another run that looked at the back side, if that would help?
                                        ahnvtk
                                        (Extremely late in reply - sorry)
                                        Yeah, that would help - and then two options or modes depending on the result. 1) If the material on the back side is the same as the front, group it with everything else that has that material. or, 2) If the material on the back side is different, group it separately (in a group with all faces that have this back/front combination). That would be great.
                                        • O Offline
                                          OG1
                                          I know it's been a while since this topic was started and posted in, but I just had to say THANK YOU!!! This plugin has saved me from going more mental! The meshes I make need to be low poly, so using both sides of a face is mandatory! It usually has a different texture on each side. After I export my mesh, the editor I work in reports if I have unpainted faces and prevents me from continuing with my submission. I sometimes go bonkers trying to find the unpainted faces. They are usually small faces, faces that shouldn't even be on the mesh, or like the post in the other thread, "couldn't see the forest through the trees"! πŸ˜„
                                          The one thing I couldn't do, was to unhide the faces I hid, without doing the 'Undo'. (unless I missed something?) Anyways, not a problem doing that, since this plugin has just saved me hours, if not days, trying to find those little buggers.
                                          Sorry for the long reply, but I am extremely grateful and thankful for this plugin, as with all the others in here that make my life easier. This one just made me saner! Thank you!!!
                                          I got my bill for paying attention. I got robbed!
                                          • dereiD Offline
                                            derei
                                            Nice one! And useful !
                                            It would be neat to have some visual clues about where is the selected "thing", like thomthom's Solid Inspector. In this way, it would me much easier to navigate in the place. On a large model, to hide everything is a time-consuming operation. Also, to unhide everything after that is nasty, if there are a lot of nested entities.
                                            DESIGNER AND ARTIST DEREI.UK
