    REQ: IMAGE TO POLY MAPPER
    15 Posts 5 Posters 1.9k Views 5 Watching
      hm... I've never used it myself.
      Tried it now - but I could not get it to work either - using any format. It appear to make some incorrect assumptions of the file formats. I'm not sure what application creates the files in the format it expects. It doesn't like what PS makes.
        I see some post about the format file pmg
        it must saved with Xnview with ascii option
        And make your test with very small images because DIdier said that is very long to generate!
        on for the plug it's writed only for the V6 ??
        but for me I have nothing on my screen any box option or menu after loading the image in SU by the plug 😮
          silver_shadow
          would have been awesome if we had something easier to work with...
          less hassle.. lol
            silver_shadow
            i found a way in max, and can bring it back, just wondered if there were something usefull in su like a plugin that works...to cut out the hopping around in apps.
            Hey guys,thanx for the help, much apreciated. 😄
              I had some code from Vertex Tools that read BMP data - just hacked it to generate a point cloud:
              to
              Just gotto do a couple of tweaks to make it make a mesh instead.
                  Experimental plugin:
                  http://forums.sketchucation.com/viewtopic.php?f=323&t=31339
                  Will refine it later.
                    It works just like a displacement map:
                    White is high points - black is low points
                    Then you have shades of grey for everything in between ( a RGB values of RGB( 128,128,128 ) would mean the height for that point is at 50% of the max height.
                    See example in main thread: http://forums.sketchucation.com/viewtopic.php?f=323&t=31339&p=275954#p275954
                    • EarthMoverE
                      EarthMover
                      Charly, try scaling it down on the Z. Worked for me.
                      Content Creator at Skapeup
                      • charly2008C
                        charly2008
                        Hi Thomas,
                        i tried your plugin but i got a strange result. After manual down scaling see the second image.
                        Charly
                        • charly2008C
                          charly2008
                          Thomas
                          It is a very promising tool. I would like to use it especially for three-dimensional reliefs.
                          Earthmover, thanks for your advice
                          • charly2008C
                            charly2008
                            A second try.
