    Internal Illumination
    20 Posts 6 Posters 4.1k Views 6 Watching
      richcat
      Hi Alex
      The Aidan Blogspot - there is a link by d12dozr fourth post down above, I missed it when initially reading. πŸ˜‰ mistook it for large signature.
      It's about a traffic light, and how he got the green light to "glow", and what obviously intrigued me was that he painted the inside of cowl with dark green to get effect of light spill which got me thinking how to create a gradiented glow - that reminded me of right context click texture edit export for editing in your chosen paint program (making texture unique first). I have been playing around with gradient textures, and thought I could use the circular one in PS as a fake glow from a fake red lighting, which then auto imports in model to replace original, when you save in PS. Apologies if you already know this.
      Same idea when I saw how Jeff did his shadows.
      Now to work out yours ❓
      • jeff hammondJ Offline
        @shura said:
        This getting really interesting, so here is mine for you to guess - with shadows not drawn and default material only...
        [attachment=0:1e5qseaa]<!-- ia0 -->guess.jpg<!-- ia0 -->[/attachment:1e5qseaa]
        is there no plane drawn on the screen and we're just looking through the wall and seeing the adjacent wall? (with the wall in back actually being an opening?
        Edit- oh wait, that would take some tricky lining up to prevent the sun from shining through and messing up the ground shadow.
        • shuraS Offline
          shura
          Oh yes, just realized it's the same traffic light you meant. You put a lot of thoughts in between, I didn't get it 😳
          Beautyful idea still.
          Tadaa! here is the key: just drawing lines to the camera and adding a face that recieves sunlight. Wonder how to get the keystoning for the TV material right...
            Ha, awesome
            How do you figure out where the camera is?
            • shuraS Offline
              shura
              Either with "film and stage" plugin, "note camera location" plugin, or with "BMVB" by Thomasz
                BMVB... good one
                your technique with a skewed/distorted picture...
                scene1 tab lines everything up properly
                πŸ˜†
                http://homepage.mac.com/jeffhammond/.Public/scf/curb_skew.jpg
                • shuraS Offline
                  shura
                  Wohoo, well done Jeff!
                  While we are taking off on this so passionately (wich in fact I enjoy a lot!) we still do not know if it is of any help to our friend Jhearcht...
                  ...Please give us a sign Sir, animation or stills?
                    jhearcht
                    I tried the stoplight technique, but I must be missing something. I placed a rectangle on the shaded side of the building, and turned off cast/receive shadows. But the face is still shaded due its position. I haven't found a way to turn-off shading for a single face. It's on a separate layer, but the Use Sun For Shading function seems to be global, regardless of the layer.
                    PS---Due to various other SU6 limitations, I finally upgraded to SU8. Does it have any new capabilities that might "shed some light" on this situation? πŸ˜‰
                    PPS---I found that a yellow face looks brighter in shade than a white face. Fortunately, yellow is one of the school colors.
                    • shuraS Offline
                      shura
                      Hi again,
                      When geometry casts shadow ON ANOTHER face - then you can prevent that geometry from casting shadow elsewhere by unchecking "Cast Shadows" for the geometry (2nd picture).
                      The stoplight technique works by preventing the respective face from recieving shadow FROM OTHER geometry by unchecking "Recieve Shadows" (3rd picture).
                      However, in your case we are not talking about a shadow that is cast somewhere else. The side of your face is simply not recieving sunlight in the first place - if you want, it casts the shadow on itself (don't know the right word for this, my translation would be "body shadow").
                      It seems that Sketchup cannot switch this off separately.
                      There are a few workarounds to produce stills like we have described before, but if you want to create an animation with shadows displayed (exept for your screen), then it looks like you have to do it in post process or just turn your model to have the screen face the sun.
                      happy if this helps
                      alex
                        jhearcht
                        I had given up on the idea of showing internal illumination of an LED-TV screen on the shaded side of the building. But I just discovered a glitch that looks like internal illumination. The first image is the normal image with two signboards. The second is what happened while I was playing with the UTC setting for time of day. The rendering would stop with everything dark except the screen facing the sun. Then after a few random clicks, it would render properly.
                        I don't have any idea what's going on here. But maybe someone can figure out how to take advantage of this anomaly to simulate internal lighting for an object in shade.
                        Normal View :
                        http://home.mindspring.com/~gnomon/LED signboard_in shadow.jpg
                        Glitch View :
                        http://home.mindspring.com/~gnomon/Dark wall_bright screen.jpg
