    [Solved]Why cant I export materials while a simple cube can?
    3 Posts 2 Posters 929 Views 2 Watching
      TheOwl
      If I just create a simple cube and put a different color for each face and export as an OBJ, the exported model contains all of the 6 materials as you can see below.
      http://img805.imageshack.us/img805/9818/ex2b.jpg
      Now if I create a complicated model. The materials exported is only one! 😲 I need to export all of the materials I made, is there something missing or this is a limitation in SU?
      http://img715.imageshack.us/img715/1546/ex1un.jpg
        TheOwl
        I got it. See this:
        Error 404 (Not Found)!!1
        (www.google.com)
          Since that link doesn't directly point to your answer and someone else searching here may want to know, the materials don't appear because you painted them onto the back faces in your second example. The OBJ export only shows materials on the front faces.
