    Close Group to Solid Object Question.
    4 Posts 3 Posters 412 Views 3 Watching
      razer
      Hey guys
      I was wondering if there are any plugins for something like this. I am trying to make it so that when I cut a wall up that from where I cut it it will then create a face for me there. This is what I mean ( pictures can make 1000 words) πŸ˜› I would still like to have my walls together just that the program I want to export them to needs to be to a simple block type style.
      http://img521.imageshack.us/img521/5192/82344078.jpg
      http://img830.imageshack.us/img830/2482/93410847.jpg
      http://img210.imageshack.us/img210/5572/97496454.jpg
      http://img842.imageshack.us/img842/1879/74064869.jpg
      Thanks for Reading
        Hi Razer,
        I am not sure what exactly the problem is in the last picture. Could you also attach the file and explain?
          razer
          When I start cutting up the wall with lines it then leaves a opening at the end of where I had cut it. I dont want that to happen when I cut it I would like it to place a face on both sides of where it was cut that way it is not hollow if you understand what I mean πŸ˜›
            Why not draw the lines across the top as you show in your second image and then use Push/Pull to push the angled portion down to eliminate it? That will leave you with the faces on the ends of the remaining walls. You could also draw the cut lines on the bottom of the walls and simply erase the edges in between. No plugin needed for either method.
