    Trapping error messages
    10 Posts 3 Posters 367 Views 3 Watching
    • honoluludesktopH Offline
      honoluludesktop
      When I group = entities.add_face (my_face_points), and my_face_points are not coplanar, the application crashes. The API indicates that:
      if (group)
        puts "OK"
      else
        puts "Failed"
      But that didn't work for not coplanar. Is there any way to trap the error message, and continue running the application?
        begin
          ### try to do something
          group = entities.add_face(my_face_points)
          result="OK."
        rescue
          ### what to do if it fails
          result="MISERABLE FAILURE!"
        UI.messagebox(result)
        πŸ€“
          1. why are you naming the variable group when you get a face in return?
          2. avoid space between method name and brackets.
            honoluludesktop
            Thanks fellows, I will try to run with those tomorrow. Tom, perhaps I should have written my_faces in place of group.
              It's much easier to follow the code when the variables aren't ambiguously named.
                honoluludesktop
                You are right, at the time it seemed OK, sorry:-(
                  honoluludesktop
                  TIG, Works great. I guess I now have to be careful not to bypass any errors that destroy the data base, and crash SU or the plugin:-)
                  I tried the following to aid debugging, but the failed command would not run after the Ruby panel opened.
                  begin
                    group = @entities.add_group(@my_entities)
                  rescue #comes here when @my_entities is not a "add_group" entity
                    result = Sketchup.send_action "showRubyPanel;"
                    group = @entities.add_group(@my_entities)#this did not run
                  But I have lots of other uses for it, Thanks.
                    This is a fuller example using multi-rescues
                    begin
                      # .. the process
                    rescue SyntaxError, NameError => ex
                      print "String doesn't compile; " + ex
                      # .. tidy up
                    rescue SystemCallError => ex
                      print "System Call Error; " + ex
                      # .. tidy up
                    rescue StandardError => ex
                      print "Error running script: " + ex
                      # .. tidy up
                    ensure
                      # .. this is for a 'tidy up' when there's something 'wrong'
                      # .. BUT it's NOT an 'error' per se
                      # .. e.g. f.close unless f.nil?
                    If you are using it for 'testing' code then just keep the Ruby Console open...
                      honoluludesktop
                      TIG, Thanks, is there a way to open SU with the Ruby Console open? Or, do you debug by keeping SU open, then cut and paste to the Web Console?
                        Add Sketchup.send_action "showRubyPanel:"
                        into the start of your script just after require 'sketchup.rb'
                        BUT remember to ### it out when you are done!
