    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 608.6k Views 92 Watching
      Sounds like a good feature. πŸ‘
      • EarthMoverE Offline
        EarthMover
        Thanks.
        Regarding the deselect, I was thinking that if you could hover select with the transform tools that it would be useful to quickly clear the selection without having to access the right click menu, but I guess it would be irrelevant if it acted as the native tools and allows you to manipulate a vertex and then release the selection. So simply, I was just looking to have the vertex move tool be able to utilize it's soft selection to bounce from vert to vert if all verts are deselected, in the same way the native move tool does.
        See here - http://www.screencast.com/t/OTRmZGM1MjA
        Content Creator at Skapeup
          EarthMover
          I've been playing with vertex tools most of the afternoon and wanted to say thanks again. Well worth the $20, as I've been telling all my designer friends who use sketchup.
          In the future, any plans to add a collapse vert or target weld?
          Also, possible to add scaling from center with the shift key, similar to native sketchup?
          Looking forward to the gizmo.
            Yes.
            I should put up a list of what I have on my todo list.
            Scaling needs much better options than it currently has. Doesn't even let you scale non-uniformly. 😞
            But the gizmos should be a great improvement to manipulation control. I have another plugin in the works which will act as prototype for the gizmos.
            • Bob JamesB Offline
              Bob James
              would of been sweet if i could've made the plane then chose (either via a single vertex or some other kind of input) which height the plane would be leveled at..
              other uses might be for cutting a level tract in the side of a hill for instance..
              i dunno, not that important but just an idea.
              +1
              I spent a lot of time on my current project using Vertex Tools doing just as Jeff described: make planar, create a reference plane for rotation of the sloped plane, rotate the plane. Jeff's idea would have been really useful πŸŽ‰
              I also had considerable difficulty making the move tool move in the direction I wanted to go. Operator error?? I tried the up arrow key, but that doesn't seem to have any effect. Guess I need some guidance TT. πŸ˜‰
                @bob james said:
                +1
                So instead of best fit plane - you want to project the selected vertices to a user defined plane?
                The arrow keys didn't lock the movement to the axis?
                  Bob James
                  Yes, that would be great: perhaps by selecting one of the vertices as "this height".
                  Not that I could tell. I'll check it out more today to be sure.
                  It would also be very useful if I could "say" move this vertex to "this spot".
                    ? what do you mean by "spot"?
                      Bob James
                      Spot: one of the vertices in the plane
                        I'm confused to what you describe, this just sounds like a normal Move operation to me... ?
                          Bob James
                          TT,
                          I was unable, with any repeatability, to "grab" a vertex and move it to coincide with another vertex: the purpose being to close up an opening in the mesh.
                          Basically, I was unable to control the arbitrary direction I needed to move in order to connect with the other vertex.
                            hmm...
                            so axis lock doesn't work for you?
                            and move doesn't work? (select a vertex, activate Move, click on the vertex when the inference snaps to it and click on another vertex?) ❓ πŸ˜•
                              Would you be able to record a video?
                                Bob James
                                @thomthom said:
                                hmm...
                                πŸ˜•
                                Not always
                                @thomthom said:
                                hmm...
                                Sometimes
                                  Bob James
                                  Yes, as soon as I can after word today (or tomorrow πŸ˜‰ )
                                    That would be great. Since it's intermittent, as you report, the trigger could be under some circumstances which I'd not use it - so being able to see in-action use would help immensely. πŸ‘
                                      Bob James
                                      One thing: If I have a whole row or pattern of vertices already selected and want to move them (let's say "up") what does it mean when it says, "Pick two points to move......."? I've already several points "picked"????
                                        I matched the same text for Vertex Tools with the text SketchUp display for it's tools. Works just like the native Move tool.
                                        A "point" is a point in 3d space.
                                        What you select (with Vertex Tools) is a "vertex".
                                        (I had trouble with this when translating to Norwegian, as the words one would pick for both translated to the same word.)
                                          Bob James
                                          It turns out that the problem (in addition to the standard numbness of my brain) appears to be the computers I am using.
                                          At work (where I really need your tool) I have a three-year-old Mac Pro running Win7 under Boot Camp with two 30" monitors.
                                          At home I have an i7 860 and an nVidea GTX480 running two 24" monitors.
                                          At work is where I was/am having all the difficulty. At home it works fine. So I chalk it up to the "antiquity" of the setup at work.
                                          In the simple test case attached, I've put a horizontal "road" around the "mountain" (it really is flat even though in perspective it doesn't look like it) and a flat plain to put the "house" on. I also attached two meshes by lifting and joining vertices to make the final mesh. I had to rotate the flat surfaces in two directions to get them horizontal, hence the request that I be able to select one of the chosen vertices (or maybe even another vertex not in the original group) as the final level for all chosen vertices.
                                          I'm still not really clear on the "two points": is one a vertex and the other a point in 3D space in the direction I want to move?
                                          I'm anxious to see what direction you're going to take this tool: it has great potential.
                                          Simple test terrain
                                            I'm thinking that an extra tool is needed. One where, while you move the mouse about it picks up the normal of the face you point on, like the protractor (which you can use the shift to lock), then when you click you make the selected vertices project to that plane.
                                            A point refer to any 3d point in the model, a vertex is always refereed to as a vertex.
                                            Like the native tool, you click one time for the start of the move and a second time for the end. None has to be anywhere on any geometry.
                                            • 33
                                            • 34
                                            • 5 / 34
