    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 608.6k Views 92 Watching
    • Bob JamesB Offline
      Bob James
      I've now had a chance to give Vertex Tools a try on my "problem" Google landscape. (See my post on the Thea Forum under "Work In Progress")
      What a great tool Thomas ❗ By the time I've gotten a little more experience with it I'm sure it will solve my terrain modification task.
      This task became necessary when I tried to put our facilities on the actual Google Earth landscape. It turned out that the Google landscape does not take into account even major modifications taken when the facilities were built in circa 1980. So, to allow me to place my models on the terrain I must modify the Google Earth landscape to match reality.
      Why? Because I plan to use renders of the models in their "natural environment".
      For anyone that needs some really handy mesh adjustment tools without getting into the middle of Bryce or the like, plunk down the very reasonable $20 USD for ThomThom's Vertex Tools.
        πŸ‘ πŸ˜„
        cheers!
        • EarthMoverE Offline
          EarthMover
          Thomas, I remember seeing somewhere that you were able to assign contextual shortcuts to Move, Rotate and Scale for when vertex tools was open and have them the same keyboard shortcuts for the native tools. I can't seem to make it work. Any help?
          Also, in a future release, would it be possible to have the transform tools select the vertex if nothing is selected, similar to the native SU transform tools? And perhaps a deselect all button?
          Content Creator at Skapeup
            Under the Tool->Vertex Tools menus you find Move, Scale, Rotate and Select - if you reassign your shortcuts to these, then they will activate the appropriate tools inside and outside vertex mode.
            Possible. For the next revision I'm looking into the UI. For instance I'm adding manipulator gizmos. While I do that I can also revise how the tools work with nothing selected. It would fit in with SU's behaviour.
            Toolbar button?
            • X Offline
              xrok1
              will we see a new release soon? πŸ˜„
                Sounds like a good feature. πŸ‘
                  EarthMover
                  Thanks.
                  Regarding the deselect, I was thinking that if you could hover select with the transform tools that it would be useful to quickly clear the selection without having to access the right click menu, but I guess it would be irrelevant if it acted as the native tools and allows you to manipulate a vertex and then release the selection. So simply, I was just looking to have the vertex move tool be able to utilize it's soft selection to bounce from vert to vert if all verts are deselected, in the same way the native move tool does.
                  See here - http://www.screencast.com/t/OTRmZGM1MjA
                    EarthMover
                    I've been playing with vertex tools most of the afternoon and wanted to say thanks again. Well worth the $20, as I've been telling all my designer friends who use sketchup.
                    In the future, any plans to add a collapse vert or target weld?
                    Also, possible to add scaling from center with the shift key, similar to native sketchup?
                    Looking forward to the gizmo.
                      Yes.
                      I should put up a list of what I have on my todo list.
                      Scaling needs much better options than it currently has. Doesn't even let you scale non-uniformly. 😞
                      But the gizmos should be a great improvement to manipulation control. I have another plugin in the works which will act as prototype for the gizmos.
                        Bob James
                        would of been sweet if i could've made the plane then chose (either via a single vertex or some other kind of input) which height the plane would be leveled at..
                        other uses might be for cutting a level tract in the side of a hill for instance..
                        i dunno, not that important but just an idea.
                        +1
                        I spent a lot of time on my current project using Vertex Tools doing just as Jeff described: make planar, create a reference plane for rotation of the sloped plane, rotate the plane. Jeff's idea would have been really useful πŸŽ‰
                        I also had considerable difficulty making the move tool move in the direction I wanted to go. Operator error?? I tried the up arrow key, but that doesn't seem to have any effect. Guess I need some guidance TT. πŸ˜‰
                          @bob james said:
                          +1
                          So instead of best fit plane - you want to project the selected vertices to a user defined plane?
                          The arrow keys didn't lock the movement to the axis?
                            Bob James
                            Yes, that would be great: perhaps by selecting one of the vertices as "this height".
                            Not that I could tell. I'll check it out more today to be sure.
                            It would also be very useful if I could "say" move this vertex to "this spot".
                              ? what do you mean by "spot"?
                                Bob James
                                Spot: one of the vertices in the plane
                                  I'm confused to what you describe, this just sounds like a normal Move operation to me... ?
                                    Bob James
                                    TT,
                                    I was unable, with any repeatability, to "grab" a vertex and move it to coincide with another vertex: the purpose being to close up an opening in the mesh.
                                    Basically, I was unable to control the arbitrary direction I needed to move in order to connect with the other vertex.
                                      hmm...
                                      so axis lock doesn't work for you?
                                      and move doesn't work? (select a vertex, activate Move, click on the vertex when the inference snaps to it and click on another vertex?) ❓ πŸ˜•
                                        Would you be able to record a video?
                                          Bob James
                                          @thomthom said:
                                          hmm...
                                          πŸ˜•
                                          Not always
                                          @thomthom said:
                                          hmm...
                                          Sometimes
                                            Bob James
                                            Yes, as soon as I can after word today (or tomorrow πŸ˜‰ )
                                            • 33
                                            • 34
                                            • 4 / 34
