    Windows 7, Sketchup 8 and SP 3 issues
    28 Posts 12 Posters 8.3k Views 12 Watching
      CPhillips
      Yoiks. SP3 isnt working with SU8?? Can someone tell me how to repro the crash and I'll fix asap.
        @jaysax: In the Save As dialog you can save to older .skp formats.
          CPhillips
          Maybe its conflicting with Twilight Render. Could you try it without that plugin?
            CPhillips
            I have a new version almost ready. But I cant release it until I know why it sometimes doesn't work with SU8
              Are you getting errors?
              Have you checked the code for the stricter syntax Ruby 1.8.6 require?
              Or checked the Ruby 1.8.6 changelog for other info on changes in the core?
                CPhillips
                It seems to work fine on my copy of SU8 Pro. No crashes or unusual errors or warnings in the console. Maybe its a OS thing. I am running Vista.
                Does anyone else find it less stable than in SU7?
                  Maybe if one of the people with problems can send you their plugins folder and you can test that? Maybe there is a third-party plugin causing problem...
                    mptak
                    Sometimes the stars just align.....Chris, go ahead and release it. You know you want to. Throw us your adoring minions a bone. Hope all is well with life and coding.
                      camokid11
                      hi, within this post http://sketchupusers.vacau.com/index.php?topic=115.msg1292#new there is a link to a dropbox which has Sketchup 7 installer file (just look through it and find the link)
                      thats if you want Sketchup 7 back.
                      If you can read this, thank a teacher.
                      If you can read this in english, thank a soldier.
                        bossdave
                        I have the same problems. Using Win7,SU8, SKP3. Only SKP# and default plugins are installed.
                        Dave
                          CPhillips
                          Maybe its an issue with Win7?
                            CPhillips
                            Can anyone who has SU8 and Win7 confirm whether it does or does not work?
                            • H Offline
                              hpnisse
                              I've got the simulation to work with:
                              Sketchup 8
                              SketchyPhysics 3 (last version I think)
                              And it runs on a computer with this:
                              Processor: Intel Pentium 4 - 3.2GHz
                              RAM: 2.5GB
                              OS: Windows 7 Ultimate 32-bit (86-bit)
                              So the simulation is slow but it works fine. (only slow in big physics models, if the .skp file is over 1MB)
                              And I had no other (heavy) plugin like Twilight or somthing like that.
                              /hpnisse
                              ` /hpnisse`
                              ` Windows 7 U -Sketchup 8 -SketchyPhysics 3.2-Dec2 - from Sweden`
                                CPhillips
                                Gah! I dont want to have to upgrade to Win7 just to track this down. Does anyone happen to have Win7, SU8, SP3 and Visual Studio 2005+ installed? Long shot I know.....
                                Hpnisse you said it was slow with big models. Slower that SU7 with the same model?
                                • H Offline
                                  hpnisse
                                  No, it was the same thing with SU7, so I think that probably is the computers fault.
                                  ` /hpnisse`
                                    jblively
                                    It's very random. On a given full day of working, sketchy physics will crash sketchup 7-8 times. Always while in run mode, and never at the 'start' of the simulation, usually a couple minutes in.
                                    I don't have visual studio, sorry.
                                    Using Win 7, Sketchup 8 and SP3.
                                      CPhillips
                                      Well this sucks. I finally managed to find a model that would crash SU8 and not SU7. But it is crashing deep in the physics engine and I have no way to debug it.
                                      At least this crash is not in the Ruby differences. It may be a bug in SU8 or it maybe a bug in the physics engine. Either way I don't see how I can fix it.
                                      This model always crashes SU8. If it doesn't crash your SU8 could you let me know.
                                      su8crash.skp
                                        mptak
                                        In the immortal words of Marty Feldman....
                                        Could be worse.....could be raining.
                                        Thanks for your incredible work and passion for your invention.
                                        I guess I'll just need to fill real sandbags now.
                                          phy
                                          Can you pm me a file that isn't working? Since I have Win 7 and sketchup 8 and it seems to work ok.
                                          Tableau de comparaison de Staxyn s'agit d'un mΠ“Β©dicament uniquement sur ordonnance.
                                            Barack
                                            Well I can't send my Plugins folder, but I can tell you what plugins I am on. These might be causing my recent crashes:
                                            Sketchyphysics 3 RC1
                                            Lazyscript 1.3083
                                            Select at Startup
                                            And, of course, all of the Sketchup 8 ruby examples.
                                            Hope this helps,
                                            Barack
                                            I'm a Sketchup Free user, nothing else. 3DS is way too expensive, and Pro, ditto. What else do you expect?
                                            UPDATE: I have some blender knowledge, that is why this signature is edited.
