    SketchUp for iPad
    30 Posts 20 Posters 45.9k Views 20 Watching
      dylan
      Some sort of viewer would be very useful.
      Its a nice thought being able to show your client or tutor etc your model on the ipad.
      http://dmdarchitecture.co.uk/
      • bmikeB
        bmike
        do iPads handle PDFs?
        you could print to a 3d PDF. been using it with clients. not the same control as with a sketchy presentation, but the plugin i'm using saves out views, etc... you can measure, create section cuts (it doesn't seem to transfer them from sketchup 😞 ) etc.
        • G
          gsmith
          You might want to check out 3DVIA Mobile on the app store. The 3D app allows for viewing of SU models on your iPhone and iPad (with the iPhone app).
          ... and yes I work for 3DVIA but thought this would help.
          • Greg
            Aerilius
            I don't know, but does the iPad have Adobe's pdf viewer?
            Rhino CAD has a viewer for the iPhone and iPad. there is a trial of Rhino CAD for the PC that allows you 25 saves and you can also open your sketchup files in there. Basically open your sketchup file, save as a rhino file and open with the viewer.
            There is also an app called "NaviCAD" available on the iPhone and the iPad which similarly allows you to view SketchUp models. It isn't quite as polished as the Rhino viewer, but it might be worth a look.
            However SketchUp (besides Android, Windows and Linux Apps) will certainly run on a WeTab.
            I'm very curious if Google will create a solution that will work on all the other new devices.
            • X
              xrok1
              NAVICAD: http://www.navicad.com/NaviCAD/Welcome.html
              http://www.navicad.com/NaviCAD/Media/animation smaller.gif
              IDOL: http://rusidol.com/portfolio.aspx?id=32
              http://rusidol.com/screenshots/2C48-982B-A369-4382-97C9-7A46-F43F-F984.jpeg
              unity3D: http://forum.unity3d.com/viewforum.php?f=23
              seems as though unity3d is availiable for iphone/ipad as well. πŸ˜„ so maybe someone familiar with it can make a viewer (or has already).
              • aadbuildA
                aadbuild
                The coolest time saver for me would be if a very basic version of Su was on android or I pad. I do extension renovation work. I use a laser measurer to measure up houses. It has blue tooth and works with auto cad the problem is the lap top is a pain to carry around the site. If I could have it draw in Su it would save me at least 2 hours per job...
                Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
                https://www.plusspec.com
                • aadbuildA
                  aadbuild
                  now I think about it the laser would have to output a file to use in CAd so I wonder if I could just put the out put files into the ruby console. hmmmm now that could be a great ruby. anyone else done anything like this?
                    Someone did talk about how he used a laser device that sent keystrokes to applications. Used that to adjust the length of edges.
                    http://forums.sketchucation.com/viewtopic.php?f=323&t=28439
                      stonebreaker
                      Google released a SketchUp 8 Viewer for PC and Mac....now it would be really nice to see it for the ipad. πŸ˜„
                      • honoluludesktopH
                        honoluludesktop
                        Google's Beta Web stuff with a viewable SU model on the ipad (or anything else) is here. Run the download. It's harmless, I promise your computer won't break. Don't know why Google requires this procedure. Nice if the SUcation page can be set up to support it. If you end up at "error", refresh your display to get the download panel.
                        • W
                          wyatt
                          The people who represented Podium at 3DBC this year had an iPad viewer for sketchup. As they moved the iPad the camera within the model moved in realtime. I don't know if they could do realtime walkthroughs, or just see the model from a stationary position, but regardless, it was pretty cool. Did anyone else see this and have any more info?
                            stonebreaker
                            that would be cool...any news?^^
                            • Mike LuceyM
                              Mike Lucey
                              Yep, it caught my eye also. The lady showing 'Sketchers Walk' was Masako Tanaka from Alphacox in Japan. I tried it out and found it fascinating. It was like viewing an SU model through a small window that one held in their hands. As you moved the iPad up / down and from side to side it showed different parts of the model. It was also possible to zoom in and out and directly 'move into' the model further.
                              I understand its in Beta now and Masako has advised me that she will keep me informed on progress. I'm looking forward to seeing the final application and think it will be very useful for showing SU models to non techie clients as all they need to do is hold and slide their finger on the screen πŸ‘
                              Mike
                              PS: I imagine it will not break the bank as iPad Apps are reasonably priced.
                              • Mike LuceyM
                                Mike Lucey
                                .... tried it and it works fine. I will explore more and show some shots πŸ‘
                                  Masako
                                  Hi Mike and others
                                  Hello,
                                  I am sorry that I can not reply to your email.
                                  I did not notice your mail. Because your E-mail has saved the folder of the junk e-mail on my mailer.
                                  That iPad App is beta yet, we must update it until release, so I will send the email when I can give sample file to you.
                                  I will give you app of iPad for test in near future.
                                  Please send it to me if there is a model of SketchUp that you want to convert for Ipad.
                                  I had sent the email to you, but mail returned though I sent you mail ahead.
                                  The following messages reached. "553 sorry, that domain isn't in my list of allowed rcpthosts (#5.7.1)"
                                  Masako
                                  • Mike LuceyM
                                    Mike Lucey
                                    Hi Masako,
                                    Good to hear you are moving ahead with SW and I am sure the guys here will be interested seeing the finish product.
                                    Sorry that my email account did not work for you. I will try to contact you via my gmail account or you can contact me via Private Message [PM] here.
                                    Mike
                                      silver_shadow
                                      its not much...but it looks like a start
                                      Invalid URL
                                      (itunes.apple.com)
                                        3dsketchupper
                                        I downloaded 3dvia on my ipad.
                                        limtation in file size and won't read sketchup format.
                                        But you can export to collada or obj. Not really impressed
                                        with the apps.
                                        I'll try Navicad
                                        You know what if you really want to view sketchup on your ipad or iphone export animation from sketchup and convert format to read iphone and ipad mp4. works fine for me and i can stop and slide animation if i want to.
                                        • EscapeArtistE
                                          EscapeArtist
                                          There will be a way to view and position SU models on an iPad or iPhone using AR: http://limitlesscomputing.com/SightSpace
                                            dmatho
                                            Actually, all we have to do is convince Google to support the SKP file-format in Google Docs.
                                            By the way, since earlier this year Google Docs already supports DXF (AWA AI, SVG, PSD and other formats); meaning from SketchUp, via "Save as..." to Google Docs offers a current solution for simple web-based 2D-viewing, i.e without any 3D navigation.
                                            Cheers,
                                            . Diego .
