    [Plugin] Rotate 90 around [X, Y, Z] axis
    49 Posts 28 Posters 62.6k Views 28 Watching
    • H Offline
      HFM
      whoops double post, sorry for that [as mentioned below it is late 🤣 ]
      • tbdT Offline
        tbd
        daiku: dont reinvent the wheel, extend it 😄
        here is my old 2004 script for start
        Rotix11 - 2004 script
        http://plugins.ro
        • philemP Offline
          philem
          I downloaded the latest version of this ruby and it worked.
          thanks mate..
          Just do it, it might be fun.
          • daikuD Offline
            daiku
            Yes, that would have been better. I was not aware of this script. This seems to be a recurring theme. What we really need is a central repository that includes detailed descriptions of what each script does, along with detailed usage instructions. There are several collections around, including on this forum, but nothing that does a complete job. I realize this would be a huge undertaking for someone, but whoever steps up would certainly earn "hero" status in our community.
            Clark Bremer
            http://www.northernlightstimberframing.com
              tor
              Many thanks for this simple, yet very useful plugin... exactly what I was looking for when creating some configurations of modular components.
              What I think would be really keen is to be able to call this script as one is placing a component from the component browser. Any ideas on how to make that work?
              Tor
              • daikuD Offline
                daiku
                Not sure what you mean. Do you want to rotate EVERY time you place it? Just re-create the component with the correct orientation to the local axes. CB.
                Clark Bremer
                  tor
                  Well, what I was hoping for is to select a component from the component browser to place into the model, then as it is moving with the mouse at the insertion point, rotate it, so that it's in the correct orientation. Kind of a building block assembly system. And, sometimes a component would need to be rotated, sometimes not.
                  Obviously, I can put the component "down", rotate, then move it, but was just hoping to simplify that process in the creation of numerous modular assemblies.
                  But it seems that the component being placed is not actually selected, per se, so no shortcut key works on it.
                  Tor
                  • I Offline
                    InterArchi
                       Thank u
                    • EarthMoverE Offline
                      EarthMover
                      Is there a plugin out there that will do this to multiple components at the same time? Or one that will rotate each around it's own z axis simultaneously?
                      Content Creator at Skapeup
                      • daikuD Offline
                        daiku
                        Easy change. Updated file at the top of the thread. CB.
                        Clark Bremer
                          EarthMover
                          That was fast. Thanks a ton!!
                            glro
                            @jim said:
                            @hfm said:
                            okay, very nice script... but could you please also make it work on X and Y axis? And make it so that you can select a shortcut for the tools?
                            Tried to edit it myself but my knowledge of ruby is lacking 🤣
                            [did get the 15 degrees to work though 😄 ]
                            I always wanted to make a rotator that is sensitive to the view. For example, it would rotate the selection around the axis that is closest to the axis from the camera to the target. If you wanted ro rotate around the Z, you could select the entities, go to Top view and press the shortcut. If you wanted to rotate around the Y axis, select the entities, go to the Front view and use the same shortcut.
                            What do you think?
                            My idea is that, having to change the view would take away the advantage of having the rotator sensitive to the view
                            I have another suggestion: Rot90.rb rotate the component around (ent.bounds.center); would it be possible to rotate around the origin instead, as you did in your mover2.rb plugin?
                              glro
                              I don't know much about ruby either, but here is a simplified version of the plugin:
                              rotate around the component origin instead of center
                              only around z axis and 90 degrees
                              no context menu, a line in the plugin menu instead (so you can add a keyboard shortcut (pop up menu, window>preferences>shortcut
                              require 'sketchup.rb'
                              ## Rotate selected component instance 90 degrees around Z axis
                              ##  Copyright (c) 2010 Clark Bremer (aka daiku)
                              ##  Northern Lights Timber Framing
                              ##  clarkb@northernlightstimberframing.com
                              ## 05/02/12; rotation autour de l'origine du composant, axe z seulement, acces menu deroulant ou raccourci clavier
                              ## 9/10/2010;	Multiple Groups/Comps
                              ## 5/17/08;  All 3 axes.  Input from Matt666
                              ## 4/24/08; Use center as rotation point instead of CI origin.  Also works on groups now.
                              # Add a menu item to launch our plugin.
                              UI.menu("PlugIns").add_item("rotation90z") { rotate90z }
                               def selected_comps_and_groups
                                   mm = Sketchup.active_model
                                   ss = mm.selection
                               	return nil if ss.empty?
                               	ss.each do |cc|
                               		return nil if not ((cc.instance_of? Sketchup;;ComponentInstance) or (cc.instance_of? Sketchup;;Group))
                                  ss
                              #def rotate90(sel, axis)
                              def rotate90z
                              	sel = selected_comps_and_groups
                              #	axis == "z"
                              	rv = Geom;;Vector3d.new(0,0,1)
                              #	rv = Geom;;Vector3d.new(0,0,1) if axis == "z"
                              #	rv = Geom;;Vector3d.new(0,1,0) if axis == "y"
                              #	rv = Geom;;Vector3d.new(1,0,0) if axis == "x"
                              	ra = 90.degrees
                              	#rt = Geom;;Transformation.rotation(rp, rv, ra) #autour du centre de la boite enveloppe
                              	sel.each do |ent|
                              		# rp = Geom;;Point3d.new(ent.bounds.center) 		#rotation point
                              		rp = Geom;;Point3d.new(ent.transformation.origin)
                              		ent.transform!(Geom;;Transformation.rotation(rp, rv, ra))
                              #if( not file_loaded?("rot90.rb") )
                              #   UI.add_context_menu_handler do |menu|
                              #		if menu == nil then
                              #			UI.messagebox("Error setting context menu handler")
                              #		else
                              #			if (sel = selected_comps_and_groups)
                              #				sbm = menu.add_submenu("Rotate 90")
                              #				sbm.add_item("Around Red") {rotate90 sel, "x"}
                              #				sbm.add_item("Around Green") {rotate90 sel, "y"}
                              #				sbm.add_item("Around Blue") {rotate90 sel, "z"}
                              #			end
                              #		end
                              #	end
                              #end
                              #file_loaded("rot90.rb")
                                Mainline411
                                >      ss = mm.selection
                                >  	ss.each do |cc|
                                >  	end
                                >     ss
                                >  end
                                > def rotate90z
                                > #	axis == "z"
                                > 	ra = 90.degrees
                                > 	sel.each do |ent|
                                > 	end
                                > end
                                > #		else
                                > #			end
                                > #		end
                                > #	end
                                > #end
                                How do I use this plugin I put the file in plugins and there is nothing in plugins dropdown and nothing when I right click.
                                  d12dozr
                                  Great plugin when mapped to a shortcut. Thanks Clark!
                                  FYI everybody, Clark just headed up a local meetup about ruby programming. 🎉
                                  http://goo.gl/f7ooYh
                                  • W Offline
                                    waltersalter
                                    Sorry, does anyone know hot to use this very useful plugin in SketchUp2016? I tried just putting it with other rb files in rooth folder, but it didn't work. Help please!
                                      Kmyklpenter
                                      Hello! Thanks for the plugin! For some reason Im having problem assigning a keybouard shortcut for certain actions. The plugin does not appear in shortcuts list.
                                      How can I do that?
                                      Thank you.
                                        Do you have a group or component selected in the model? Like other Context menu items, you need to have something selected that would make this plugin appear in the menu.
                                        • O Offline
                                          oman3000
                                          hello im a fan of this extension. simple yet useful. im just hope it to rotate even ungroup entities for the next version update. 😄
                                          • V Offline
                                            Vizan
                                            How to make only the axis of a component or a group rotate?
                                            • 2 / 3
