Brain Freeze requires faces help???
I know its going to be a simple answer BUT How can I remove all faces only and leave the forms?
What forms? Edges only?
If so (but this only works in a single editing context so if you have groups, components, you will need to repeat "inside")
- Hide (uncheck) your edges in the Styles > In model > Edit > Edge settings panel
- Select everything with a bounding box (not triple clicking)
- Erase
- Unhide (check) edges again.
You can use Selection Toys to quickly filter your selection: http://forums.sketchucation.com/viewtopic.php?f=323&t=14975&p=114380
How about a wireframe view of the model found under View/Face Style/Wireframe
Sorry I did not mention what I want to do...Iam useing the 3dtext tool to make letters..Then deleating the faces and using the line to tube ruby to turn them into tubes for neon..Works pretty good but open to other ideas...
Well then thomthom's selection tools plugin will be best for you.
Are you already at work?
...of course you are...
See you soon!
