    Looking for a line to pipe plugin
    extensions
    10 Posts 4 Posters 3.6k Views 4 Watching
      Catsmeat
      I'm looking for a plugin that I once had but now can't find. I seem to remember that the plugin added a toolbar with three icons. It turned lines into tubes, but you could specify the number of edges of your tube, so one could make a "box tube" with four only sides. I've searched the forums and google but to no avail.
      • charly2008C Offline
        charly2008
        Hi Catsmeat,
        there are three rubies:
        Lines to pipes (Convert arcs....)
        http://forums.sketchucation.com/download/file.php?id=13860
        PipeAlongPath
        http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=286
        TubeAlongPath
        http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=453
        Charly
          Catsmeat
          Thanks Charly,
          I remember stumbling across PipeAlongPath before and I will enjoy using it again. But unfortunatly none of your three excellent links is the plugin i was thinking of.
            3skeng ? πŸ˜‰
              Catsmeat
              No not 3skeng either πŸ˜ƒ The toolbar had, as I said, three buttons, and each button had the image of a line in persepctive, with either a circle, a star or a square, at the end of that line. The purpose was to quickly create a shape along the line. Sorry if this doesn't make a lot of sense. The reason I want it now is because of the new solid modeling tools. I want to use the plugin to create boxes along the contours of the roof in my model, and then use those boxes to cut roof tiles that are going over the edge. I know creating the boxes can be done manually, but the plugin would be a time saver. πŸ˜ƒ
                Catsmeat
                Yes! That's the baby! Thanks=)
                  Ah! Ok It's a Chris Fullmer plug πŸ˜‰
                  Perpendicular face tools β˜€
                  Select your curve
                  Call the plug
                  Explode the group then use Follow me or other one πŸ˜‰
                  • boofredlayB Offline
                    boofredlay
                    Ah, I was thinking you were looking for this one...
                    http://www.3skeng.com/en/index.htm
                      Yet posted 3 posts above πŸ’š
                        boofredlay
                        D'oh
                        http://www.ausphotography.net.au/forum/images/smilies/Doh.gif
