    [Plugin] Raytracer
    60 Posts 18 Posters 68.6k Views 18 Watching
      You and me both. That is turning out to be a brain twister.
        Panga
        Thanks a lot Thomthom, exactly what I requested a month ago for evaluating covisibility on a terrain !!
        • olisheaO Offline
          olishea
          can you post an example of how this works please? just couple of images will do......pretty please ☀
          oli
            Done.
            I found a bug in my plugin - so you want to update it and TT_Lib2.
            I also found there is a nasty bug in SU8 that cause bogus results in the ray-tracing. I'm looking into this one - trying to work out way to work around it.
              Found a workaround. Please update TT_Lib2 to version 2.1.1.
                Panga
                Thomthom,
                Thanks again for this plugin, but can I suggest you another function for this script. I need to make a raytrace from on point in every direction in order to see where rays intersect a terrain for example. I know that could generates a lot of rays and calculation, but It would be nice to have this function with maybe an option where we can choose the number of rays like : 1 to 10 rays / 10 o 100 rays / 100 to 1 000 rays. If it's possible, the rays should be drawn as guidelines, and a guide point could be automatically drawn on each intersection with the rest of the model.
                I don't know if you can do that...just and idea for my workflow that can be helpfull for others maybe.
                Thanks.
                  I say, yes, it'd be a whole lot of rays. So, would it be like sub-dividing a sphere and shoot a ray for every segment?
                  YEs, can draw them a guidelines, yes. But how many points of origins are we talking about? There'd a huge amount of CLines. Would there be a limit to how far they reached? Would it be ok to draw only the rays that hit something?
                  Do the rays need to ignore other geometry other than the target group/component?
                    Panga
                    For my specific usage, there's two possibilities and the first one of them could be already fanstastic:
                    1. From one point at time
                    2. From one complex object (component or group)
                    Yes, Yes and Yes. In fact I only need to evaluate "covisibility". So I could select a point on my model (or a complex object) and the plugin draw a certain number of rays only where there's intersections with the model, or with a specific component/group if it's easier to implement/calculate.
                    This could be a good solution with a sphere that surrounds the whole model.
                    Thanks for your answer.
                    Regards.
                      I didn't mean to put an actual sphere in the model, just how one would determine which of the infinite possible directions the rays should be shot. What I meant by the sphere was they the ray's be evenly distributed based on how many rays one shoot.
                        Panga
                        Yes I understood you. And controlling the number of segments/faces of the "virtual sphere" could help to have more or less rays. Whatever you can do for that, thanks in advance.
                        EDIT : In fact, what could be really nice is a "sun" or a omnilight that I could place wherever I want in my SU model, and with shadows activated I could see the illuminated parts of my models and the dark ones...
                          I'm writing this down in the todo list. Will see what I can do.
                            hmm.... I'm not quite sure how to calculate the rays to shoot. Been all too long since I've done math like this...
                              Panga
                              My knowledge in maths are very limited...so I'll not be able to help you on that. Anyway, thanks for giving it a try !! 😉
                                Found a solution! 😄
                                  Panga
                                  I had no doubt about that !! 😉
                                    When I say I I mean, someone smarter than me helped me out. 😉
                                      Panga
                                      Whatever if someone helped you or not, you were the one looking for the solution...so you found it ! 😛
                                        artupato
                                        sir Thomthom,
                                        thank you very much for this plugin.
                                        what a coincidence! This day I've been thinking of raytracing and what is its concept. I think I'll understand this once I use your plugin and of course read some notes about it. 😄
                                          grrrr.... SU8 has even more troublesome bug with the raytest method. I'm struggling to find a workaround.
                                          I got the Spray Ray working in SU7 - but SU8 is being a PITA.
                                            Version 1.1.0
                                            • Requires TT_Lib2 (v2.3.0)
                                            • Trace Spray Ray.
                                            • Bugfixes.
                                            Note: SU8 does not process rays properly and the results are not reliable!
                                            I've been unable to work out a successful workaround. 😞
                                            • 1 / 3
