    Mitsuba Physically Based Render
    extensions
    14 Posts 7 Posters 6.0k Views 7 Watching
      Jim
      Found this one through tak2hata's (Make Fur) web site.
      The program currently runs on Linux, MacOS X and Microsoft Windows and makes use of SSE2 optimizations on x86 and x86_64 platforms. So far, its main use has been as a testbed for algorithm development in computer graphics, but there are many other interesting applications.
      Mitsuba comes with a command-line interface as well as a graphical frontend to interactively explore scenes. While navigating, a rough preview is shown that becomes increasingly accurate as soon as all movements are stopped. Once a viewpoint has been chosen, a wide range of rendering techniques can be used to generate images, and their parameters can be tuned from within the program.
      Mitsuba 3 - A Retargetable Forward and Inverse Renderer
      (www.mitsuba-renderer.org)
      • E Offline
        Ecuadorian
        Thanks, JIm. I had to delete the index.html part to be able to load the site...
        The main page shows a lovely image of a "rough dielectric" material (sandblasted glass?).
        I remember "mitsu" means "three units" in japanese. So... what does "ba" mean here?
        -Miguel Lescano
          Jim
          Thanks.
          It supports collada import and distributed parallel rendering, so may be well suitable for a Sketchup render farm. I don't really know much about it, I just thought it might be interesting to someone.
          • EarthMoverE Offline
            EarthMover
            Interesting that it works with .XML files. I tried it with the Thea exporter, but got an error. This looks very promising as a free unbiased renderer.
            Content Creator at Skapeup
            • N Offline
              notareal
              Well... xml is not a universal language. Obviously they use different XML schema 😄 Have to say, there is something I like in mitsuba. Worth to keep eye on.
              Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
              • V Offline
                vidy
                hello notareal,
                can you give me advice to install this render step by step, i already read the instruction, i saw it need quite a lot software to install, please give a clue.. thanks
                it looks interesting on the video demo
                regards,
                still so much to learn..
                • N Offline
                  notareal
                  @vidy said:
                  hello notareal,
                  regards,
                  Don't know your system, but if you are using windows, just download the distribution zip-archive, unpack it and run mtsgui.exe. There no installation. Don't forget to load some example scenes they do provide.
                  I believe this could help http://www.mitsuba-renderer.org/documentation.pdf
                  Disclaimer: This is an early beta release, please don't expect too much.
                  It's really what they say, early beta - but interesting concept.
                  • V Offline
                    vidy
                    im using XP SP3, and when i hit mtsgui.exe i got this message
                    http://a.imageshack.us/img547/6498/15403894.jpg
                    Uploaded with ImageShack.us
                    probably someone know what software should i installed to correct this problem? thanks
                    regards,
                    • N Offline
                      notareal
                      Try to update your display drivers.
                      • V Offline
                        vidy
                        thanks for your suggestion notareal, i think it won't work when i do it at office, my VGA is onboard card,
                        i will try this mitsuba at home.
                        EDIT: already try at home, but don't know how to open a file or import it (same case like earth mover did), anyway its still pre beta right? this software looks going to be a good one as an open source.
                        regards,
                        • E Offline
                          Ecuadorian
                          According to the development blog, the Collada importer is ready but only usable via command line (can't figure out how to do this). It seems like the importer will be integrated into the GUI soon, however:
                          Mitsuba Development Blog
                          -Miguel Lescano
                          • E Offline
                            Ecuadorian
                            The current version can import Collada files.
                            To export from SU:
                            -Make your model a component/group
                            -Right click > Flip along Component's Blue
                            -Rotate it +90º on red axis (follow right hand rule)
                            -When exporting to Collada, make sure "triangulate all faces" is checked and "preserve component hierarchies" is unchecked.
                            In Mitsuba, just go to File > Import.
                            That's it. That's all I know for now. 💚
                            Check the PDF manual. Most of it is technical, but pages 24-25 offer a promising glimpse of Mitsuba's power:
                            http://www.mitsuba-renderer.org/docs.html
                            For now, here's a simple SketchUp model rendered with Mitsuba's Path Tracer in 23 seconds on a Core i5:
                            -Miguel Lescano
                              mozzie
                              Its a green herb/ vegetable, and the FAQ says that the dev was cooking with it at the time and gives this reference (http://en.wikipedia.org/wiki/Cryptotaenia). It does have a sort of 3 lobed leaf, so maybe thats it?
                                Khai
                                shame it's Intel only 😞
                                "Fatal Error: This program was not built to run on the processor in your system. The allowed processors are: Intel(R) Core(TM) Duo processors and compatible Intel processors with supplemental Streaming SIMD Extensions 3 (SSSE3) instruction support"
