    Help With a Grid Beam Dynamic Component
    Scheduled Pinned Locked Moved Dynamic Components
    2 Posts 2 Posters 1.5k Views 2 Watching
    • Q Offline
      QuietStorm81
      Hey all! Love the board and want to help the community with all I figure out.
      To that end, I have an issue. I want to build using the Grid Beam building system and have done a few models using a 1.5 square inch kit of components that a dude on the Warehouse uploaded. But now I want to build a new set using 2 inch extruded sign post. I'll attach the files later so people can see what I mean.
      How can I a component in Sketchup that will expand as I grow the piece from a simple 2 inch block to how ever many feet I need it to be with the ends staying intact?
      • gullfoG Offline
        gullfo
        the way i approach this is to create 2 end caps and a middle component. then i can calculate the length of the gridbeam constrained to the block size and count the number of middle components to copy. see attached.
        to use a different size you could adjust the size value noting that the holes will scale accordingly. or re-size each component manual and adjust the holes and positions etc. if the size of each is not a cube, you might need another attribute to handle the different dimension. e.g. if the sign post is 3x3 but the height is 2, the calculation needs to know the height of 2... in my model it assumes all 3 dimensions are the same.
        to neaten it up i hide the edges on the ends and middle which face each other. i took out the inner geometry as it will overload quickly when lot's of these are used in a model.
        using the gridbeam to create a small wheelbarrow
        dynamic gridbeam component
        Glenn
        http://www.runnel.com
