    Render This - Chair Loft
    112 Posts 55 Posters 32.5k Views 55 Watching
    • michaliszissiouM
      michaliszissiou
      All these are fine renders, excellent job all of you.
      @blajnov: I prefer two chairs here, not three, a sofa is even better. ๐Ÿ˜†
      Well done.
      • B
        blajnov
        Well done.
        Pending a sofa ...
        ArtlantisStudio 3.0.3.2
        Time: 39 min. 40 sec.
        • olisheaO
          olishea
          boxman: i think pugz was talking to me, i guess you are called Oli too right?! I think i saw your stuff on 3dwh....
          i need to have a go at rendering this
          oli
          • GaieusG
            @steve2802 said:
            ...How do you get the soft edge effect on the shadows?
            Maybe there are some tutorials on this sort of thing so if you could point me in the right direction...
            A lot of those suggestions would depend on the rendering software you used but forgot to mention.
            ๐Ÿ˜‰
            Generally speaking, a bigger size light will provide softer shadows in many rendering apps.
              steve2802
              @gaieus said:
              ...I actually just found it through trial and error - there's a soft shadow tick box in the sun settings - can't believe I didn't see it before...
              ๐Ÿ‘
              OK, if you check that box, you are going to get soft shadows. Now how soft they should be is up to the sun radius that you can also control.
              Note that soft shadows will increase render time a bit (the softer the longer). This scene would also be a cool one for volumetric lights in Kerky if you want to play around with it. That increases rendering time too however but the scene itself is not too complex so there should not be any problems.
              • B
                bocomofo
                Kerkyhtea render.
                HDRI sky, setting 20 MLT (BPT). left overnight...not much else...
                apart from a squinty camera!
                Not up to the standards of some of the work posted here...but i'm pleased with it!
                j
                  steve2802
                  Guys,
                  I'm just getting into rendering so any feedback appreciated.
                  Maybe there are some tutorials on this sort of thing so if you could point me in the right direction I would be grateful.
                  Cheers,
                  Steve.
                  tried various things and it's getting better - guess i just need more practice.
                  • marvins_dadM
                    marvins_dad
                    I call it "Need Another Black Chair"
                    Rendered with Twilight, Interior+, 40 passes
                    My Gallery
                    • P
                      puck
                      Hi guys,
                      Thought I'd have a go at this one. I might try another few of the old ones as it has been great practice, especially when learning new software.
                      This was rendered in Arion for about an hour. I'm quite pleased with the results. Set up time was about 15 mins for the textures and lighting.
                      Comments would be very welcome.
                      Regards,
                      Puck
                      • ely862meE
                        ely862me
                        First try..kind of vapid.It took about 30 minutes in hypershot.Chair Loft.435.jpg
                        Some more tweaking.
                        Elisei (sketchupper)
                        Come and See EliseiDesign
                        • tridemT
                          tridem
                          Thanks Pete, it's a nice scene for a 'render this' thread, the brick wall inspired me somehow a dramatic scene (and then I saw some other had the same feeling)... I made a quick one with kerkythea and gimp.
                          Luca
                            jsteacy
                            here is my attempt, twilight, mostly kerkythea materials, DOF added in photoshop, the glass chair didn't turn out the best in the render but the DOF kind of hides it. I think I need to practice using the fur plugin a little more to get a more realistic distribution of ivy. Also I think the ivy has too much of a shine to it. I used the paint (flat enamel) preset in twilight, anyone have some suggestions on a better preset?
                            Cheers,
                            jsteacy
                            Chair loft with blur
                            original render
                            • jenujacobJ
                              jenujacob
                              http://i218.photobucket.com/albums/cc199/jenujacob/Thea Renders/ChairloftPS.png
                              Thea render.. straight output save for the border!
                                sketchnl
                                Hi People,
                                this is what I made of it. Rendered in Kerkythea and the finishing touches with photoshop.
                                http://www.sketchimpressions.nl
                                • pugz1983P
                                  pugz1983
                                  Hi Everybody,
                                  Since I've never entered a render challenge before, and because I love the scene and model Oli made, I decided to join in. Here's my contribution:
                                  Rendered for about 8 hours in Indigo on MLT setting
                                  Greetz Twan
                                  • B
                                    bocomofo
                                    Puck you're stone wall looks a bit shiny, but otherwise its looking good, especially the glass / clear chair.
                                    Thats a nice image jeremy...Good post pro in photoshop!
                                    Just goes to show what a difference it can make.
                                    If you dont mind me asking what procedure did you follow in photoshop?
                                    I tend to go for duplicate layer, add gaussian blur, set to soft light, reduce saturation and adjust curves.
                                    would be good to know what others do!
                                    j
                                    • jo-keJ
                                      jo-ke
                                      and another one
                                      http://www.zz7.de
                                      • MarianM
                                        Marian
                                        And a render made with Simlab Composer
                                        • EarthMoverE
                                          EarthMover
                                          Here's my go. Been a while since I did an interior. Nice, simple and fun, this one was.
                                          Content Creator at Skapeup
                                          • soloS
                                            Adam!!!!
                                            Long bloody time no see, awesome render mate.
                                            (please say you coming to base camp)
                                            • 2 / 6
