    About color
    14 Posts 5 Posters 962 Views 5 Watching
    • Z Offline
      zps222
      Below is my code, the result is only one face of the whole cube is blue, but what I want to see is the cube is painted all by "blue"
      Create the new material
      mats = Sketchup.active_model.materials
      ct_mat = mats.add "Color_Texture"
      ct_mat.color = "DodgerBlue"
      Draw a Face and set its material
      ents = Sketchup.active_model.entities
      face = ents.add_face [1, -1, 1], [1, 1, 1], [-1, 1, 1], [-1, -1, 1]
      ents.material = ct_mat
      Is there any method?
      I really appretiate.
        @zps222 said:
        # Draw a Face and set its material ents = Sketchup.active_model.entities face = ents.add_face [1, -1, 1], [1, 1, 1], [-1, 1, 1], [-1, -1, 1] ents.material = ct_mat
        You are applying material to the entities collection - no such method. That should produce an error.
        face.material = ct_ma should work
        Hard to tell why only one face is blue for you, since your sample code just creates a single face.
        • Z Offline
          zps222
          Thank you. I use the pushpull method to draw a cube, so is there any method to paint the other sides?
            Are you drawing into an empty context? Or into a context with existing geometry?
              If you draw into a context where it's only your group, you can do this:
              entities.each { |e|
                next unless e.is_a?(Sketchup;;Face)
                e.material = 'blue'
              If you are drawing into a context with existing geometry:
              cache = entities.to_a
              face = entities.add_face( [1, -1, 1], [1, 1, 1], [-1, 1, 1], [-1, -1, 1] )
              face.pushpull(1)
              (entities.to_a - cache).each { |e|
                e.material = 'blue'
              • AdamBA Offline
                AdamB
                Nice thomthom, but wouldn't it be simpler to apply color to the face and then pushpull and it will pick up the material of the originating face.
                  I did think of that - but when modelling I some times find PushPull to apply the material to the back-side of the extruded faces. Though not always - haven't worked out when it happens. (material is on the front face)
                    Good pragmatic solution. πŸ‘
                    • AdamBA Offline
                      AdamB
                      Whoa there! Hammer to crack a nut there.
                      In a right handed system (like SU), the front of a Face is defined in an anti-clockwise direction. Imagine gripping the face normal with your right hand and your thumb in the direction of the normal - your fingers show the winding of the face.
                      Face#pushpull() takes a distance to move along the face normal. So if you define a Face and paint its front material with something, then apply a negative pushpull, you'll always get a cuboid with that material on the outside.
                      Adam
                      • Dan RathbunD Offline
                        Dan Rathbun
                        But if you applied to both the front and back before push-pulling, then all will have the color afterward.
                        I'm not here much anymore.
                          The loop 'direction' does indeed force the face.normal except in one important case... If you draw a 'flat' face a z=0 it will always face downwards no matter which 'direction' you might have drawn the loop :!
                          It's a quirk of Sketchup - it thinks you are going to PushPull the face 'up' in that case so it orients it for you to suit. It happens when making flat faces at z=0 both manually AND via the API.
                          Whenever I do this sort of face making I always check for
                          face.nornal.z==-1 and face.vertices[0].position.z==0
                          and if true and if I want to PushPull the face 'up' I add face.reverse! before I face.pushpull(distance). Remember too that you also use a negative distance to make the 'box' above an 'upwards looking' face...
                          Incidentally Adam is right that adding the material before doing the PushPull is the simplest way to make all of the new faces in that material. It is best to leave face-backs in the default 'blue' back-material as it's easier to see what's happening without resorting to Monochrome mode to check faces are correctly oriented...
                            Dan Rathbun
                            Well not a hammer (you overreact..) nut..
                            The problem does not occur with the built-in pullpull tool.
                            Does SU automatically reverse the face that is colored differently, using the built-in Tool?
                            EDIT: I guess TIG answered the nitty-gritty there. The API doesn't say that Face.pushpull's second argument defaults to false.
                              In my experience - yes, sometimes.
                              • Z Offline
                                zps222
                                Thank you all guys
