    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Adding child group while parent group is active
    10 Posts 4 Posters 1.3k Views 4 Watching
    • DavidBoulderD Offline
      DavidBoulder
      We are having some problems getting the transformation correct when adding a child group to a parent group when that parent group is active. If the parent group isn't active then it works fine.
      Has anyone else had this problem. Details and technique to duplicate are below.
      Our workflow is that the user adds child groups to a parent group while the parent is open. The script below shows my problem, you have to enter it line by line in the ruby console because there are steps (Steps A and B) where you have to click around to change the current active group. I have tried calling make unique on both groups to no avail and can’t even do a work around of setting the child’s transformation to the parent’s inverse transformation because when I try to get the parent’s transformation it comes back as identity. I would really appreciate any help in finding a work around for this, I don’t want to have to go to components instead of groups unless I really have to.
      Script is below:
      # clear everything out
      Sketchup.active_model.entities.clear!
      # add the parent group
      group1 = Sketchup.active_model.entities.add_group
      # didn’t work
      # group1.make_unique
      # set parent’s transformation
      group1.transformation = Geom;;Transformation.translation(Geom;;Point3d.new(10.m, 0, 0))
      # add some points to the parent group
      group1.entities.add_cpoint(Geom;;Point3d.new(0.m, 0.m, 0.m))
      group1.entities.add_cpoint(Geom;;Point3d.new(5.m, 5.m, 3.m))
      # the parent group’s transformation shows the correct translation
      puts group1.transformation.to_a.join(', ')
      # step A) double click group1 to open it
      # parent’s transformation now shows as identity?
      # add the child group
      group2 = group1.entities.add_group
      # didn’t work
      # group2.make_unique
      # we want the child group’s axes to be the same as the parent group’s axes, unfortunately this seems to put it at the absolute origin
      group2.transformation = Geom;;Transformation.new
      # add some points to the child group
      group2.entities.add_cpoint(Geom;;Point3d.new(0.m, 0.m, 1.m))
      group2.entities.add_cpoint(Geom;;Point3d.new(5.m, 5.m, 4.m))
      # step B) exit out of all groups to top level model
      # the parent group’s transformation is correct
      # the child group has a negative translation to bring it back to the origin?  Why?
      puts group2.transformation.to_a.join(', ')
      # this will put group2 where it is supposed to be
      # group transformations are now correct
      David Goldwasser
      OpenStudio Developer
      National Renewable Energy Laboratory
        Returns the transformation of the current component edit session. If a user has double-clicked to edit a component's geometry, this will return the transformation of that component, relative to its parent's origin. This allows one to correctly calculate "local" transformations of a given entity regardless of whether the user is in edit mode.
        http://code.google.com/apis/sketchup/docs/ourdoc/model.html#edit_transform
        Have you looked into that method? SU7+ though.
          macumber
          Thanks ThomThom, do you have any information explaining edit_transform in more detail? In my case I have group1 with group2 inside of it. I sort of understand what this does when the active_path is '[group1]'. However, what happens when the active path is '[group1, group2]'? What I'm really after is some documentation like:
          when active_path is '[]', group1.transformation returns xxx, group2.transformation returns yyy, active_model.edit_transform returns zzz
          when active_path is '[group1]', group1.transformation returns xxx, group2.transformation returns yyy, active_model.edit_transform returns zzz
          when active_path is '[group1, group2]', group1.transformation returns xxx, group2.transformation returns yyy, active_model.edit_transform returns zzz
            If I remember correctly, when a group/component is open for editing SU will transform the coordinates inside the active context into global coordinates. With model.edit_transform you can convert the coordinates you get while editing back into local coordinates.
            You also have model.active_path http://code.google.com/apis/sketchup/docs/ourdoc/model.html#active_path with give you access to the current edit path.
            I can't remember exactly how it worked - I'm sure someone else will chime in.
              macumber
              I guess a simple question is which component are you editing when you are editing group2 inside of group1? Are you editing group2, group1, or both?
                danbig
                @davidboulder said:
                ...I don’t want to have to go to components instead of groups unless I really have to.
                Just out of curiosity, why do you want to use groups instead of components? I've been trying to set some standards for my own workflow of when to use a group vs. a component (beyond the obvious of having multiple instances of the same entity, or needing the internal reference axis of components).
                  Groups don't add entries in the Component Browser. The comp list quickly grows in a project, so unless I know I will need multiple instances of an object I create groups.
                    danbig
                    What about being able to change the internal axis of a component? It seems like this changes the orientation of the bounding box as well. Does this have any consequence on your workflow?
                      Never trust the API docs. šŸ˜•
                      Also check out the comments at the bottom of the page.
                        macumber
                        Well I guess I will have to get off my butt and post the answer to my own question:
                        # set child’s transformation
                        group2.transformation = Geom;;Transformation.translation(Geom;;Point3d.new(0, 10.m, 0))
                        group2.entities.add_cpoint(Geom;;Point3d.new(0.m, 0.m, 0.m))
                        group2.entities.add_cpoint(Geom;;Point3d.new(5.m, 5.m, 3.m))
                        puts Sketchup.active_model.active_path
                        puts Sketchup.active_model.edit_transform.to_a.join(', ')
                        # from top level
                        active_path = nil
                        group1.transformation = [1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 393.700787401575, 0.0, 0.0, 1.0]
                        group2.transformation = [1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 393.700787401575, 0.0, 1.0]
                        edit_transform = [1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0]
                        # open group1
                        active_path = [group1]
                        group1.transformation = [1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0]
                        group2.transformation = [1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 393.700787401575, 393.700787401575, 0.0, 1.0]
                        edit_transform = [1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 393.700787401575, 0.0, 0.0, 1.0]
                        # open group2
                        active_path = [group1, group2]
                        group2.transformation = [1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0]
                        edit_transform = [1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 393.700787401575, 393.700787401575, 0.0, 1.0]
