    PC v MAC webdialog populate
    45 Posts 4 Posters 7.1k Views 4 Watching
      I appreciate that if the only thing you want to do is 'set' a value [or 'remove' it] you can do it directly in js, BUT I do the callback when it does lots of other things to do too, then the value setting is just part of it - the sample if/else code is a pared down version...
      Also I've found that even using =1/=0 for true/false goes wrong in some setups, but "checked"/removing_the_attribute for true/false then works instead...
        Yes - that is what I do as well - I use the JS onclick event to set the checkbox value to reflect the state of the checkbox.
        And this is a great example for using frameworks - with jQuery I just make a live onclick event so all checkboxes created will behave like this. http://api.jquery.com/live/
        (untested - didn't have my reference code at hand)
        $('input[type=checkbox]').live('click', function() { $( this ).val( $(this).is(':checked').toString() ); });
        Not sure if that catches state change caused by keyboard though.
        If you don't need continuous update of the checkbox values, but rather at a single event, this works as well:
        // Set Checkbox values to reflect checked state so SU Ruby's $('input[type=checkbox]').val( function(index,value){ return $(this).is(':checked').toString() } );
          The question is can you get it to have a checkbox that when it is checked/unchecked [true/false] controls 4 other checkboxes, so that they are all set to be unchecked and disabled if it is unchecked, and if it is checked then they all become enabled and the first one is also ticked by default. I got this working fine on a PC with true/false etc but the MAC version refused to work when resetting from the SKP's attributes on a load etc - that is where I found the checked=null PLUS a follow up remove_checked_attribute and remove_disabled_attribute worked across all platforms... πŸ˜•
          • Dan RathbunD Offline
            Dan Rathbun
            A few Safari questions:
            Does Safari automatically keep it's WebKit up to date?
            Did you ask your testers what WebKit version their Safari was using?
            Still wondering if this behaviour is a WebKit bug...
            I'm not here much anymore.
              They are such a varied and clueless bunch they almost certainly won't know - I can't press it as they have helped above and beyond the call of duty already. πŸ˜’
                I'll have a look over the weekend. I have access to both PC and Mac.
                  Dan Rathbun
                  Well, the next alternative is to post in the WebKit Bugzilla, and see if they fix it or tell you it's the way they want it to work.
                    Dan Rathbun
                    ThomThom do me a favour, please.
                    On the Mac.. check the console output of:
                    RUBY_VERSION
                    %(#BF0000)[RUBY_PATCHLEVEL
                    RUBY_RELEASE_DATE]
                    RUBY_DESCRIPTION
                    I wish to know what their output is for the "out-of-the-box" OSX Sketchup.
                    Also wonder if they changed between ver 6.x and 7.x SU ??
                      RUBY_VERSION
                      RUBY_RELEASE_DATE]
                      RUBY_DESCRIPTION
                      Mac Mini Intel - OSX 10.5
                      ` > PLATFORM
                      i686-darwin8.10.1
                      RUBY_VERSION
                      1.8.5
                      RUBY_PATCHLEVEL
                      Error: #<NameError: (eval): uninitialized constant RUBY_PATCHLEVEL>
                      (eval)
                      RUBY_RELEASE_DATE
                      2006-08-25
                      RUBY_DESCRIPTION
                      Error: #<NameError: (eval): uninitialized constant RUBY_DESCRIPTION>
                      (eval)`
                        TIG: I I tried with a simple sample file. This works on both Explorer and Webkit:
                        <html>
                        <head>
                          <title>Checkbox Test</title>
                          <script type="text/javascript">
                        window.onload = init;
                        function $(id)
                          return document.getElementById(id);
                        function init()
                          $('ch1').onclick = function()
                            $('ch2').checked = this.checked;
                            $('ch3').checked = this.checked;
                            $('ch4').checked = this.checked;
                            $('ch2').disabled = !this.checked;
                            $('ch3').disabled = !this.checked;
                            $('ch4').disabled = !this.checked;
                          </script>
                        </head>
                        <body>
                        <p>
                        <label for="ch1">Checkbox 1</label>
                        <input type="checkbox" id="ch1" />
                        </p>
                        <fieldset>
                          <p>
                          <label for="ch2">Checkbox 2</label>
                          <input type="checkbox" id="ch2" disabled="disabled" />
                          </p>
                          <p>
                          <label for="ch3">Checkbox 3</label>
                          <input type="checkbox" id="ch3" disabled="disabled" />
                          </p>
                          <p>
                          <label for="ch4">Checkbox 4</label>
                          <input type="checkbox" id="ch4" disabled="disabled" />
                          </p>
                        </fieldset>
                        </body>
                        </html>
                        I tested on PC IE8 and OSX 10.5 SU7.1 Webkit
                        Zipped HTML test file
                          Thomthom - thanks for the example - so it appears that the embedded js solution works consistently but the ruby run-script with .setAttribute() etc doesn't - it's weird ?
                          I have tested it on my PC and it needed a tweak to do what I actually wanted - here's a version that sets only the first nested checkbox checked when the main one is checked [they all become enabled] - the other two nested checkboxes remain unchecked until you click on them - on unchecking the main one all of the nested ones are unchecked and disabled as required...
                          <html>
                          <head>
                          function $(id)
                          function init()
                              if (!this.checked)
                                val = this.checked
                              else
                                val = !this.checked
                              $('ch3').checked = val;
                              $('ch4').checked = val;
                            </script>
                          </head>
                          <body>
                          <p>
                          </p>
                          <fieldset>
                            <p>
                            </p>
                            <p>
                            </p>
                            <p>
                            </p>
                          </fieldset>
                          </body>
                          </html>
                          All it needs now is some auto-value setting when a checkbox is changed so that these can be read out into Sketchup when needed... πŸ€“
                            Your Ruby script calls a JS method that use setAttribute?
                            Why not just .checked ? I didn't try setAttribute at all, as checked seemed to work on all platforms.
                                // Make all checkbox's values reflect their checked state.
                                var inputs = document.getElementsByTagName('input');
                                for ( i=0; i < inputs.length; i++ )
                                  input = inputs[i];
                                  if ( input.getAttribute('type') == 'checkbox' )
                                    input.onchange = update_checkbox;
                                    input.onclick = update_checkbox; // for IE
                                    input.onkeyup = update_checkbox; // for IE
                              function update_checkbox()
                                this.value = this.checked.toString();
                                this.title = this.checked.toString();
                                hm.... that did not work under IE...
                                  Updated the post.
                                  That should work.
                                  NOTE! the onChange event triggers in IE when the input looses focus - so I attached the same event handler to onClick and onKeyUp to force immediate update. But if you use the this snippet with the other example the two onClick events will override each other and only one will trigger. You'd need to attach the event instead to make both event handlers work.
                                  • 2 / 3
