    PC v MAC webdialog populate
    45 Posts 4 Posters 9.0k Views 4 Watching
      OK, so far I find this - for PC and i must assume the same for MAC [?]
      The html attributes checked and disabled must be booleans =true/=false
      If you use a 'string' value - including ='false' - it always returns true [boolean] - I assume because a 'string' is 'something' and a false boolean is 'nothing'?
      The value attribute must be a 'string': I pair the checked and value with the test
      onclick="if(this.checked)(window.location='skp:resolution@true');else(window.location='skp:resolution@false');"
      Which says if this [checkbox] is checked [true as boolean] then do a callback passing 'true' skp:resolution@true [which is set in the rb file] and this sets the values of various related dialog items - e.g. setting that item's 'value' to match [ checked >>> value='true'] making other checkboxes checked/unchecked and enabled/disabled to suit [the 'else' test does the same callback passing 'false' etc].
      This all works fine on my PC...
      One thing I do notice is if I add
      @dlg.show{
        sleep(2)
        self.populate()
      It will initially show the dialog with all of the checkboxes ticked - although in the html it has checked=false !!! and then after 2 seconds the populate() kicks in and updates them all to suit... On the MAC version it seems as if it does the initial step and then fails on the populate() ??? Very puzzling πŸ˜•
      So it all works fine on a PC. Initially I did have a callback inside the html to run populate() as an onLoad= js function within the html's <body > tag but this caused a js parse child/parent error message for a few PC users (Win7+Chrome), which did nothing and it ran OK on a Yes reply, so I decided to run the populate() in the block of the ruby @dlg.show{} instead - it now works without errors for ALL PC users...
      However, for the MAC I have made many permutations of the html attributes and at what point populate() is run and I suspect that if I now get one of my MAC testers [e.g. long-suffering Burkhard] to try out this current version it'll still hiccup at the self.populate() step and so fail to change the checkboxes' values to the preset 'defaults' [or to the SKP's attributes as previously saved as attributes otherwise]...
      I can't find anything otherwise that tells us the dialog is fully loaded - if there were we could wait for it and then run populate() - but isn't that what the
      [ruby:2tujxofo]@dlg.show{once_its_loaded_we_can_do_more_commands_in_this_block}[/ruby:2tujxofo]
      does ???
      • Dan RathbunD Offline
        Dan Rathbun
        @tig said:
        I can't find anything otherwise that tells us the dialog is fully loaded - if there were we could wait for it and then run populate() ...
        Js Example (from MSDN)
        See: [onreadystatechange Event](http://msdn.microsoft.com/en-us/library/ms536957(v)
        // JavaScript
        document.onreadystatechange=fnStartInit;
        function fnStartInit()
           if (document.readyState=="complete")
              // Finish initialization.
        I'd think the handler function declaration, and the statement to register it would need to go in a <SCRIPT> element in the <HEAD> section.
        I'm not here much anymore.
          Dan thanks,
          I had this in the header
          <script type="text/javascript">
            function nowpopulate() {
              window.location='skp;populate@';
          </script>
          which runs the ruby populate code
          and this in the 'body tag'
          <body onLoad="nowpopulate()">
          which runs nowpopulate once all of the html has loaded
          This works fine on a PC but fails on a MAC.
          The way I currently have it set up is - with no js in the html and 'onLoad=' in the body, but instead within the ruby @dlg.show{self.populate()} which supposedly runs populate after the dialog is loaded - this works fine on a PC but fails on a MAC.
          I have also tried your suggested method [using fnStartInit] in the html and in the ruby @dlg.show{}... and that seems to work exactly the same on my PC as the other methods - i.e. it's all fine - but it's not yet been tested on the MAC - I'll get it tested by someone and report back...
          • Didier BurD Offline
            Didier Bur
            Hi TIG,
            Did you test with a 'yield' statement ?
            DB
              @didier bur said:
              Hi TIG,
              πŸ˜• Please explain 'yield' a little more...
                I think element.checked is a true/false boolean, but element.setAttribute('checked', x) - x should be either 'checked' or ''.
                  Thanks for all of the input...
                  Setting checked to be almost ANYTHING returns true [checked] on a MAC - even ='' is true! I'm about to try checked=null to see if that helps to 'uncheck' items on a MAC.
                  On a PC you can have checked=true [>>>true], checked=false[>>>false] or even checked='true' [>>>true], checked='false'[>>>false]... but on a MAC they are all *true*.
                  Also learnt that checked="checked" is the only way to set checked to be true in XHTML !!!
                  This area of coding is a mess...
                    Dan Rathbun
                    Is your checkbox control wrapped withIN a <FORM> element?
                    Some of the input control attributes may rely on being inside a FORM.
                    Safari could be nitpicky about this.
                    It seems to me I have a vague memory of having similar problems.
                    I think I just kept track of the checked state myself (with a Js var,) using the onClick event.
                    The only other thing I would suggest is playing with the HTML spec compliance settings in the <!DOCTYPE> tag and see if that makes a difference.
                      Dan Rathbun
                      [floatr:j2u13kn5]
                      http://images.apple.com/support/_images/hero_safari.jpg
                      [/floatr:j2u13kn5]TIG.. I did some checking over at the Apple Discussions
                      Did a search on "input type=checkbox"
                      and got a couple of hits with sample code.
                      It looks like these guys are using "0" and "1"
                      as the checked property value:
                      %(#804000)[<TD><input type="checkbox" name="AutoLogin"]%(#BF4000)[**value="1"**]%(#804000)[>Automatic Login</TD>]
                      URL:Topic : Safari ... cannot redirect to locations starting with "(null):" -- What?
                      %(#804000)[<label for="cb_cookieuser_navbar"> <input type="checkbox" name="cookieuser"]%(#BF4000)[**value="1"**]%(#804000)[tabindex="103" id="cb_cookieuser_navbar" accesskey="c" />Remember Me?</label>]
                      URL: Topic : Safari Browser does not play well with vbulletin forums (save login?)!
                        Dan, thanks. I have checked="checked" [i.e. checked] and checked=null [i.e. false] working fine on a PC and I'm waiting for feedback from some MAC testers...
                        The value= attribute is separate from the checkbox= issue - So I can get SUp to read the 'value' from the item I have to set its value='true' or 'false' according to the item's checked state - this is fine... BUT as I want to change the checked status of a checkbox with js (perhaps because some other checkbox changes these should not be checked either) then I change the value and checked together - fine on PC but fails on a MAC - though the jury's out on checked=null till the feedback arrives...
                        If the null option fails on the MAC I'll look at testing the value='0' / '1' alternatives 😞
                        I really can't seen where this is falling over........ πŸ˜’
                          have you considerd using a framework that will take care of these crossplatform issues for you? They are great time savers. Lets you focus on the making.
                            I am currently getting favorable results for the MAC testers using checked="checked" and checked=null !!!
                            The PC version already worked... so I'll report back when the jury's verdict is finalized. πŸ˜•
                              I think I have the solution πŸ˜•
                              document.getElementById("myCheckBox").setAttribute("checked", "checked");
                              document.getElementById("myCheckBox").setAttribute("checked", null);
                              document.getElementById("myCheckBox").removeAttribute("checked");
                              The first line 'checks' a checkbox in js... BUT... to 'uncheck' it the second AND third lines are needed
                              Some browsers/OSs want you to set its value to something 'false' [like null or false or ''], BUT some other browsers/OSs will take any setting at all to be 'true' and will therefore still 'check' it irregardless... so the only way to then 'uncheck' it is to remove its 'checked' attribute completely as in the third line!
                              Combining the last two lines should 'uncheck' a checkbox in most browsers/OSs ?
                              On a PC the second alone works but the third alone fails [and is ignored].
                              On a MAC the second alone fails but the third alone works.
                              Combining them should work 'cross-platform' ❓
                                Dan Rathbun
                                Hmmm... I'll bet we also have differing behaviour in regard to the defaultChecked and defaultValue properties on the two platforms.
                                defaultChecked
                                http://msdn.microsoft.com/en-us/library/ms533715(v=VS.85).aspx
                                defaultValue
                                http://msdn.microsoft.com/en-us/library/ms533718(v=VS.85).aspx
                                  Dan Rathbun
                                  Acording to:
                                  http://msdn.microsoft.com/en-us/library/ms533556(v=VS.85).aspx
                                  the above using "removeAttribute("checked")" is supposed to work on PC but in IE8 mode.
                                  You never said what PC browser ver that the tests were done on, and if you tried IE8 mode.
                                    It has to be multi-browser and platform including IE7 etc ?
                                    I think this latest fix works for everything so far...
                                      Dan Rathbun
                                      IE7(I haven't upgraded to IE8 yet.)
                                      Results the same for both:
                                      <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2 Transitional//EN">
                                      <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 STRICT//EN" "http://www.w3.org/TR/html4/strict.dtd">
                                      ID="myCheckBox"
                                      Check the checkbox:
                                      %(#408000)[WORKS]: myCheckBox.setAttribute('checked',**1**); %(#408000)[WORKS]: myCheckBox.setAttribute('checked',**'any string'**); %(#408000)[WORKS]: myCheckBox.setAttribute('checked',**true**); %(#408000)[WORKS]: myCheckBox.checked=**true**; %(#804000)[FAILS]: myCheckBox.defaultChecked=**true**;
                                      Uncheck the checkbox:
                                      %(#408000)[WORKS]: myCheckBox.setAttribute('checked',**0**); %(#408000)[WORKS]: myCheckBox.setAttribute('checked',**null**); %(#408000)[WORKS]: myCheckBox.setAttribute('checked',**false**); %(#408000)[WORKS]: myCheckBox.checked=**false**; %(#804000)[FAILS]: myCheckBox.defaultChecked=**false**; %(#804000)[FAILS]: myCheckBox.removeAttribute(**'checked'**);
                                        This is as expected - the checking is easy just set the 'checked' attribute to something 'positive' for a PC [or 'anything at all' for say a MAC - which causes the MAC's 'unchecking' conundrum]...
                                        So it's the 'unchecking' that is the pain...
                                        The myCheckBox.setAttribute('checked',null); will work on most platforms [like the PC] but the myCheckBox.('checked'); fails on the PC - however, but since that's after the ' =null' version has worked it's no matter...
                                        The will work on some platforms after the preceding myCheckBox.setAttribute('checked',null); has just failed [e.g. a MAC where ' =null' actually checks the box ! then the removeAttribute successfully unchecks it].
                                        I haven't tried the exact myCheckBox.checked=true; / myCheckBox.checked=false on a MAC test... but I suspect it'd fail as myCheckBox.setAttribute('checked',false); does fail...
                                        This is all too convoluted - but at least I seem to have a workaround that works on all tested platforms. πŸ˜’
                                          Dan Rathbun
                                          Have you tried the integers 0 | 1 on the Mac yet?
                                          It's so weird.. checked is supposed to be a boolean.
                                          I'd consider this a Webkit bug.
                                          Does anyone know if there is a website specific to webkit? Forums, BugReports, etc?
                                            Dan Rathbun
                                            To answer myself .. (to myself I says..)
                                            http://webkit.org/
                                            [url=https://bugs.webkit.org/query.cgi?format=specific&product=WebKit:1174kw44]The Webkit Bugzilla[/url:1174kw44]
                                            A search on "checkbox" gets 59 open hits. I did not see what had been closed.
                                            • 1 / 3
