    Tank Suspension
    34 Posts 4 Posters 4.7k Views 4 Watching
      camokid11
      errrrmmmm, so are you wanting to copy the arms of the suspension and the wheels.
      if so what i find the easiest is to copy it without any joins, so then you can copy it however many times you like and then attach the joints.
      or you could use physics copy to copy them with the joint, and then explode the groupe an reconnect the joints (but im not to sure with this method, i havnt used it must before)
      -- the way ide go around it, is copying the arm and wheel, then get rid of all joints inside the arm and wheel, and disconnect them from any other joint (so the arm and wheel have no joints inside or are connected to any).
      -- then copy and paste the arm and wheel together and place them where they are needed.
      -- then finally remake all of the joints again and then re-attach them.
      if you get confused with this method then just use your own and take your time. and remember save a copy before you start so if it goes wrong, you still have something to go back on.
      If you can read this, thank a teacher.
      If you can read this in english, thank a soldier.
      • H Offline
        hvypetals
        Thank you kindly.
        Do joints export? Like to 3DS for example?
        • H Offline
          hobbnob
          the physical joint will, but the mechanics of it won't
          My WIP Thread:Here
          • H Offline
            hvypetals
            groan... ๐Ÿ˜ž
            • H Offline
              hvypetals
              ok camokid i read your advice and i think i will do it that way
              this is a pic of where i am right now, the hull and turret are hidden and i cut the wall off inside the armor plate. attachment tests are coming up
              • H Offline
                hvypetals
                Any chance the selection cut tool will mess with my joints. I want to cut away the side skirts before attaching the joints so i can see a little better.
                  camokid11
                  errrrrrmmmmmm, to be honest i dont know, cus i make my physics tanks differently and i dont use that feature.
                  Normaly what i do when making tanks is make the full static model first and all in place. then i split it up into different "physics parts" (what i call for all different features like wheels, doors, turrets, ect...)
                  Then i work on each part induvidually, so the wheels are away from the body, and the joint are still visible, and nothing is locking the view.
                  To be honest i see no reason why the selection cut would interfere with the joints. Another option is making a line with the "line" tool and make a mark of where the part was and move it away so it doesnt block the part. then move it back after.
                  • H Offline
                    hvypetals
                    @camokid - i followed your advice almost exactly thank you for suggesting that.
                    you know I believe i made a mistake. i put the origin of axes for the main group (my hull) at center hull bottom but.. i shouldve put it at ground level instead i put it at hull. now when the armor drops the wheels sort of hang.
                    duh! Now what. I cant explode without everything falling apart. ๐Ÿ˜ฎ
                    • H Offline
                      hvypetals
                      Ugh Im getting stuck in the mud. My double hinges are turning inward.
                      I dont know what Im doing wrong and the tank is way to big already without the turret and gun. Oh well i guess this is good practice.
                      I would have provided the model in a zip but its so big.
                      ๐Ÿ˜•
                      tank bounces then all the legs push up and in
                        camokid11
                        right, rom what it looks like, it could be the collision geometry.
                        so what this is, is a normal physics box acts like a box, however when you make a complex shape, like a hole for a pin to go through, the collision geometry will still think the object is a box so nothing will go through the hole.
                        so the possible problem is that youve made the whole body as one model and grouped it all together. this means that the wheels (or suspension arms in your case) try to move outside the geometry.
                        its a pain to tell you how to fix it, so could you email it to me (Taylor.c.123@hotmail.co.uk) and ill fix it for you. the only problem with this method is, cus it adds more objects and stuff, it could add lag (but in the past ive picked up tips to cut lag).
                          camokid11
                          ha, dont worry we all make mistakes. and once you find one problem, then that means you stop doing it in the future. trust me, the more you make, the easier it becomes. (ever heard of meshing, its making propper 3D planes and stuff from 2D prints, On the 3D warehouse search Tu-160. better yet, here a link: http://sketchup.google.com/3dwarehouse/details?mid=df3944a1135871f5d40e00f72aac160e)
                          That took me about 2-3 weeks to make. now i could do it in a few days.
                          • H Offline
                            hvypetals
                            Thanks camokid Im going to send you the file to your email when I get home in about 5 hours I hope thats okay.
                            I think I understand what your saying. I did make these holes for my torsion arms. Last night I tried to seal them up but had the same issue. Im going to look at the example your provided as well. Although I have not heard of meshing but it sounds interesting.
                            I really appreciate all the help.
                            • H Offline
                              hvypetals
                              Great bomber btw! Reminds me of my Falcon 4.0 days.
                              What is this meshing? Im going to look it up.
                              • H Offline
                                hvypetals
                                after talking with camokid i am re approaching my tank to better suit the wheels. i did not model correctly and my hull was being seen as only a box thus pushing my wheels the wrong way.
                                in doing this i also chopped off the side skirt with a plane, outlined it and deleted my sloppy geometry and rebuilt a simpler version.
                                the old one is on top
                                  camokid11
                                  The new side is looking much better. and i cant wait to see if it works and see it when its done. f you need anymore help, just ask, ill try my best
                                  • H Offline
                                    hvypetals
                                    you rock Taylor thanks for the help. ๐Ÿ˜„
                                      camokid11
                                      god knows, its just one of the many unexplained things of life.
                                      thats or its a glitch
                                      • 2 / 2
