    Tank Suspension
    34 Posts 4 Posters 4.7k Views 4 Watching
    • H Offline
      hvypetals
      Any chance the selection cut tool will mess with my joints. I want to cut away the side skirts before attaching the joints so i can see a little better.
        camokid11
        errrrrrmmmmmm, to be honest i dont know, cus i make my physics tanks differently and i dont use that feature.
        Normaly what i do when making tanks is make the full static model first and all in place. then i split it up into different "physics parts" (what i call for all different features like wheels, doors, turrets, ect...)
        Then i work on each part induvidually, so the wheels are away from the body, and the joint are still visible, and nothing is locking the view.
        To be honest i see no reason why the selection cut would interfere with the joints. Another option is making a line with the "line" tool and make a mark of where the part was and move it away so it doesnt block the part. then move it back after.
        If you can read this, thank a teacher.
        If you can read this in english, thank a soldier.
        • H Offline
          hvypetals
          @camokid - i followed your advice almost exactly thank you for suggesting that.
          you know I believe i made a mistake. i put the origin of axes for the main group (my hull) at center hull bottom but.. i shouldve put it at ground level instead i put it at hull. now when the armor drops the wheels sort of hang.
          duh! Now what. I cant explode without everything falling apart. ๐Ÿ˜ฎ
          • H Offline
            hvypetals
            Ugh Im getting stuck in the mud. My double hinges are turning inward.
            I dont know what Im doing wrong and the tank is way to big already without the turret and gun. Oh well i guess this is good practice.
            I would have provided the model in a zip but its so big.
            ๐Ÿ˜•
            tank bounces then all the legs push up and in
              camokid11
              right, rom what it looks like, it could be the collision geometry.
              so what this is, is a normal physics box acts like a box, however when you make a complex shape, like a hole for a pin to go through, the collision geometry will still think the object is a box so nothing will go through the hole.
              so the possible problem is that youve made the whole body as one model and grouped it all together. this means that the wheels (or suspension arms in your case) try to move outside the geometry.
              its a pain to tell you how to fix it, so could you email it to me (Taylor.c.123@hotmail.co.uk) and ill fix it for you. the only problem with this method is, cus it adds more objects and stuff, it could add lag (but in the past ive picked up tips to cut lag).
                camokid11
                ha, dont worry we all make mistakes. and once you find one problem, then that means you stop doing it in the future. trust me, the more you make, the easier it becomes. (ever heard of meshing, its making propper 3D planes and stuff from 2D prints, On the 3D warehouse search Tu-160. better yet, here a link: http://sketchup.google.com/3dwarehouse/details?mid=df3944a1135871f5d40e00f72aac160e)
                That took me about 2-3 weeks to make. now i could do it in a few days.
                • H Offline
                  hvypetals
                  Thanks camokid Im going to send you the file to your email when I get home in about 5 hours I hope thats okay.
                  I think I understand what your saying. I did make these holes for my torsion arms. Last night I tried to seal them up but had the same issue. Im going to look at the example your provided as well. Although I have not heard of meshing but it sounds interesting.
                  I really appreciate all the help.
                  • H Offline
                    hvypetals
                    Great bomber btw! Reminds me of my Falcon 4.0 days.
                    What is this meshing? Im going to look it up.
                    • H Offline
                      hvypetals
                      after talking with camokid i am re approaching my tank to better suit the wheels. i did not model correctly and my hull was being seen as only a box thus pushing my wheels the wrong way.
                      in doing this i also chopped off the side skirt with a plane, outlined it and deleted my sloppy geometry and rebuilt a simpler version.
                      the old one is on top
                        camokid11
                        The new side is looking much better. and i cant wait to see if it works and see it when its done. f you need anymore help, just ask, ill try my best
                        • H Offline
                          hvypetals
                          you rock Taylor thanks for the help. ๐Ÿ˜„
                            camokid11
                            god knows, its just one of the many unexplained things of life.
                            thats or its a glitch
                            • 2 / 2
